Thermodynamics problem - circular process
13 replies · 3K views
solidbastard
MODERATOR NOTE - NO TEMPLATE BACAUSE POSTED IN GENERAL PHYSICS
I am having trouble attacking this problem properly and getting the right solution, which I do not have. (only know I did it wrong on exam).
Anyway, there is picture attached this is a cycle of some working material that has a total energy of U= alpha*T^4
I need to determine:
  1. Change of total energy from 1 to 2.
  2. Heat that came from 3 to 1.
For the first, I view it as adiabatic expansion, so there is no change of heat, only the work done. And for the second question, it is a constant volume, so there is no mechanical work that is done.
To solve it is going to use this or?
Code:
$(\frac{\partial U}{\partial V})\cdot dV + (\frac{\partial U}{\partial T})\cdot dT + (\frac{\partial U}{\partial p})\cdot dp$
So not sure if in total calculation should take in mind changes in p, T and V or what? Becuase T is changing always?
Anyway, thanks for help if anyone has solution :
Hi. Welcome to PF!
It would help to give us all the details. In order to quantify the total energy we would to know more than youhave provided. I assume you were told it is an ideal gas and can determine Cv and Cp.
This is a first law problem. Just use ## Q = \Delta U + \int PdV##
For the isothermal expansion from 1 to 2 is there any change in U? So what is Q?
For the constant volume heating from 3 to 1, what is the change in T? (hint: how is ΔU related to ΔT?)
AM
Andrew Mason said:
Hi. Welcome to PF!
AM
Hi Andrew! Thanks for welcome and thank your for the reply!
Yeah, problems is about ideal gas of total energy ## U = \alpha \cdot T^4 ##
I know for isothermal expansion that there is no change in U. So, with the first law ## Q = \int PdV##
And for constant volume part from 3 to 1, should I maybe try change in T with this relation. Where of course part of dV falls of, because there is no change?
##(\frac{\partial U}{\partial V})\cdot dV + (\frac{\partial U}{\partial T})\cdot dT + (\frac{\partial U}{\partial p})\cdot dp##Thanks for the help very much!
This is not the expression for U. That may be the source of your difficulty. T is a measure of the average translational kinetic energy of the molecules so U is proportional to T.
hint: to calculate, substitute for P using the ideal gas law.
Yes. Just use the relationship between ΔT, Cv and ΔU.
AM
Chestermiller said:
What is the exact statement of the problem (not your interpretation)?
In cycle shown on the picture working material of total energy ## U = \alpha \cdot T^4 ## is give.
Determine:
Change of total energy on the way 1 to 2.
Heat acquired on the way 3 to 1.
And I assume it is also ideal gas.And I got one more problem that is almost all the same, and goes like this (picture is the same):
In cycle shown on the picture working material is ideal gas of total energy ## U = c_v \cdot T##
Determine:
Change of total energy on the way 2 to 3.
Determine:
Determine:
This is the exact statement, word-for-word?
Yes. :)
Andrew Mason said:
Hi. Welcome to PF!
AM
Um..is the path 1 to 2 isothermal ?
The OP has traced out a straight line instead of the hyperbolic curve for isotherms.Can we still consider it to be isothermal ?
I think some information has been left out.
Yeah. Consider it isothermal. It is little bad drawing out there. :)
Ah, then its alright.
Determine:
Determine:
In the first part, this is obviously not an ideal gas. We need to know how P is related to V at constant T. The diagram appears to show ##P \propto 1/V##. Is that accurate? We really need to see the exact and complete wording of the problem.
AM
