How Do You Calculate the Increase in Internal Energy for Neon in a Tank?
  • Thread starter Thread starter PhysicStud01
    Thermodynamics
The discussion revolves around calculating the increase in internal energy for neon gas in a rigid tank as its temperature changes. The problem involves concepts from thermodynamics, particularly the relationships between pressure, volume, temperature, and internal energy for an ideal gas.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants explore the relationship between temperature and internal energy, questioning how to calculate changes in heat and work. There are discussions on the implications of a rigid tank on volume and work done on surroundings. Some participants attempt to apply the ideal gas law to find the number of moles of neon, while others express uncertainty about which temperature to use in their calculations.
The discussion is active, with participants providing insights and asking clarifying questions. Some guidance has been offered regarding the effects of temperature on internal energy and the calculation of moles, but there is still uncertainty regarding the application of work calculations in this context.
Participants are navigating the constraints of the problem, including the rigid nature of the tank and the implications for work done, as well as the need to accurately apply the ideal gas law with the correct temperature values.
PhysicStud01
Suppose that a tank contains 680 m3 of neon at an absolute pressure of 1.01x105 Pa. The temperature is changed from 293.2 to 294.3 K. What is the increase in the internal energy of the neon? [3.9x105 J]
delta Q = delta U + delta W
pV = nRT
there is no potential energy between them. all the kinetic of neon is kinetic since it is ideal gas
how do i find delta Q and delta W. should they be positve or negative?
i assume that an increase in temperature increases kinetic energy. so internal energy increase. delta U is positive?
can you please tell me how to proceed
If the tank is rigid, what can you say about its change in volume? Given this, how much work is done on the surroundings?
Chet
Chet
the volume won't change. but the pressure will.
i used P1 / T1 = P2 / T2 to find new pressure, then work = (delta p) V
but the answer was not correct
Actually, if the volume doesn't change, zero work is done on the surroundings.
Irrespective of whether any work is done, what is the effect of temperature on the internal energy of an ideal gas? How many moles of neon are present in the tank?
Chet
Chet
internal energy increases since kinetic energy increases
How many moles of neon are there in the tank? Quantitiatively (in terms of an algebraic equation), if the temperature of an ideal gas changes by ΔT, what is the change in the internal energy ΔU.
Chet
is it 1/2 k (delta T)?
i ca't obtain the answer with this too
Actually, it's 3/2 kΔT, and that's per molecule. What is the change in internal energy per mole? If you have n moles, what is ΔU? You still didn't tell me how many moles of neon are in the tank. You need this to determine the change in U. Do you know how to use the ideal gas law to calculate the number of moles in the tank?
Chet
Chet
from pV = nRT
but i don't know which temperature to use
PhysicStud01 said:
from pV = nRT
The number of moles in the tank doesn't change, and you're using the starting pressure and the starting volume in your calculation of the number of moles. So, does it make sense to you to use the final temperature or the starting temperature?
Chet
the starting one
So how many moles of neon are there in the tank? And you still haven't answered my question about the algebraic relationship between ΔU and ΔT for n moles of an ideal gas.
Chet
Chet
ok. thanks I got it.
but I still don't understand why work = (delta p) V cannot be used? if hte pressure changes, should not there be a work?
Since when is work equal to distance times the change in force?
Chet
  • · Replies 21 ·
  • · Replies 25 ·
