Thermodynamics - Rankine Cycle Reheating
3 replies · 5K views
ConnorM
A Rankine cycle with reheat uses water as its working fluid. Superheated vapour enters the high-pressure turbine at 10 MPa and 440oC. The steam expands through this high-pressure turbine to 0.7 MPa and is then reheated to 400oC. The steam then expands through the low-pressure turbine to 6 kPa before entering the con-denser. The mass flow rate of water through the cycle is 600 kg/s.The temperature of the water at the pump inlet is 30oC.
The isentropic efficiency of the pump is 65%. The isentropic efficiency of the high-pressure turbine is 92% while that of the low-pressure turbine is 87%.
The turbine and pump can be treated as adiabatic. The pressure drops of the work-ing fluid as it flows through the boiler and through the condenser are negligible. Kinetic and potential energy effects can also be ignored. For your analysis use the state point numbering scheme indicated in the following schematic:
Here is a picture of the problem as well as the schematic,
http://imgur.com/3jBdbn4,NhHwqlI
- Determine quality of steam at 2
- Determine quality of steam at 4
- Calculate the net power produced in the cycle
- Calculate the back work ratio of the cycle
- Calculate the thermal efficiency of the cycle
http://pascal.sca.uqam.ca/~eva/phy2001/TP_DocSoutien/TableauxDiagrammesThermodynamiques.pdf
I am using these steam tables
quality
x = ( sout - sf[P] ) / sfg[P]
enthalpy
h = hf[P] + x*hfg[P]
Wnet = Sum of Power
BWR =( -Wc/m ) / Wt/m
neff = Wt / Qin
Here is what I have done so far,
http://imgur.com/R4fRxqc
I am stuck on how I am supposed to find the net power and I am not 100% sure what I have done so far is correct.
For finding the newt power produced I think I know how to determine the turbine power, but for the pump power I have,
Wp = m ( h5 - h6 )
I am not sure how to find the h values and my data for state 5, T = 30 oC and P = 6 kPa doesn't seem to work with any of the steam tables.
edit: After working some more I noticed that it states that in state 5 it is water, so liquid. From here if I assume my pressure of 6 kPa is wrong and ignore it I can continue on and obtain my h5 also I can use the entropy from state 5 to interpolate my enthalpy in state 6 since I know it is an adiabatic pump.
Updated picture of my work, last 3 answers in bottom right,
http://imgur.com/tlzeU1k
Any help would be appreciated! Should I try posting somewhere else?
No, this is the right place. Somebody more knowledgeable than I should be weighing in shortly.
Wp = m ( h5 - h6 )
Anything coming out of the condenser is liquid water (that's what the condenser is for: to condense the gaseous steam into liquid water by removing the latent heat of vaporization).
Unlike the turbines, where the work done can be calculated by the change in enthalpy of the expanding steam, in the pump, you are raising the pressure of the liquid water from its value on leaving the condenser to a pressure high enough to force it back into the steam generator.
If your steam or compressed water tables don't have values for the enthalpy of water at high pressure, a different approximation of the pump work can be determined using the energy equation for incompressible fluids:
http://www.ohio.edu/mechanical/thermo/Intro/Chapt.1_6/Chapter4b.html
which is an application of the definition of enthalpy, h = u + Pv
http://en.wikipedia.org/wiki/Rankine_cycle
