Thermodynamics- thermal expansion coefficient
The volume thermal expansion coefficient (β) of a solid is definitively equal to the sum of its linear expansion coefficients in three dimensions, expressed as β = αx + αy + αz. For isotropic solids, this simplifies to β = 3α. The derivation involves calculating the change in volume of a cube when heated, leading to the approximation that β can be expressed in terms of the linear expansion coefficient (α) and temperature change (ΔT). This relationship is crucial for understanding thermal expansion in materials.
  • Understanding of thermal expansion coefficients (linear and volumetric)
  • Basic knowledge of calculus for differentiation and approximation
  • Familiarity with the concept of isotropic materials
  • Ability to manipulate algebraic expressions related to volume and temperature
  • Study the derivation of the volumetric thermal expansion coefficient in detail
  • Explore the properties of isotropic vs. anisotropic materials in thermal expansion
  • Learn about the applications of thermal expansion coefficients in engineering materials
  • Investigate the effects of temperature on material properties using finite element analysis
Students in physics or engineering, material scientists, and professionals involved in thermal analysis and material design will benefit from this discussion.
Fellowroot
Prove that the volume thermal expansion coefficient of a solid is equal to the sum of its linear expansion coefficients in the three directions. \beta=\alphax +\alphay+\alphaz
For isotopic solid when \beta = 3\alpha
\beta=[1/v][dv/dt]p= \alphax +\alphay+\alphaz
I have looked at several websites but can't seem to get it.
http://www.ami.ac.uk/courses/topics/0197_cte/index.html
http://en.wikipedia.org/wiki/Coefficient_of_thermal_expansion
I thought about just plugging in the \beta but I don't think that is correct.
Consider a cube, and calculate β in terms of changing edge lengths, and then in terms of α. What do you get? What approximations can you make if α is very small?
Thanks for your help.
I know see what you mean.
I did of course only understand it until I found this solution online, I wanted to post it here again just in case someone else wants it.
Let's start with that cube of side L.
If we heat it up, the length of each side will change from L to (L+ΔL), where ΔL = αLΔT.
In other words, the new length is:
L′ = L + αLΔT = L(1 + αΔT)
So the new volume is:
Vo′ = (L′)^3
= [L(1 + αΔT)]^3
= (L^3)(1 + 3αΔT + 3(αΔT)² + (αΔT)^3)
= Vo(1 + 3αΔT + 3(αΔT)² + (αΔT)^3)
Now we make an approximation. Since αΔT is quite small compared to 1, we can safely say that the "3(αΔT)²" term and the "(αΔT)^3" term are negligible compared to the "3αΔT" term. Therefore, to a good approximation,
Vo′ = Vo(1 + 3αΔT)
But we already know, from the definition of β, that:
Vo′ = Vo(1 + βΔT)
So this means that β = 3α.
16K
