Thevenin Equal Resistance - Strange Circuit
9 replies · 3K views · last reply
staggarhs
I want to find Rτ (Thevenin Equal Resistance) if the load is R4 in the attached image's circuit.
As easy it may seem, I get confused because it asks for the equal resistance between A and B.
We remove the voltage sources and s/c them. Then we have: R1 is parallel to (R2+R3) -> R1//(R2+R3).
R5 parallel to the rest. So we have in total: Rτ= [R1//(R2+R3)] // R5
  • Circuit schematic with two voltage sources Vs1 and Vs2, resistors R1 through R5, and nodes A and B, with a ground symbol at the bottom.
Welcome to PF :smile:
I see no current sources in the figure, those are voltage sources. So, what do we do with voltage sources?
Also, note R2 & R3 are not actually in series. Because node A has a path leading to R4, they (R2 & R3) do not have an equal current going through them.
Sorry my mistake. I meant Voltage sources. I need to find the Thevenin Equivalent Resistance if i take R4 as the load. So I replace voltage sources with short-circuit and also remove the load R4. From this point could you help me figure out the connections of the resistors ?
Thanks again...
Your approach looks ok. But the calculations are wrong. Check again how to calculate the paralleled resistances. Have you gotten ET already?
I haven't done any calculations yet, I just indicated how I think the resistors are connected. No I just want to find RT
Oh, okay. I thought those //'s were division marks.
Thanks again...
I would redraw the figure (with voltage sources shorted), with "A" at the very top and "B" at the bottom. Redraw/move the resistors around until you see some that are in parallel or series, and combine them.
I came up with this one, but the equivalent is different than the first one i posted ( Rτ= [R1//(R2+R3)] // R5 )
In this case it is: RΤ=[(R1+R2)//R3 + R5]
Please give me any hint as I am very confused.
Thanks a lot
  • Circuit schematic with terminals A at top and B at bottom. Between the top and bottom nodes, R2 and R1 are in series on the left branch, R3 is on the right branch in parallel, and R5 is in series below, labeled R5 near terminal B.
Thanks a lot
I'm not sure if this is any help to you, but what can be said about any open circuit (i.e. unconnected wires)?
Thanks a lot
There's some problems with your figure. Just for example, R2 should connect between A & B, after Vs2 is shorted.
