The Role of Propagators in Determining Decay Rates
The discussion centers on the role of propagators in determining decay rates, specifically in electromagnetic (EM) interactions involving massless photons. Participants clarify that while the amplitude for EM decays is expressed as f(q²) = g²/q², the propagator 1/q² is not ignored; rather, it is integrated over momentum space during calculations. The conversation highlights that in certain decays, such as the neutral pion decay, there are no virtual photon propagators, but virtual quark propagators must be considered to maintain dimensional consistency in decay rates.
  • Understanding of Feynman diagrams and their components
  • Knowledge of electromagnetic interactions and the fine structure constant
  • Familiarity with particle decay processes, specifically pion decays
  • Basic grasp of quantum field theory concepts
  • Study the role of virtual particles in quantum field theory
  • Learn about the decay processes of mesons, particularly neutral and charged pions
  • Explore the implications of gauge bosons in particle interactions
  • Investigate the mathematical treatment of decay rates in quantum mechanics
Physicists, particularly those specializing in particle physics and quantum field theory, as well as students seeking to deepen their understanding of decay processes and propagators in particle interactions.
vertices
i was thinking about propagators, and I've got bit of a silly question.
The amplitude for any given decay takes the form:
f(q^{2})=\frac{g^{2}}{q^{2}+M_{X}^{2}c^{2}}.
for EMAG decays, the Mx=0 (as we're dealing with photons), so the amplitude is just:
f(q^{2})=\frac{g^{2}}{q^{2}},
Why do we not consider the propagator: \frac{1}{q^{2}} when determining decay rates (we just say its proportional to the fine structure constant to power of the number of vertices)?
Hello.
In the case of EM interactions,
g IS the fine structure constant.. where's your problem ?
Atakor said:
Hello.
thanks Atakor.
I understand that. However, the gauge boson (the carrier of the electromagnetic force), in this case a massless photon, transfers a momenmtum q. Why is the propagor 1/q^2, ignored when calculating the transition amplitude?
Hello vertices!
In feynman language:
to each vertex we associate the couplig constant : -ig
for each _internal_ line we associate the function you dubbed f(q)
but f(q) is not the amplitude of the transition..
we have to integrate over all momentum space (q) (with conservation of energy-momentum)
after taking into account the functions of the particles (spin 1/2 ->spinors ...)
I hope this will help you.
We do take that factor into account! Do you have any specific example to discuss? That factor will be there with q having the value of some energy scale in the problem (of order the mass of the decaying particle).
Yes, as it happens I do. Please look at the attached files which consider the decays of the pi and pi- mesons. The bit I have highlighted bit in the file "Propagator 2", basically says that, in the case of the neutral pion, which decays electromagnetically, "there is no propagator". I don't get this!
A propagator is used when a virtual particle propagates from one vertex to another. In the decay of the pi0, there are no virtual photons, so there are no photon propagators. In decays where you do have a virtual photon, e.g. J/\psi \rightarrow \mu^+ \mu^-, you have a photon propagator.
i see. thanks for your reply Vanadium:)
If you look at the Feynman diagram, you will see that there is no gauge boson propagator (no photon propagator or W or Z boson propagator) involved in the neutral pion decay.
However, this is not the end of the story. And the excerpts you provided don't make much sense. You see right away that what they say does not make sense because a decay rate must always have the same dimensions no matter what process is computed. They seem to say that in one case the decay rate goes like 1/M^4 and in the other case it is dimensionless. This is clearly nonsense.
two things are missing to the discussion. First, in the charged pion decay there will be spinor factors coming from the outgoing fermions taht are being produced. These will provide additional dimensionful factors that must be taken into account. These will produce an additional factor with dimension of energy.
Also, in the neutral pion decay there is a propagator in the diagram: it's the propagator of the virtual quark between the two photon vertices! This must be taken into account as well. This wil produce a factor of dimension E^{-1}. This way the two diagrams will have the same dimensions (I am setting aside the factors coming from the initial quarks which are presumably of the same order in both diagrams so if we are taking a ratio of the two diagrams we don't have to think about those).
What is the source of those excerpts you provided. I hope it's not the book by D McMahon!
Yes indeed it is, thanks for pointing that out!
aahhh. didn't think of that. here comes a really stupid question - a virtual quark isn't a gauge boson, so how does it/why can it mediate the process in question?
Its "Nuclear and Particle Physics" by Brian Martin. I can overlook its complacency/lack of rigour because it does explain concepts quite well:)
