This is very hard i dont know how to start, please guide
  • Thread starter Thread starter eqreal
    Hard
The discussion revolves around a physics problem involving a particle suspended by a string over a peg, requiring the calculation of tension and mass. The key points include the equilibrium of forces acting on the particle, where the tensions in segments AP, PQ, and QB are equal due to the properties of the string and the setup. The problem also involves calculating the mass of a second particle attached to the string at a midpoint, with specific angles provided for the inclined segments. The solution requires applying the principles of static equilibrium and trigonometric relationships.
  • Understanding of static equilibrium in physics
  • Knowledge of tension in strings and forces
  • Basic trigonometry, specifically cosine functions
  • Familiarity with free body diagrams
  • Study the principles of static equilibrium in physics
  • Learn about tension in strings and how it relates to forces
  • Review trigonometric identities and their applications in physics problems
  • Practice drawing and analyzing free body diagrams for complex systems
Students studying physics, particularly those focusing on mechanics and equilibrium problems, as well as educators looking for examples of tension and force analysis in practical scenarios.
eqreal
(Take g = 10 m/s2 in this question.) The ends of a light inextensible string, of length 0.7 m, are attached to two fixed points A and B at the same horizontal level, where AQ = 0.4 m and QB = 0.1 m. A particle of mass 0.2 kg is attached to the string at the point P, where AP = PB = 0.3 m. The particle hangs in equilibrium, with the string passing over a small smooth peg fixed at the point Q in the horizontal line between A and B at a distance of 0.1 m from B, as shown below. Give three reasons why the tensions in the three parts, AP, PQ, and QB, of the string have the same value, and find this value. Also, determine the angle between QA and the force exerted on the string by the peg. Refer figure below:
http://s919.photobucket.com/albums/ad39/eqreal87/?action=view&current=DSC01488.jpg
The peg is now removed and a particle of mass m kg is attached to the string at the midpoint M of PB. The system hangs in equilibrium with PM horizontal, and AP and MB inclined to the horizontal at angles β and γ respectively, where cos β = 7/9 and cos γ = 1/3, as shown in the figure below. Calculate m
http://s919.photobucket.com/albums/ad39/eqreal87/?action=view&current=DSC01486.jpg
I'm stucked and I have no idea on how to start, can anyone please kindly guide me on this? I'll truly appreciate and thanks a lot
Use the fact that both the horizontal and the vertical components of all the forces on the various weights must cancel.
Check if you have copied the problem correctly. In the third line AP = PQ = 0.3m must have been meant.
the question is correct though. Sigh :(
10K
10K
