Timber Roof Trusses: Supporting Domestic Residences
  • Thread starter markeo
  • Tags
    Trusses
In summary, the conversation discusses a plumber drilling a 32mm hole through a 9"x2" timber joist for a second floor domestic residence. The hole is 30mm from a nail plate, raising concerns about the structural integrity of the beam. However, according to a stress concentration factors reference book, the hole will only increase bending stresses near the center of the beam by about 30%. To ensure safety, it is recommended to consult a professional engineer and provide detailed drawings of the connection and its location.
markeo
Dear all,
Situation:
plumber has drilled a 32mm hole through a 9"x2" timber joist. This is being used to support a second floor domestic residence.
ive been told the hole is central with in the section (ie: 9" thus 4.5" to centre) but its only 30mm from the nail plate.
Will this effect this beam as it lays a long on netral axis or do i need to look at the who truss as a structural element? I also have concerns over the close proximity of the nail plate, any practical remidies (ie: how to thicken or depend the section if required).
Regards
Markeo
Looking at my stress concentration factors reference book, a 32mm hole drilled in a 9" beam (a d/H ratio of ~.14) will increase the bending stresses near the center of the beam by about 30%, but the maximum stress will still reside at the top/bottom surfaces of the beam, and therefore not significantly reduce the beam's overall load carrying capacity. These are assumed for a beam of infinite length and uniform material, neither of which your beam satisfies perfectly (since you're near one end, and it's made of wood).
Keep in mind- it can be very difficult to guess at stress risers in wood due to grain structures and irregularities. If you're afraid of reduced strength to a critical structural beam, you should consult a professional engineer specializing in construction to take a look at it and give his opinion (...and tell the plumber to leave the structural members alone!).
By "nail plate", do you mean the support? If so, he has drilled the 32 mm dia hole pretty much at the point of maximum shear stress. To answer this question properly, we need a good drawing with three orthographic view, if you can manage it, to show the connection in detail, and its location relative to the beam. Having said all that, however, it doesn't sound very critical.
1. What are timber roof trusses?
Timber roof trusses are structural frames made of wood that are used to support the roof of a building. They consist of a series of interconnected triangles that distribute the weight of the roof evenly across the structure.
2. Why are timber roof trusses used in domestic residences?
Timber roof trusses are commonly used in domestic residences because they are cost-effective, lightweight, and can be easily customized to fit different roof shapes and sizes. They also allow for more open and flexible floor plans compared to traditional stick-built roofs.
3. How are timber roof trusses designed and manufactured?
Timber roof trusses are designed by engineers using specialized software that takes into account the specific load requirements and structural needs of a building. Once the design is finalized, the trusses are manufactured in a factory using precision cutting and assembly techniques to ensure accuracy and strength.
4. Are timber roof trusses strong enough to support heavy snow loads?
Yes, timber roof trusses are designed to withstand heavy snow loads and other weather conditions. The interconnected triangles in the truss design provide excellent strength and stability, making them suitable for use in areas with heavy snowfall.
5. Can timber roof trusses be used for different roof styles?
Yes, timber roof trusses can be used for a variety of roof styles, including gable, hip, and gambrel roofs. They can also be customized to fit unique roof designs, such as curved or vaulted ceilings.
