What is the optimal time-base setting for a c.r.o display?
  • Thread starter Thread starter Janiceleong26
    Base Time
To determine the optimal time-base setting for a cathode ray oscilloscope (C.R.O) display, one must calculate the period of the signal, which in this case is 0.02 seconds per revolution. The display width of 10 cm suggests that a time base setting should allow for approximately 5 revolutions to be visible. It is essential to select a time base that distinctly shows separate pulses without them appearing too close together. A slower setting may display more pulses, but could result in overlapping, while a faster setting might only capture part of a pulse. The goal is to find a balance that effectively visualizes both positive and negative voltage changes as the signal cycles.
Janiceleong26
How to find the time-base setting?
None
Firstly, I calculated the period of the revolution..
3000 Rev -> 60s
1 Rev -> 0.02s
Then, how to calculate the time base setting?
Do we need to estimate which is the most suitable one?
If the display is 10cm wide then, 0.1/0.02= 5 rev ?
Yes, estimating the most suitable one is the way to go. Work out how many cycles of the signal will appear on the display for each of the timebase settings and select one that will most distinctly show (to the naked eye) separate pulses.
Ok, thanks !
This is a tricky question. Obviously the slowest setting will show the most pulses, but will they appear too close together? The fastest setting might show only one pulse or only part of it. Also the pulse should go both positive and negative (volts) as the magnet passes the coil.
Thread 'Correct statement about size of wire to produce larger extension'
The answer is (B) but I don't really understand why. Based on formula of Young Modulus: $$x=\frac{FL}{AE}$$ The second wire made of the same material so it means they have same Young Modulus. Larger extension means larger value of ##x## so to get larger value of ##x## we can increase ##F## and ##L## and decrease ##A## I am not sure whether there is change in ##F## for first and second wire so I will just assume ##F## does not change. It leaves (B) and (C) as possible options so why is (C)...
9K
  • · Replies 16 ·
