Does Time Dilation Explain the Lack of Effects in Quasar Light Curves?
Passionflower
On a paper published recently by Hawkins (not Hawking):
In this paper we set out to measure time dilation in quasar light curves. In order to detect the effects of time dilation, sets of light curves from two monitoring programmes are used to construct Fourier power spectra covering time-scales from 50 d to 28 yr. Data from high- and low-redshift samples are compared to look for the changes expected from time dilation. The main result of the paper is that quasar light curves do not show the effects of time dilation. Several explanations are discussed, including the possibility that time dilation effects are exactly offset by an increase in time-scale of variation associated with black hole growth, or that the variations are caused by microlensing in which case time dilation would not be expected.
Comments? Opinions?
http://www.physorg.com/news190027752.html
http://www3.interscience.wiley.com/journal/123345710/abstract?CRETRY=1&SRETRY=0
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
