Time Dilation at Near Light Speed: Answers to a Thought Exercise
The discussion revolves around a thought exercise related to time dilation as described by special relativity, specifically focusing on a scenario involving a spaceship traveling at near light speed and its implications for time perception between observers on Earth and aboard the spaceship. The scope includes conceptual understanding of time dilation and the relativistic Doppler effect.
  • Some participants propose that both the shipboard observer and the Earthbound observer will perceive the other's clock as running slow due to the symmetrical nature of their relative motion.
  • One participant emphasizes the importance of accounting for the travel time of video signals and suggests using a spacetime diagram for clarity.
  • Another participant clarifies that the primary effect observed will be the relativistic Doppler effect, which causes images of each other's clocks to lag behind, rather than a direct observation of time dilation.
  • A participant explains that time dilation is specific to the moving ship according to the inertial reference frame (IRF) where Earth is at rest, and that the ship experiences time dilation while Earth does not.
  • It is noted that the relativistic Doppler effect will result in both observers seeing the other's time taking longer, despite the differences in time dilation experienced by each observer.
  • One participant questions the initial misunderstanding of the concept and seeks clarification on how time appears to pass differently for each observer.
Participants express differing views on the interpretation of time dilation and the relativistic Doppler effect, with some clarifying misunderstandings while others maintain their original positions. The discussion remains unresolved regarding the nuances of how each observer perceives time.
Limitations include the dependence on specific inertial reference frames and the complexity of visualizing time dilation versus the relativistic Doppler effect. The discussion highlights the need for careful analysis of these concepts in relation to each observer's frame of reference.
Hollygrove
I'm fairly new to the concepts provided by special and general relativity, and was wondering if someone could provide an answer to a thought exercise I came across regarding time dilation on an object going near light speed.
Say a spaceship were connected by a live video feed to a monitor on Earth, and the feed was being monitored at both ends.
The spaceship then accelerates to near light speed away from Earth, which in my understanding would slow the passage of time on board the ship in relation to time passing on Earth. So my question is what would the video show? Would time actually appear to be moving slower from a person on Earth's view of the video feed, would it appear to be moving faster from someone onboard the ship? Or have I misunderstood the concept?
Both the shipboard observer and the earthbound observer will report that the other clock running slow. The situation is symmetrical, as each observer will consider themselves to be at rest while the other one is moving.
To analyze this situation correctly you need to allow for the travel time of the video signals, and a carefully drawn spacetime diagram is a big help.
First of all, welcome to Physicsforums! :-)
The main effect will be in first instance the Doppler effect: as the distance between the Earth and the spaceship increases faster and faster, images of each other's clocks take increasingly more time to reach the other - in other words, clocks appearing on each other's video feeds will increasingly lag behind.
The effect of "time dilation" comes only in addition to this basic Doppler effect; thus it appears as a correction to what you would expect to see based on classical physics.
Actually, a better, more precise, way of saying this is that it would slow the passage of time on board the moving ship according to the Inertial Reference Frame (IRF) in which the Earth is at rest. Saying it the way you said it is what led you to the false conclusion that the passage of time on Earth will be faster than time passing on the moving ship.
This slowing of time for an object moving according to an IRF is what is called Time Dilation. So in the IRF in which the Earth is at rest, it does not experience Time Dilation, only the ship does because only the ship is moving (after it leaves Earth).
It doesn't show Time Dilation. Rather it shows the Relativistic Doppler Effect. Let me give you an example. Let's suppose that the ship leaves the Earth at 60% of the speed of light. The Time Dilation factor at that speed is 1.25 which means that the clock on the ship will take longer to tick out each second than the Coordinate Time of Earth's rest IRF. But the Relativistic Doppler factor at that speed is 2 which means it takes twice as long for the Earth to see a particular amount of time passing on the ship through the video feed.
Here's a spacetime diagram for Earth's IRF showing the Earth as the thick blue line and the ship as the thick red line. The dots mark off one-second intervals of time for each of them. The thin lines represent one-second intervals of the video feed, red for the video sent from the ship and blue for the video sent from the Earth:
As you can see, the blue dots are aligned with the Coordinate Time of the diagram because the Earth is not moving in this IRF but the red dots are spaced 1.25 times the Coordinate Time.
Yes, you have misunderstood the concept. As I stated earlier, you have incorrectly concluded that if Earth sees time going slower on the ship then the ship must see time going faster on Earth.
But if you look at the diagram, you can also see that it takes twice as long, two seconds according to the dots, for each of them to receive each second of the video feed from the other one. So even though only the ship is Time Dilated in this IRF, they both see the same Relativistic Doppler Effect of the other one. In other words, they cannot see the Time Dilation, they can only see the Relativistic Doppler Effect.
To emphasize this point, I'm going to use the Lorentz Transformation process on the coordinates of each of the events (dots) in the above diagram to see what things look like in the IRF in which the ship is at rest after the Earth and ship separate:
As you can see, the Relativistic Doppler Effect remains the same as in the first diagram, that is, they each see the others time taking twice as long as their own even though it is the Earth that is now Time Dilated according to this IRF.
We could also transform to other IRF's and they would all show the same Relativistic Doppler Effect even though the Time Dilation of each object can be different. Just remember that Time Dilation is dependent on the speed of an object according to an IRF so since speeds are different in different IRF's, so are Time Dilations but they all show the same observations of each observer.
Does this all make perfect sense to you now? Any questions?
Thank you for the replies, especially ghwellsjr, it was very thorough. I'll have a look through at the relativisticdoppler effect so that I have a better understanding, but the scenario is much clearer now.
  • · Replies 65 ·
14K
  • · Replies 25 ·
  • · Replies 26 ·
  • · Replies 42 ·
  • · Replies 27 ·
  • · Replies 45 ·
