Time Dilation for Slower Objects - Physics Explained
The discussion revolves around the concept of time dilation, particularly in relation to objects moving at various speeds, including the speed of light and slower speeds such as the speed of sound. Participants explore the implications of time dilation in different mediums and the nature of light's speed in relation to moving observers.
  • One participant questions whether time dilation occurs at slower speeds, such as the speed of sound, and if it varies in different mediums.
  • Another participant asserts that time dilation is not applicable to light and only pertains to objects moving slower than light.
  • Misunderstandings about the nature of time dilation and the speed of light are highlighted, with calls for clarification on the original participant's references and reasoning.
  • Clarifications are made regarding the distinction between time dilation and the constancy of the speed of light, emphasizing that only objects with nonzero rest mass can experience time dilation.
  • One participant suggests starting with a foundational understanding of Special Relativity to address the misconceptions presented.
Participants generally disagree on the understanding of time dilation and its application, with multiple competing views on the original participant's interpretations and questions. The discussion remains unresolved regarding the clarity of the concepts involved.
Participants express uncertainty about the original participant's references and understanding, indicating a need for clearer foundational knowledge in Special Relativity. There are unresolved aspects regarding the application of time dilation to various speeds and the implications of moving observers.
This discussion may be useful for individuals seeking to understand the complexities of time dilation, particularly in the context of Special Relativity and the behavior of light and slower-moving objects.
iForget
Good day,
I'm a high schooler so my knowledge of physics is futile and still expanding. Please correct me when I'm wrong, I love physics.
Now to my question. I'm still a bit fuzzy on this theory of time dilation and the speed of light etc. But if time dilation happens at the speed of light can it also happen at slower speeds such as the speed of sound? If this is true does the amount of time dilation change within a different medium or a vacuum all together?
My understanding of time dilation is that if you (or an object) that is traveling at the speed of light moves or emits a beam of light then that beam/movement will still move at the speed of light regardless of your motion prior to said event while everything else observing it sees it slower. Because the speed of light is constant and nothing can move faster than it. This raises another question. If this is so; your moving at the speed of light and you move just your hand, will time then slow down for the rest of your body as your hand is moving?
I am very lost.
It doesn't. The concept of "time dilation" isn't applicable to light. It's only applicable to things that move slower than light.
It only makes sense as a concept at slower speeds.
...appears to be garbled. Can you give the references you are using? It appears that you have misunderstood or misinterpreted quite a few things.
To briefly outline some of the misconceptions in your post:
(1) Nothing except light, or other radiation that has zero rest mass, can move at the speed of light. You can't, and an ordinary object (meaning, anything with nonzero rest mass) can't. So saying "if you (or an object) that is traveling at the speed of light" makes no sense.
(2) Time dilation is not the same thing as the speed of light being the same in all inertial frames.
(3) As above, time dilation as a concept does not apply to light, or anything that moves at the speed of light. It only applies to things that move slower than light, i.e., things with nonzero rest mass.
iForget said:
The references are from various places,
http://galileo.phys.virginia.edu/classes/252/time_dil.html being one.
That reference looks fine to me. But I don't see how you are getting from what you read there to any of the questions you ask in the OP. I think you might want to take a step back and read the article again.
I also came across the train example. Being that all this is theoretical/conceptual so were my questions.
At a quick glance, I see nothing wrong with the presentation in that link, but your understanding of it is, as Peter said, totally garbled. It does not present anything that I can see that would lead to any of your erroneous conclusions/beliefs.
Perhaps some of your other references were more confusing than this one.
At any rate, I suggest that you start with a simple presentation on Special Relativity from the ground up. I don't have a good reference off hand to point you to, but a forum search will likely turn something up since such recommendations occur here from time to time.
I don't understand you point about your questions being theoretical/conceptual.
EDIT: I see Peter beat me to it :smile:
That's not time dilation. If you watch a moving clock, you will observe that it runs slow. A clock running slow is not the same thing as an object moving slow. A clock running slow means time itself has slowed. An object moving at a slow speed is something else, like a car moving at 30 mi'h is slow compared to a car moving at 60 mi/h.
A clock in motion relative to you runs slower than a clock that's not moving relative to you. The faster the clock moves, the slower it runs.
Nothing with mass can move as fast as light. It's the absolute speed limit.
Thank you everyone.
I will go back and start from the ground up. I must have missed or misinterpreted a large part in properly understanding. I'll revise and try rebuilding the proper paradigm for a subject this complex.
Thank you.
  • · Replies 26 ·
  • · Replies 18 ·
  • · Replies 58 ·
  • · Replies 16 ·
  • · Replies 45 ·
  • · Replies 47 ·
  • · Replies 27 ·
