Time Dilation on Spinning Atoms?
1832vin
would time dilation occur if for example, i was making a hydrogen atom spin with the center of spin the atom? would time dilation occur? because it didn't really traveled distance...
or, if so spin a muon, would it decay faster if i was to spin it in an incredible amount of speed?
but then if it does, how about the center of the muon, it has not moved
above all, can you even spin a particle, i know there are spins on atoms, but i mean, but you counter spin the funtimental particle's spin, would that cancel it out? (no, i mean because it's not spinning in a dimension!)
If you find a way to do that, publish it, that would violate quantum mechanics.
You can excite the atom to give the electron some spin, but that is not a rotation of the atom, so no time dilation involved.
You cannot change the spin of a muon (well, just its direction). A muon does not have a finite size (at least no known size), something like "the center of a muon" is not a meaningful concept.
Likes 1 person
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
