Time Independant Pertubation Theory - QM
3 replies · 2K views
knowlewj01
An electron is confined to a 1 dimensional infinite well [itex]0 \leq x \leq L[/itex]
Use lowest order pertubation theory to determine the shift in the second level due to a pertubation [itex]V(x) = -V_0 \frac{x}{L}[/itex] where Vo is small (0.1eV).
[1]
[itex]E_n \approx E_n^{(0)} + V_{nn}[/itex]
[2]
[itex]V_{nn} = \int_{-\infty}^{\infty} \psi_{n}^{(0) *} (x) V(x) \psi_{n}^{(0)} (x) dx[/itex]
the following integral may be useful:
[3]
[itex]\int_{0}^{2\pi}\phi sin^2 \phi d\phi = \pi^2[/itex]
From [1] and the known result for E2 of an infinite well
[itex]E_2 = \frac{4\hbar^2 \pi^2}{2mL^2} - \frac{2V_0}{L^2}\int_{0}^{L} x sin^2\left(\frac{2\pi x}{L}\right) dx[/itex]
I can't see a substitution that will get it into the form in [3], anyone have any ideas?
Also, is equation [1] a general result for the time independent case for first order pertubations?
Thanks
If i were to make the substitution:
[itex]\phi = \frac{2\pi x}{L}[/itex]
[itex]\frac{\phi}{x} = \frac{2\pi}{L}[/itex]
does this imply that the limits of integration change from L to 2π ?
knowlewj01 said:
[1]
No, it isn't. It applies when the energy eigenstates of the unperturbed Hamiltonian states are non-degenerate, like in this problem. You'll have to use a different approach for the degenerate case.
