Time with no gravitational force
Guiga
Hello everyone,
I was doing my Physics homework and a question arose from it: if a mass affects time there is a difference in the time measured near different masses. However if there was no mass at all?
Let's pretend this is possible just for theoretical purposes, a perfectly flat space-time. In this situation time would not pass at all.
So how can light travel through such regions? (I know there is not such a thing in the Universe but intergalactical space may have very little space-time distortion.)
Just to confirm if my understanding is correct: time would pass slower near the Sun than near the Earth? (imagine they are both static, they do not have either translation or rotation)
Thank you very much!
Why do you say time will not pass at all? ds^{2} = -dt^{2} + dx^{2} + dy^{2} + dz^{2} and \tau = \int_{\gamma }(-g_{\mu \nu }dx^{\mu }dx^{\nu })^{1/2} so in the rest frame of a test particle \Delta \tau = \int_{t_{i}}^{t_{f}}dt = \Delta t so there is a passage of proper time.
1. This should go in the Homework section.
2. Yes, time does pass slower near the Sun than near the Earth(however, both amounts of time dilation are so small they are irrelevant, we aren't near neutron stars or black holes here)
I really do not know how time would pass in such a region. That is really beyond me. There are plenty of people here who know more about this stuff than I do.
Hi WannabeNewton,
I couldn't understand perfectly the equation you posted but I got the idea. So actually my reasoning was misleading, time would be pass extremely fast in a space-time without gravity.
Is this difference in time taken into account when calculating distances in light-years?
xeryx35, this question was not from my homework, actually the way I wrote made it confusing.
Thanks!
When you say extremely fast, it's somewhat meaningless. Anyone can travel through time, its given by your temporal velocity which comes from the velocity 4-vector, u_{\alpha}=\langle u_0, \vec{u} \rangle. Here we can look at u_0, which equals u_0=\gamma c=\frac{c}{\sqrt{1-\frac{v^2}{c^2}}} where v^2 is the magnitude of the 3-velocity. This can also be written
<br /> \gamma=\frac{1}{\sqrt{1-\frac{v^2}{c^2}}}=\frac{dt}{d\tau}<br />
where \tau is the proper time. This says you can move through time at a maximum speed of 1 sec/sec, which is essentially what you are experiencing now relative to the rest of us and everyday experiences. But as you seemed to have picked up, this depends on the gravitational field one is immersed in, so in flat space, you are moving through time at essentially the rate you are moving through it right now since the curvature is practically negligible.
Flat spacetime is a gravitational field. its commonly expressed as \eta_{\alpha\beta}. In Einstein's relativity, there are sill solutions to the field equations that determine the dynamics of gravity even in the absence of sources of gravitation. This is similar to Maxwell's equations, for instance \vec{\nabla}\cdot\vec{E}=\rho /\epsilon_0 still has solutions even when \rho=0, that is, there are "free-field solutions". In fact there are many solutions that satisfy the vacuum equations, for instance, the solution describing the spacetime around our star, Sun. I hope this puts some things in order for you.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
