TISE solution for a hydrogen atom
The discussion revolves around the time-independent Schrödinger equation (TISE) for a hydrogen atom, specifically focusing on the radial component and the wave function, psi. Participants are exploring the relationship between the parameters involved, particularly the Bohr radius (a_0), and how it relates to the total energy of the system.
  • Participants are attempting to substitute the wave function into the TISE and are questioning how the derived expression relates to the total energy. There are discussions about the dependency of the expression on the variable r and the conditions under which a_0 must be defined.
The conversation is ongoing, with participants providing hints and guidance on how to approach the problem. There is recognition that a_0 is not an independent constant and must be expressed in terms of fundamental constants. Some participants are exploring the implications of setting terms to zero to simplify the equation.
There is an emphasis on understanding the physical significance of the parameters involved, particularly the kinetic and potential energy expressions, and how they relate to the overall energy of the electron in the hydrogen atom. Participants are also navigating the complexities of the Hamiltonian and its role in quantum mechanics.
Kynsuo
Show that psi is a solution to the radial component of the TISE for the electron in the Hydrogen Atom, find the value of ##a_0## in terms of fundamental constants and find the energy for this state.
$$- \frac{\hbar^2}{2mr^2} \frac d {dr} \left(r^2 \frac {d \psi}{dr} \right) + V(r) \psi = E \psi$$
$$V(r) = -\dfrac 1 {4 \pi \varepsilon_0} \dfrac{e^2}{r}$$
$$\psi(r) = \dfrac 1 {\sqrt{\pi a_0^3}} \exp\left(-\dfrac r {a_0}\right)$$
I am unable to complete the first part of the question. After I plug in the function for psi into the differential equation I am stuck:
$$\frac {d \psi (r)}{dr} = -\frac 1 a_0 \psi (r), \frac d{dr} \biggl(r^2 \frac {d\psi (r)}{dr} \biggr) = -\frac 1 {a_0}\frac d {dr} \bigl[r^2 \psi(r) \bigr] = - \frac 1 {a_0}\biggl[ 2r\psi(r) - \frac{r^2}{a_0} \psi(r) \biggr]$$
$$\frac{\hbar }{2mr^2} \frac 1 {a_0} \biggl[ 2r \psi(r) - \frac {r^2}{a_0} \psi(r) \biggr] + V(r) \psi(r) = E \psi(r) $$
$$\Leftrightarrow \psi (r) \biggl[ \frac {\hbar}{2mr^2} \frac {2ra_0-r^2}{a_0^2} - \frac{e^2}{4 \pi \varepsilon_0 r} \biggr] = E \psi(r)$$
I don't the how the expression I get in the brackets in the RHS at the end is equal to the total energy.
The solution requires a specific value of ##a_0##. The parameter ##a_0## can't just be any value.
Hi, thank you so. much for your reply, but I'm not sure I understand your point. Does this mean that ##a_0## has to be such that the expression in the brackets is equal to the sum of the potential and kinetic energies?
It means that ##a_0## has to be such that the expression in the brackets is constant! I.e. not a function of ##r##.
Hi, I think that this is my problem: I don't understand why the total energy/expression the brackets has no dependency on the variable ##r##.
You need to try to find ##a_0## to achieve that. Hint: expand the expression explicitly in powers of ##r##.
Kynsuo said:
Homework Statement:: Show that psi is a solution to the radial component of the TISE for the electron in the Hydrogen Atom, find the value of ##a_0## in terms of fundamental constants and find the energy for this state.
Relevant Equations:: $$- \frac{\hbar^2}{2mr^2} \frac d {dr} \left(r^2 \frac {d \psi}{dr} \right) + V(r) \psi = E \psi$$
Your calculations are all correct.
What Perok is pointing out is that ##a_0## is not an independent constant. It can actually be written in terms of ##e,\epsilon_0, \hbar, m_e##. Use this and then you will see that the energy will be a constant and will give the correct value.
What Perok is pointing out is that ##a_0## is not an independent constant. It can actually be written in terms of ##e,\epsilon_0, \hbar, m_e##. You can either 1) look it up and you will see that the energy will be constant or 2) impose that the energy does not depend on ##r##, in other words, force the term proportional to ##1/r## to be zero. That will give the value of ##a_0## in terms of these other parameters.
Then you will see that the energy will be a constant and will give the correct value.
Thanks nqred, but I think I'm still missing something. Can this expression for ##a_0## be found purely mathematically or do I need to make assumptions/ rewrite other terms?
Can you solve this equation for ##a_0##?
$$\frac{a_0}{r} - \frac 2 r = 0$$
Hi PeroK, thanks for replying. The solution would be ##a_0 =2## but I'm not sure I understand why I need this equation.
That equation was simpler, but the same as this one. Which you seem to be so frightened of that you're afraid to go anywhere near it! :smile:
Kynsuo said:
$$\Leftrightarrow \biggl[ \frac {\hbar}{2mr^2} \frac {2ra_0-r^2}{a_0^2} - \frac{e^2}{4 \pi \varepsilon_0 r} \biggr] = E $$
Hi, I still don't get it (I'm really sorry :(! ): when I replace ##a_0## by 2, the expression inside the brackets is still dependent on ##r##
Start with
$$\frac {\hbar}{2mr^2} \frac {2ra_0-r^2}{a_0^2} - \frac{e^2}{4 \pi \varepsilon_0 r} = \frac {\hbar}{ma_0r} - \frac {\hbar}{2ma_0^2} - \frac{e^2}{4 \pi \varepsilon_0 r}$$
So, if we have:
$$\frac {\hbar}{ma_0r} - \frac{e^2}{4 \pi \varepsilon_0 r} = 0$$
Then we get rid of all terms in ##r##. To do this we need:
$$\frac {\hbar}{ma_0} = \frac{e^2}{4 \pi \varepsilon_0}$$
Hopefully you can solve for ##a_0## from there.
PeroK said:
Start with
So, if we have:
Hi peroK, this is really helpful, and I am confident I can solve this equation for ##a_0##. I think that my problem is that I don't understand why the kinetic energy of the electron in the hydrogen atom is: $$ \frac {\hbar}{ma_0r} - \frac {\hbar}{2ma_0^2}$$
It depends what you mean by understand. It all came out of your calculation in the original post. Which in turn were based on expressing the Hamiltonian in spherical coordinates.
I haven't studied the Hamiltonian in much detail as this came from an introductory foundation course for quantum physics, which I will study in detail next year (all I know is that it is an operator that returns the total energy of a system). What I mean by understand is that I am not able to see how this expression for the kinetic energy stems directly from my calculation.
Kynsuo said:
$$ \psi (r) \biggl[ \frac {\hbar}{2mr^2} \frac {2ra_0-r^2}{a_0^2} - \frac{e^2}{4 \pi \varepsilon_0 r} \biggr] = E \psi(r)$$
I'll try explaining this. You arrived at the expression shown above all by yourself therefore you understand it. You have one equation and apparently two unknowns, ##a_0## and ##E## which the problem is asking you to find. Furthermore, you are also asked to show that the given wavefunction is a solution. There are only specific values for ##a_0## and ##E## that make the wavefunction a solution. The underlying logic then is to assume that the given wavefunction is indeed a solution and then proceed to find ##a_0## and ##E## that will make this a correct assumption.
Under the assumption you can cancel ##\psi(r)## that appears on both sides, noting that it is zero only at infinity. Then you have the energy, $$E= \biggl[ \frac {\hbar}{2mr^2} \frac {2ra_0-r^2}{a_0^2} - \frac{e^2}{4 \pi \varepsilon_0 r} \biggr]$$ Again under the assumption, this equality must hold for any value of ##r## otherwise we don't have a solution.
In post #14, @PeroK showed how this can be achieved and obtained the equality$$\frac {\hbar}{ma_0} = \frac{e^2}{4 \pi \varepsilon_0}.$$At this point, all you have to do is solve this last equation for ##a_0##, then go back to the energy equation and substitute ##a_0##. The ##r## terms in the expression should drop out because ##a_0## was chosen specifically to make this happen. This then will give you a constant for the energy ##E##. Not only that, but also you have justified that ##\psi(x)## is a solution. If you don't believe me that this is the case, you can always take the given ##\psi(x)##, the value for ##a_0## and ##E## that you found and put them all in the original TISE. If you make no algebraic mistakes, you should end up with ##0=0##.
Hi! Sorry for taking so long to get back. I understand PeroK's logic better now. I alsorealised that there is a typo in my equation (all the ##\hbar##'s are actually ##\hbar^2##) . Thank you for that. The only thing I'm missing is how PeroK went from
##\frac{\hbar^2}{2mr} \frac{2a_0-r}{a_0^2} - V(r) = \frac{\hbar^2}{ma_0r}- \frac{\hbar^2} {2ma_0^2} - V(r)##To: ##\frac{\hbar^2}{ma_0r} - V(r) =0 ##
I didn't really do anything there. I just noted that if we choose ##a_0## such that:
$$\frac{\hbar^2}{ma_0r} - V(r) =0$$
Then:
$$\frac{\hbar^2}{ma_0r}- \frac{\hbar^2} {2ma_0^2} - V(r) = - \frac{\hbar^2} {2ma_0^2}$$
is constant, which is what we want.
Then:
Hi PeroK, thank you so much for getting back so fast. This might sound stupid, but are we allowed to do this? Can we 'chose a value for ##a_0## such that the expression is equal to zero' only because this equation is true for all values of ##r##, IE this is not an equation, but an identity?
We can if ##V(r) = \frac k r##. That's the point.
High Perok: I think I understand. Basically, the energy must be a constant that doesn't depend on ##r##. Since we have 2 terms of the form ## \frac cr, \; c \in \mathbb C ##, their sum must equate to 0. This also makes sense because the expression gives the first energy state for the H atom when I plug in the value of ##a_0##.
Thanks!
