TISE solution for a hydrogen atom
22 replies · 3K views
Kynsuo
Show that psi is a solution to the radial component of the TISE for the electron in the Hydrogen Atom, find the value of ##a_0## in terms of fundamental constants and find the energy for this state.
$$- \frac{\hbar^2}{2mr^2} \frac d {dr} \left(r^2 \frac {d \psi}{dr} \right) + V(r) \psi = E \psi$$
$$V(r) = -\dfrac 1 {4 \pi \varepsilon_0} \dfrac{e^2}{r}$$
$$\psi(r) = \dfrac 1 {\sqrt{\pi a_0^3}} \exp\left(-\dfrac r {a_0}\right)$$
I am unable to complete the first part of the question. After I plug in the function for psi into the differential equation I am stuck:
$$\frac {d \psi (r)}{dr} = -\frac 1 a_0 \psi (r), \frac d{dr} \biggl(r^2 \frac {d\psi (r)}{dr} \biggr) = -\frac 1 {a_0}\frac d {dr} \bigl[r^2 \psi(r) \bigr] = - \frac 1 {a_0}\biggl[ 2r\psi(r) - \frac{r^2}{a_0} \psi(r) \biggr]$$
$$\frac{\hbar }{2mr^2} \frac 1 {a_0} \biggl[ 2r \psi(r) - \frac {r^2}{a_0} \psi(r) \biggr] + V(r) \psi(r) = E \psi(r) $$
$$\Leftrightarrow \psi (r) \biggl[ \frac {\hbar}{2mr^2} \frac {2ra_0-r^2}{a_0^2} - \frac{e^2}{4 \pi \varepsilon_0 r} \biggr] = E \psi(r)$$
I don't the how the expression I get in the brackets in the RHS at the end is equal to the total energy.
The solution requires a specific value of ##a_0##. The parameter ##a_0## can't just be any value.
Hi, thank you so. much for your reply, but I'm not sure I understand your point. Does this mean that ##a_0## has to be such that the expression in the brackets is equal to the sum of the potential and kinetic energies?
It means that ##a_0## has to be such that the expression in the brackets is constant! I.e. not a function of ##r##.
Hi, I think that this is my problem: I don't understand why the total energy/expression the brackets has no dependency on the variable ##r##.
You need to try to find ##a_0## to achieve that. Hint: expand the expression explicitly in powers of ##r##.
Kynsuo said:
Homework Statement:: Show that psi is a solution to the radial component of the TISE for the electron in the Hydrogen Atom, find the value of ##a_0## in terms of fundamental constants and find the energy for this state.
Relevant Equations:: $$- \frac{\hbar^2}{2mr^2} \frac d {dr} \left(r^2 \frac {d \psi}{dr} \right) + V(r) \psi = E \psi$$
Your calculations are all correct.
What Perok is pointing out is that ##a_0## is not an independent constant. It can actually be written in terms of ##e,\epsilon_0, \hbar, m_e##. Use this and then you will see that the energy will be a constant and will give the correct value.
What Perok is pointing out is that ##a_0## is not an independent constant. It can actually be written in terms of ##e,\epsilon_0, \hbar, m_e##. You can either 1) look it up and you will see that the energy will be constant or 2) impose that the energy does not depend on ##r##, in other words, force the term proportional to ##1/r## to be zero. That will give the value of ##a_0## in terms of these other parameters.
Then you will see that the energy will be a constant and will give the correct value.
Thanks nqred, but I think I'm still missing something. Can this expression for ##a_0## be found purely mathematically or do I need to make assumptions/ rewrite other terms?
Can you solve this equation for ##a_0##?
$$\frac{a_0}{r} - \frac 2 r = 0$$
Hi PeroK, thanks for replying. The solution would be ##a_0 =2## but I'm not sure I understand why I need this equation.
That equation was simpler, but the same as this one. Which you seem to be so frightened of that you're afraid to go anywhere near it! :smile:
Kynsuo said:
$$\Leftrightarrow \biggl[ \frac {\hbar}{2mr^2} \frac {2ra_0-r^2}{a_0^2} - \frac{e^2}{4 \pi \varepsilon_0 r} \biggr] = E $$
Hi, I still don't get it (I'm really sorry :(! ): when I replace ##a_0## by 2, the expression inside the brackets is still dependent on ##r##
Start with
$$\frac {\hbar}{2mr^2} \frac {2ra_0-r^2}{a_0^2} - \frac{e^2}{4 \pi \varepsilon_0 r} = \frac {\hbar}{ma_0r} - \frac {\hbar}{2ma_0^2} - \frac{e^2}{4 \pi \varepsilon_0 r}$$
So, if we have:
$$\frac {\hbar}{ma_0r} - \frac{e^2}{4 \pi \varepsilon_0 r} = 0$$
Then we get rid of all terms in ##r##. To do this we need:
$$\frac {\hbar}{ma_0} = \frac{e^2}{4 \pi \varepsilon_0}$$
Hopefully you can solve for ##a_0## from there.
PeroK said:
Start with
So, if we have:
Hi peroK, this is really helpful, and I am confident I can solve this equation for ##a_0##. I think that my problem is that I don't understand why the kinetic energy of the electron in the hydrogen atom is: $$ \frac {\hbar}{ma_0r} - \frac {\hbar}{2ma_0^2}$$
It depends what you mean by understand. It all came out of your calculation in the original post. Which in turn were based on expressing the Hamiltonian in spherical coordinates.
I haven't studied the Hamiltonian in much detail as this came from an introductory foundation course for quantum physics, which I will study in detail next year (all I know is that it is an operator that returns the total energy of a system). What I mean by understand is that I am not able to see how this expression for the kinetic energy stems directly from my calculation.
Kynsuo said:
$$ \psi (r) \biggl[ \frac {\hbar}{2mr^2} \frac {2ra_0-r^2}{a_0^2} - \frac{e^2}{4 \pi \varepsilon_0 r} \biggr] = E \psi(r)$$
I'll try explaining this. You arrived at the expression shown above all by yourself therefore you understand it. You have one equation and apparently two unknowns, ##a_0## and ##E## which the problem is asking you to find. Furthermore, you are also asked to show that the given wavefunction is a solution. There are only specific values for ##a_0## and ##E## that make the wavefunction a solution. The underlying logic then is to assume that the given wavefunction is indeed a solution and then proceed to find ##a_0## and ##E## that will make this a correct assumption.
Under the assumption you can cancel ##\psi(r)## that appears on both sides, noting that it is zero only at infinity. Then you have the energy, $$E= \biggl[ \frac {\hbar}{2mr^2} \frac {2ra_0-r^2}{a_0^2} - \frac{e^2}{4 \pi \varepsilon_0 r} \biggr]$$ Again under the assumption, this equality must hold for any value of ##r## otherwise we don't have a solution.
In post #14, @PeroK showed how this can be achieved and obtained the equality$$\frac {\hbar}{ma_0} = \frac{e^2}{4 \pi \varepsilon_0}.$$At this point, all you have to do is solve this last equation for ##a_0##, then go back to the energy equation and substitute ##a_0##. The ##r## terms in the expression should drop out because ##a_0## was chosen specifically to make this happen. This then will give you a constant for the energy ##E##. Not only that, but also you have justified that ##\psi(x)## is a solution. If you don't believe me that this is the case, you can always take the given ##\psi(x)##, the value for ##a_0## and ##E## that you found and put them all in the original TISE. If you make no algebraic mistakes, you should end up with ##0=0##.
Hi! Sorry for taking so long to get back. I understand PeroK's logic better now. I alsorealised that there is a typo in my equation (all the ##\hbar##'s are actually ##\hbar^2##) . Thank you for that. The only thing I'm missing is how PeroK went from
##\frac{\hbar^2}{2mr} \frac{2a_0-r}{a_0^2} - V(r) = \frac{\hbar^2}{ma_0r}- \frac{\hbar^2} {2ma_0^2} - V(r)##To: ##\frac{\hbar^2}{ma_0r} - V(r) =0 ##
I didn't really do anything there. I just noted that if we choose ##a_0## such that:
$$\frac{\hbar^2}{ma_0r} - V(r) =0$$
Then:
$$\frac{\hbar^2}{ma_0r}- \frac{\hbar^2} {2ma_0^2} - V(r) = - \frac{\hbar^2} {2ma_0^2}$$
is constant, which is what we want.
Then:
Hi PeroK, thank you so much for getting back so fast. This might sound stupid, but are we allowed to do this? Can we 'chose a value for ##a_0## such that the expression is equal to zero' only because this equation is true for all values of ##r##, IE this is not an equation, but an identity?
We can if ##V(r) = \frac k r##. That's the point.
High Perok: I think I understand. Basically, the energy must be a constant that doesn't depend on ##r##. Since we have 2 terms of the form ## \frac cr, \; c \in \mathbb C ##, their sum must equate to 0. This also makes sense because the expression gives the first energy state for the H atom when I plug in the value of ##a_0##.
Thanks!
