To find out the compression of the spring
The discussion revolves around calculating the compression of a spring when a 2kg block slides down an inclined plane with a spring constant of 100 N/m at the bottom. The block is released from rest at the top of the incline, which is 4m from the spring, and the kinetic coefficient of friction is 0.1. The initial attempt yielded a compression of 0.797m, while the correct answer is 0.933m. Key errors identified include the incorrect application of gravitational potential energy and the distance over which friction acts, which should be 'x' rather than 4m.
  • Understanding of conservation of energy principles
  • Familiarity with spring mechanics and Hooke's Law
  • Knowledge of kinematic equations and their applications
  • Basic concepts of friction and its impact on motion
  • Review the principles of conservation of mechanical energy in systems with nonconservative forces
  • Study the correct application of gravitational potential energy in inclined planes
  • Learn about Hooke's Law and its implications for spring compression
  • Explore the effects of friction on energy conservation in mechanical systems
Students studying physics, particularly those focusing on mechanics, as well as educators seeking to clarify concepts related to energy conservation and spring dynamics.
icecool8
Hi Guys, I am trying to solve a classic problem involves conservation energy, spring, compression, I got my attempt and answer and I think my step was correct but the answer is different with the solution, can anyone please have look for me, any suggestions will be really appreciated.
Here is the question:
2kg block is at rest at the top of a inclined plane, spring constant is 100N/m is at the bottom of the incline, the equilibrium position of the spring is 4m from the block's position, the θ=30, the block is released at some instant in time. find out the compression of the spring if the kinetic coefficient of friction is 0.1
ΔK+ΔU=-fd
Vf=√(Vi+2aΔx)
g=9.8
n=mgcosθ, therefore f=μN=0.1*2*9.8*cos30=1.6974
ƩFx=mgsinθ-f=ma
a=(2*9.8*0.5-1.6974)/2=4.0513
Vf=√0+2*4.0513*4=5.69
then ΔK+ΔU=-fd (because the block slided down and contacted to the spring, the Vf become Vi, the Vf become 0)
(Kf+Uf)+(Ki+Ui)=-fd
0+0.5*100*x^2-0.5*2*5.69^2-2*9.8*sin30*x^2=-1.6974*4
x=0.797, but the answer in the solution sheet is 0.933m,
I don't know where I went wrong...
welcome to physicsforums, icecool8! hmm, before I look through the working, I better check a few things: The equilibrium position is 4m from the block's position, does that mean the equilibrium position is 4m down the slope from the block? Also, is the spring attached to the block from the start? Or does the block only come into contact with the spring at the equilibrium position?
Welcome to PF!
It looks like you are using both the kinematic and energy methods and mixing up your approach. You could forget the kinematic method and just use the energy method from start to finish. Note that your gravitational potential energy change is incorrect. It is not mgsintheta(x^2); and the work done by friction in your last equation does not act over a distance of 4 m, it acts over x meters.
Hi BruceW,
Thanks for your reply and sorry about not clearly explain the question
yes, the equilibrium position is 4m down the slop from the block, the spring is unstretched(assume it is massless) it is not attached to the block from the start, it is at the bottom of the inclined plane, and block slides down then contact to the spring, the speed of the block is zero when the block compresses the spring.
PhanthomJay said:
Welcome to PF!
Hi PhanthomJay, Thanks for that,
,thats right, once the block contacted the spring, it should only act over x meter ,not the 4m, Thanks for that
My understanding for the nonconservative force such as friction are involved is total initial and final energy=decrease in mechanical energy which is the friction in this case...and is the energy = potential energy +kinetic?
Find the energy when the block just barely touches the spring, kinetic and potential(with reference to final compression)
This energy will compress the spring.
Remember when compression is carried out, take account of friction too.
You have the correct energy equation when non conservative forces act, W_nc = ΔK+ΔU. Your '2 step' approach using the kinematic equations and Newton's laws for the first part of the motion, and the energy approach for the second part of the motion, is not necessary, but it is nevertheless OK. So after you make the correction for the friction force distance using 'x' instead of '4 m', the other correction you need to make relates to the change in the gravitational potential energy, whch is a function of x, not x^2 as you have written.
Thanks for your hints
9K
