Today I Learned
  • Thread starter Thread starter Greg Bernhardt
6,993 replies · 637K views
fresh_42 said:
boarding (5m - since there is no need to board all at once!)
If the airplane makes multiple stops on the way to your destination you lose much more time. You want a direct flight, or at least just 2-3 flights for more complicated trips.
Today I learned on YouTube that you can kill a phone by putting it in 2% Helium Air mix. Apparently the MEMs oscillators are sensitive and stop working for several days.
Today I learned it's plausible to open a door, and then have one of these metal bars fall on your head. Careful out there! lol
I just went and did the math of g after a meter...it was probably traveling about 15km/h; figuring it's not much of a glider.
TIL that there are as may neurons in the human intestine as there are in a cat's brain.
I am studying abiogenesis at the mo and I decided to find a decent biology forum. First page I went to recommended...you guessed it. Physics forums!
I would agree with that.
I have checked out a few biology forums, but have not found one as nice as the Physics Forums.
Let me know if you find a good one.
My previous post was inspired by an article in this week's New Yorker magazine about facial recognition technology. It discusses the company that is applying it to cows:
[...] Cainthus's head of product science [...] grew up in Brooklyn, earned a Ph.D. in high-energy physics from Yale, and spent five years smashing subatomic particles at CERN's Large Hadron Collider, in Switzerland. She is now a student of cow behavior.
Yet another example of where you can end up with a physics Ph.D.! :cool:
You know how we're related to earthworms Stavros? The human intestine / digestive system is basically a 5 foot worm with it's organs on the outside and a calcium phosphate skeleton so it can walk.
It seems that vertebrates are evolved worms.
mfb said:
"Worm" is a poorly defined group
Yes. In addition, the word "worm" can be used in different ways in biology:
1) general outside shape; like a worm (long and skinny, often wiggly or squirmy), ends could be pointy or rounded; vermiform
2) Organisms that are phylogenetically related to present day worms (see @mfb's post above), not in any obvious way.
3) a general worm-like body plan (this is what @skyshrimp may have been talking about.
However, he seems to equating just the inner (gut) tube as the worm.
Perhaps he meant just a single tube, thereby ignoring other wonderful aspects of worminess.
Topologically, most body plans of animals can be reduced or simplified by pushing in the limbs to make a flatter surface without changing its planar contintuity (there's probably a name for this).
Doing this reduces them to either a sphere or a donut or torus shape (often described as a tube within a tube).
An elongated donut would be pulled into a tube within a tube shape, where the outside layer is the ectoderm (protective skin surface).
The inside layer is the endoderm which forms the gut (all the internal digestive surfaces of the body).
The sheet of gut cells is continuous with the outer surface curved into the middle of the donut).
See figure 4 https://www2.estrellamountain.edu/faculty/farabee/biobk/BioBookDiversity_7.html. This is a traditional conceptual diagram of the main features of body plans of three different phyla (all worms) with a tube within a tube tissue organization.
Similarly, a sphere shape cold have a pushed in surface to make it cup shaped. The possibly protected, pushed in surface cold be specialized in digestion of food and absorption of nutrients. This would form a bag within a bag topology and a one ended gut.
Upon developing directional movement, and organism would be expected to acquire front and back end specializations for sensory and motor control as well as in what goes on at the front end of the digestive tube as opposed to the back end.
Efficiency would drive these features which are widely found in different animals.
At some point a two ended gut could be formed by either:
  • A part of the folded in surface of could instead fuse with a different area of the outside of the sphere that it is pressed up to on their inside surfaces.
or:
  • the sides of the elongated pinched in surface would fuse together (at the tissue level (sheets of cells)) to form a tunnel for food input at one end and waste offloading at the other. (I like this one better because the change expected would be less of a big modification in how things were operating than creating a new opening (with new flows of materials) would require.)
It has therefore been assumed that the simplest of early metazoans in the animal lineage would have evolved the first of body plans through a sequential addition of features such as:
  • have tissues specially organized cells, cell types
  • inside/outside (like ectoderm/endoderm) distinction
  • top/bottom axis and later an axial position readout system
  • Front/back axis and later an axial position readout system
  • Ball to Donut shape transformation (formation of a tubular gut from a pinched in region); therefor distinguish endoderm/ectoderm molecularly (This would be a the worm-like body plan
Although these kinds of transformations may not be allowed in topology (so I have heard!), it is not that difficult for biological systems to create new openings or fuse an opening closed during embryology.
4) The simplest of bilateral organisms would have the head/tail, top/bottom, inside/outside distinctions. Soon after a tubular worm-like (tube within a tube) body plan would be evolved. This according to @mbf's link, would be at the level the xenacoelomorpha group branches off. The last common ancestor of both the protostomes and the deuterostomes.
Xenacoelomorphs are very primitive. They have a front/back, top/bottom, a primitive digestive system with only one opening (mouth/anus), a kind of bag inside a bag body plan that can be simplified to a sphere.
They have not yet formed the tube within a tube aspect of their body plan.
Some might call them a worm. They are shaped somewhat like a flatworm, which also have single ended guts.
Immediately after this branch point in the phylogeny shows the split between the protostomes and the deuterostomes, which is a distinction based upon which end (the mouth or the anus) forms first in development (the cellular processes that shape and determine the adult body form).
This basic feature of the body plan, may have been set-up independently, which could explain the difference,
or there might have been some kind of anatomical transformation of the mouth or anus location.
Today I learned that there is a fish that is afraid of the water.
Blue Planet II: Meet the fish which is so scared of water it lives in a cave
It is not easy being a fish when you are afraid of the water.
So spare a thought for the leaping blenny, which detests the sea so much, it chooses to live in miniature cave three feet above the tide-line in Guam, Micronesia, and scampers to higher ground when it notices even the smallest wave approaching.
The Pacific leaping blenny, which needs to frequently roll around in coastal puddles to stay wet, has been filmed for the first time by BBC’s Blue Planet II.
Wow - and i thought I was neurotic !
Today I learned that Cantor set theory is still controversial at least among those who /can/ do not understand it.
TIL where the word ghetto comes from.
It originated from Venetian Italian. The copper manufacturers lived in a certain part of town and used to throw their waste all on the same place. To throw away meant gettare in the local dialect and the place became getto. When the jews were forced to move in this part of town, they pronounced it ghetto, according to the German pronunciation of Yiddish.
Today I learned about a curious nearly-pattern in the decimal system:
##10^{14}-1 = 909,091 \times 109, 999,989##
##10^{24}-1 = 99,990,001 \times 9,901 \times 1, 010,099, 989,899##
##10^{36}-1 = 999,999, 000,001 \times 9,901 \times 100, 999,999, 999,999, 999,899##
##10^{38}-1 = 909,090,909,090,909,091 \times 109, 999,999, 999,999, 999,989##
##10^{39}-1 = 900,900,900,900,990,990,990,991 \times 1,109, 999,999 ,999,889##
##10^{48}-1 = 9,999, 999,900, 000,001 \times 99, 990,001 \times 1, 000,100, 009,999, 999,899 ,989,999##
##10^{62}-1 = 909,090,909,090,909,090,909,090,909,091 \times 109 ,999,999 ,999,999 ,999,999 ,999,999, 999,989##
##10^{72}-1 = 999999 000001 \times 99 990001 \times 9901 \times 101 \times 10,000, 999,999 ,989,998, 989,999 ,010,001, 010,000, 999,999 ,989,999##
##10^{78}-1 = 900,900, 900,900, 990,990, 990,991 \times 1 ,109,999, 999,999, 889,000, 000,000, 000,000 ,000,000 ,001,109, 999,999 ,999,889##
The numbers get too large for an exhaustive search, but two larger examples:
##10^{93}-1 = 900,900,900,900,900,900,900,900,900,900,990,990,990,990,990,990,990,990,990,991 \times 1,109,999,999,999,999,999,999,999,999,999,889##
##10^{196}-1 = 999,999,999,999,990,000,000,000,000,099,999,999,999,999,000,000,000,000,009,999,999,999,999,900,000,000,000,001 \times 900,900,900,900,990,990,990,991 \times 11,099, 999,999 ,999,000 ,999,999 ,999,988, 900,000, 000,011 ,099,999, 999,999, 000,999, 999,999 ,988,900 ,000,000, 011,099 ,999,999##
In each case all factors apart from the last one are prime numbers.
Is this for real?
[And I was wondering why my knowledge was incomplete! Seems I found what was missing! ... :biggrin::smile:]
mfb said:
You can check them with WolframAlpha or Dario Alpern's tool (which I used for factorization).
I got the idea from unique primes: If a prime is a unique prime with a period length p, then it is the largest factor of 10p-1.
Thanks for the tips.
I am beginning to see the mechanism now
TIL that Canada has a "digitize stuff*" website, and recently just added a ton of stuff.
The site is called Canadiana and is "run" by CRKN - "The Canadian Research Knowledge Network is a partnership of Canadian universities, dedicated to expanding digital content for the academic research and teaching enterprise in Canada."
