Tolman-Oppenheimer-Volkoff equation
  • Level: Graduate
  • Thread starter Thread starter Orion1
64 replies · 25K views · last reply
Orion1
I attempted to derive the TOV equation in modern physics notation, however my equation solution does not seem to match the equation solution derived by Tolman, Oppenheimer and Volkoff. (ref.1)
Also, the equation solution listed in (ref. 1) does not match the equation solution listed on Wikipedia, which listed (ref. 1) as the source of the equation. The TOV equation listed in (ref. 1) does not contain the 'mass function' listed on the Wikipedia page (ref. 2).
The (ref. 1) paper describes how the TOV equation was derived:
[itex]\tag{3} 8 \pi P(r) = e^{- \lambda} \left( \frac{1}{r} \frac{d \nu}{dr} + \frac{1}{r^2} \right) - \frac{1}{r^2}[/itex]
[itex]\tag{8} e^{-\lambda} = r(r - 2u)[/itex]
[itex]\tag{5} \frac{d \nu}{dr} = \frac{2}{P(r) + \rho(r) c^2} \left( \frac{dP}{dr} \right)[/itex]
In Eq. (3) replace [itex]e^{- \lambda}[/itex] by its value from (8) and [itex]\nu '[/itex] by its value from (5). It becomes:
Solve for: [itex]\frac{dP}{dr}[/itex]
[itex]\tag{10} \frac{dP}{dr} = - (P(r) + \rho(r) c^2) [4 \pi r^3 P(r) + u] [r(r - 2u)]^{-1}[/itex]
And here is my first attempt to derive the TOV equation:
[itex]8 \pi P(r) = e^{- \lambda} \left(\frac{1}{r} \frac{d \nu}{dr} + \frac{1}{r^2} \right) - \frac{1}{r^2}[/itex]
Identity:
[itex]e^{-\lambda} = r(r - 2u) = 1 - \frac{2u}{r} = r(r - r_s) = 1 - \frac{r_s}{r}[/itex]
[itex]\boxed{u = \frac{r_s}{2}}[/itex]
[itex]\boxed{e^{-\lambda} = r(r - r_s)}[/itex]
[itex]u(r) = \frac{1}{2} r(1 - e^{-\lambda})[/itex]
[itex]e^{-\lambda} = r(r - 2u)[/itex]
[itex]\frac{d \nu}{dr} = \frac{2}{P(r) + \rho(r) c^2} \left( \frac{dP}{dr} \right)[/itex]
This is my first attempt to derive this equation.
Integration by substitution:
[itex]8 \pi P(r) = - ( r (r - 2u) ) ( ( \frac{2}{P(r) + \rho (r) c^2} ) ( \frac{dP}{dr} ) \frac{1}{r} + \frac{1}{r^2} ) - \frac{1}{r^2}[/itex]
My equation solution:
[itex]\boxed{\frac{dP}{dr} = -(P(r) + \rho(r) c^2) \frac{r}{2} [(8 \pi P(r) + \frac{1}{r^2})[r(r - 2u)]^{-1} - \frac{1}{r^2}]}[/itex]
TOV equation solution: ref. 1
[itex]\frac{dP}{dr} = - (P(r) + \rho(r) c^2) [4 \pi r^3 P(r) + u] [r(r - 2u)]^{-1}[/itex]
TOV equation solution: ref. 2
[itex]\frac{dP}{dr} = - \frac{G}{r^2} [\rho(r) + \frac{P(r)}{c^2}][m(r) + 4 \pi r^3 \frac{P(r)}{c^2}][r(r - r_s)]^{-1}[/itex]
[/Color]
Reference:
http://home.comcast.net/~lambo1826/download/PHRVAO_55_4_374_1.pdf"
http://en.wikipedia.org/wiki/Tolman-Oppenheimer-Volkoff_equation"
Astronomy news on Phys.org
If the the stated equation solutions are equivalent, then the mass term in ref. 2 must have originated form the first 'u' term:
[itex](P(r) + \rho(r) c^2) [4 \pi r^3 P(r) + u] = \frac{G}{r^2} [\rho(r) + \frac{P(r)}{c^2}][m(r) + 4 \pi r^3 \frac{P(r)}{c^2}][/itex]
Factoring out [itex]c^2[/itex] from the LHS results in:
[itex]c^2 (\frac{P(r)}{c^2} + \rho(r)) [4 \pi r^3 \frac{P(r)}{c^2} + \frac{u}{c^2}] = \frac{G}{r^2} [\rho(r) + \frac{P(r)}{c^2}][m(r) + 4 \pi r^3 \frac{P(r)}{c^2}][/itex]
Eliminate terms:
[itex]c^2 [4 \pi r^3 \frac{P(r)}{c^2} + \frac{u}{c^2}] = \frac{G}{r^2} [m(r) + 4 \pi r^3 \frac{P(r)}{c^2}][/itex]
Solve for u:
[itex]4 \pi r^3 \frac{P(r)}{c^2} + \frac{u}{c^2} = \frac{G}{c^2 r^2} [m(r) + 4 \pi r^3 \frac{P(r)}{c^2}][/itex]
[itex]\frac{u}{c^2} = \frac{G}{c^2 r^2} [m(r) + 4 \pi r^3 \frac{P(r)}{c^2}] - 4 \pi r^3 \frac{P(r)}{c^2}[/itex]
[itex]u = c^2 [(\frac{G m(r)}{c^2 r^2} + 4 \pi G r^3 \frac{P(r)}{r^2 c^4}) - 4 \pi r^3 \frac{P(r)}{c^2}][/itex]
[itex]u = \frac{G m(r)}{r^2} + 4 \pi G r^3 \frac{P(r)}{r^2 c^2} - 4 \pi r^3 P(r)[/itex]
[/Color]
[itex]\boxed{u = \frac{G m(r)}{r^2} + 4 \pi r^3 P(r) \left(1 - \frac{G}{r^2 c^2} \right)}[/itex]
Is this equation solution correct?
[/Color]
Still working through it, but equation 8 should be
[tex]\tag{8} e^{-\lambda} = r^{-1}(r - 2u)[/tex]
so check the equations after that.
I have not located a Mathematica command that can factor identities:
[itex]1 - \frac{2u}{r} = r^{-1} (r - 2u)[/itex]
[itex]\tag{8} \boxed{e^{-\lambda} = r^{-1}(r - 2u)}[/itex]
Affirmative that is correct.
[itex]e^{-\lambda}[/itex] is a variable in the Schwarzschild metric and I calculate it has dimensionless SI units.
Identity:
[itex]\boxed{e^{-\lambda} = r^{-1} (r - 2u) = 1 - \frac{2u}{r} = r^{-1}(r - r_s) = 1 - \frac{r_s}{r}}[/itex]
[itex]8 \pi P(r) = - [ r^{-1} (r - 2u) ] \left[ \left( \frac{2}{P(r) + \rho (r) c^2} \right) \left( \frac{dP}{dr} \right) \frac{1}{r} + \frac{1}{r^2} \right] - \frac{1}{r^2}[/itex]
[itex]\boxed{\frac{dP}{dr} = -(P(r) + \rho(r) c^2) \frac{r}{2} \left[ \left(8 \pi P(r) + \frac{1}{r^2} \right) r [r - 2u]^{-1} - \frac{1}{r^2} \right]}[/itex]
Mathematic 6 solution: (at this point)
[itex]\boxed{\frac{dP}{dr} = -(P(r) + \rho(r) c^2)(r + 4 \pi r^3 P(r) - u)[r(r - 2u)]^{-1}}[/itex]
[itex]\frac{dP}{dr} = - (P(r) + \rho(r) c^2) (4 \pi r^3 P(r) + u) [r(r - 2u)]^{-1}[/itex]
[itex]\frac{dP}{dr} = - \frac{G}{r^2} \left(\rho(r) + \frac{P(r)}{c^2} \right) \left(m(r) + 4 \pi r^3 \frac{P(r)}{c^2} \right) [r(r - r_s)]^{-1}[/itex]
[/Color]
Reference:
http://en.wikipedia.org/wiki/SI"
http://en.wikipedia.org/wiki/Schwarzschild_metric"
Identity?:
[itex]\frac{r}{2} \left[ \left(8 \pi P(r) + \frac{1}{r^2} \right) r [r - 2u]^{-1} - \frac{1}{r^2} \right]} = (r + 4 \pi r^3 P(r) - u)[r(r - 2u)]^{-1}}[/itex]
Mathematica 6 confirms identity as True.
My solution for u:
Mathematica 6 solution for u: (ref. 1 = ref. 2)
[itex]u = \frac{4 c^4 \pi P(r) r^5+c^4 r^3-4 G \pi P(r) r^3-c^2 G m(r)}{c^4 r^2}[/itex]
[/Color]
My solution for u:
[itex]u = \frac{G m(r)}{c^2 r^2} + \frac{4 \pi G r P(r)}{c^4} - 4 \pi r^3 P(r)[/itex]
[itex]\boxed{u = \frac{G m(r)}{c^2 r^2} + 4 \pi r^3 P(r) \left( 1 - \frac{G}{r^2 c^4} \right)}[/itex]
[itex]\boxed{u = \frac{4 c^4 \pi P(r) r^5+c^4 r^3-4 G \pi P(r) r^3-c^2 G m(r)}{c^4 r^2}}[/itex]
[/Color]
[itex]u = \frac{r_s}{2} = \frac{G m(r)}{c^2}[/itex]
[itex]\boxed{u = \frac{G m(r)}{c^2}}[/itex]
[itex]\boxed{\frac{dP}{dr} = -(P(r) + \rho(r) c^2) \left(r + 4 \pi r^3 P(r) - \frac{G m(r)}{c^2} \right) \left[ r \left( r - \frac{2G m(r)}{c^2} \right) \right]^{-1}}[/itex]
[/Color]
[itex]8 \pi P(r) = [ r^{-1} (r - 2u) ] \left[ \left( \frac{2}{P(r) + \rho (r) c^2} \right) \left( \frac{dP}{dr} \right) \frac{1}{r} + \frac{1}{r^2} \right] - \frac{1}{r^2}[/itex]
My identity:
[itex]\boxed{\frac{r}{2} \left[ \left(8 \pi P(r) + \frac{1}{r^2} \right) r [r - 2u]^{-1} - \frac{1}{r^2} \right] = (4 \pi r^3 P(r) + u)[r(r - 2u)]^{-1}}}[/itex]
[itex]\boxed{\frac{dP}{dr} = -(P(r) + \rho(r) c^2)(4 \pi r^3 P(r) + u)[r(r - 2u)]^{-1}}[/itex]
[itex]\boxed{\frac{dP}{dr} = -(P(r) + \rho(r) c^2) \left(4 \pi r^3 P(r) + \frac{G m(r)}{c^2} \right) \left[ r \left( r - \frac{2G m(r)}{c^2} \right) \right]^{-1}}[/itex]
Unresolved issues at this point:
Mathematica 6 functionally confirms 'my identity' as True, however symbolic proof unresolved.
TOV equation solution: ref. 2 listed in Wikipedia is incorrect.
[/Color]
[itex]\frac{dP}{dr} = - \frac{G}{r^2} \left( \rho(r) + \frac{P(r)}{c^2} \right) \left(m(r) + 4 \pi r^3 \frac{P(r)}{c^2} \right) \left( \frac{1}{r(r - r_s)} \right)[/itex]
[itex]\frac{dF}{dL^2 \cdot dL} = \frac{dF \cdot dL^2}{dm^2 \cdot dL^2} \left( \frac{dm}{dL^3} + \frac{dF \cdot dt^2}{dL^2 \cdot dL^2} \right) \left(dm + \frac{dL^3 \cdot dF \cdot dt^2}{dL^2 \cdot dL^2} \right) \frac{1}{dL^2}[/itex]
[itex]\frac{dF}{dL^3} = \frac{dF}{dm^2} \left( \frac{dm}{dL^3} + \frac{dF \cdot dt^2}{dL^4} \right) \left(dm + \frac{dF \cdot dt^2}{dL} \right) \frac{1}{dL^2}[/itex]
[itex]\frac{dF}{dL^3} = \frac{dF \cdot dm}{dm^2 \cdot dL^2} \left( \frac{dm}{dL^3} \right)[/itex]
[itex]\boxed{\frac{dF}{dL^3} \neq \frac{dF}{dL^5}}[/itex]
[/Color]
Reference:
[itex]\frac{dP}{dr} = -(P(r) + \rho(r) c^2) \left(4 \pi r^3 P(r) + \frac{G m(r)}{c^2} \right) \left[ r \left( r - \frac{2G m(r)}{c^2} \right) \right]^{-1}[/itex]
[itex]\frac{dF}{dL^2 \cdot dL} = \left( \frac{dF}{dL^2} + \frac{dm \cdot dL^2}{dL^3 \cdot dt^2} \right) \left( dL^3 \cdot \frac{dF}{dL^2} + \frac{dF \cdot dL^2 \cdot dm \cdot dt^2}{dm^2 \cdot dL^2} \right) \frac{1}{dL^2}[/itex]
[itex]\frac{dF}{dL^3} = \left( \frac{dF}{dL^2} \right) \left(dF \cdot dL + \frac{dF \cdot dt^2}{dm} \right) \frac{1}{dL^2}[/itex]
[itex]\frac{dF}{dL^3} = \frac{dF}{dL^4} \left( dF \cdot dL \right)[/itex]
Unknown extra force derivative:
[itex]\boxed{\frac{dF}{dL^3} \neq \frac{dF^2}{dL^3}}[/itex]
[/Color]
Well there is a problem right here
specifically
[itex](4 \pi r^3 P(r) + u)[/itex]
because u is dimensionless per equation (8) of Oppenheimer-Volkoff paper.
and r3P(r) has units of energy! Pressure = F/L2 = FL/L3 = energy density, where F = force = ML/T2, and Energy = Force*L.
In the Oppenheimer-Volkoff paper, I believe there is an error in equation (1), actually an omission.
ds2 = . . . . + [itex]e^{\nu}dt^2[/itex].
I believe it should be
ds2 = . . . . + [itex]e^{\nu}\,c^2\,dt^2[/itex] so that it is dimensionally correct. That is more or less the form in the Wikipedia article on TOV.
Also, in the Oppenheimer-Volkoff paper.
Also, one must be careful between the Wikipedia article and the original OV paper.
In the OV paper, in the text following OV equation (2), it states that [itex]\rho(r)[/itex] is the macroscopic energy density, and not the mass density, although energy density is related to mass density * c2. So this [(P(r) + \rho(r) c^2)] could be problematic.
Also is [r(r - 2u)]^{-1} correct? Remember [tex]\tag{8} e^{-\lambda} = r^{-1}(r - 2u)[/tex]
One has to be careful of units, consistency of terms and errors or omissions in the literature!
The [itex][r(r - 2u)]^{-1}[/itex] term originates algebraically from 'my identity' equation which is solved symbolically in reference. 1 link below and by Mathematica 6:
'My identity':
[itex]\frac{r}{2} \left[ \left(8 \pi P(r) + \frac{1}{r^2} \right) e^{\lambda} - \frac{1}{r^2} \right] = \frac{4 \pi r^3 P(r) + u}{r(r - 2u)}[/itex]
Mathematica 6 solution for [itex]e^{-\lambda}[/itex] based upon 'my identity':
[itex]e^{-\lambda} = \frac{r - 2u}{r}[/itex]
[/Color]
Reference:
https://www.physicsforums.com/showthread.php?p=1692563#post1692563"
The overall SI terminology of of the TOV equation should be:
[itex]\frac{dF}{dL^3} = \left( \frac{dF}{dL^2} \right)(dL) \left( \frac{1}{dL^2} \right)[/itex]
[itex]\boxed{u = dL}[/itex]
Making the SI correction, the equation solution becomes:
[itex]\frac{dP}{dr} = -(P(r) + \rho(r) c^2) \left( \frac{4 \pi r^3 P(r)}{dF} + \frac{G m(r)}{c^2} \right) \left[ r \left( r - \frac{2G m(r)}{c^2} \right) \right]^{-1}[/itex]
[/Color]
The overall SI terminology of of the Wikipedia TOV equation should be:
[itex]\frac{dF}{dL^3} = \left( \frac{dF \cdot dL^2}{dm^2} \right) \left( \frac{dm}{dL^3} \right)(dm) \left( \frac{1}{dL^2} \right)[/itex]
The only known dimensionally functional solution for the Wikipedia TOV equation:
[itex]\boxed{\frac{dP}{dr} = - G \left( \rho(r) + \frac{P(r)}{c^2} \right) \left(m(r) + 4 \pi r^3 \frac{P(r)}{c^2} \right) \left( \frac{1}{r(r - r_s)} \right)}[/itex]
TOV = TOV Wikipedia dimensional identity:
[itex](P(r) + \rho(r) c^2) \left( \frac{4 \pi r^3 P(r)}{dF} + \frac{G m(r)}{c^2} \right) = G \left( \rho(r) + \frac{P(r)}{c^2} \right) \left(m(r) + 4 \pi r^3 \frac{P(r)}{c^2} \right)[/itex]
Mathematica 6 solution for [itex]dF[/itex]:
[itex]\boxed{dF = \frac{c^4}{G}}[/itex]
The TOV equation should be:
[itex]\boxed{\frac{dP}{dr} = -(P(r) + \rho(r) c^2) \left( \frac{4 \pi G r^3 P(r)}{c^4} + \frac{G m(r)}{c^2} \right) \left[ r \left( r - \frac{2G m(r)}{c^2} \right) \right]^{-1}}[/itex]
[/Color]
The TOV equation solution for a Neutron Star:
[itex]\boxed{\frac{dP}{dr} = -(P(r) + \rho(r) c^2) \left( \frac{4 \pi G r^3 P(r)}{c^4} + \frac{r_s}{2} \right) \left[ r \left( r - r_s \right) \right]^{-1}} \; \; \; (r > r_p) \; \; \; r \neq r_p[/itex]
[itex]\boxed{\frac{dP}{dr} = -(P(r) + \rho(r) c^2) \left( \frac{4 \pi G r^3 P(r)}{c^4} + \frac{G m(r)}{c^2} \right) \left[ r \left( r - \frac{2G m(r)}{c^2} \right) \right]^{-1}} \; \; \; (r > r_s) \; \; \; r \neq r_s[/itex]
The TOV equation solution for a Black Hole:
[itex]\boxed{r_s = r_p}[/itex]
[itex]\boxed{u = \frac{r_p}{2}}[/itex]
[itex]\boxed{\frac{dP}{dr} = -(P(r) + \rho(r) c^2) \left( \frac{4 \pi G r^3 P(r)}{c^4} + \frac{r_p}{2} \right) \left[ r \left( r - r_p \right) \right]^{-1}} \; \; \; (r > r_p) \; \; \; r \neq r_p[/itex]
[itex]\boxed{\frac{dP}{dr} = -(P(r) + \rho(r) c^2) \left( \frac{4 \pi G r^3 P(r)}{c^4} + \frac{1}{2} \sqrt{\frac{\hbar G}{c^3}} \right) \left[ r \left( r - \sqrt{\frac{\hbar G}{c^3}} \right) \right]^{-1}} \; \; \; (r > r_p) \; \; \; r \neq r_p[/itex]
[/Color]
I haven't read through the details, but it looks good.
Reflecting on my previous post, the OV paper mentions just before equation (18) that Eqs. (3), (4) and (5) from which (16) and (17) are derived are stated in "relativistic units" which apparently Tolman used. In relativistic units, c = 1, so obviously c2 = 1, and G = 1. So those factors do not show in the equations in the OV paper.
I now suspect that the c2 is in equation 1, but has value 1, so it's not explicitly written. I never like systems that use c = 1, because while they might look nicer, it's easy to make a mistake in derivations.
The Wikipedia article apparently uses SI, so c2 is explicitly used with the mass density, but then [itex]\rho[/itex] is mass density, not energy density.
Planck Sphere surface pressure:
[itex]P_p = \frac{c^7}{4 \pi \hbar G^2}[/itex]
Planck Sphere density:
[itex]\rho_p = \frac{3c^5}{4 \pi \hbar G^2}[/itex]
[itex]\frac{dP}{dr} = - \left[ \frac{c^7}{4 \pi \hbar G^2} + \left( \frac{3c^5}{4 \pi \hbar G^2} \right) c^2 \right] \left( \frac{4 \pi G r^3}{c^4} \left( \frac{c^7}{4 \pi \hbar G^2} \right) + \frac{1}{2} \sqrt{\frac{\hbar G}{c^3}} \right) \left[ r \left( r - \sqrt{\frac{\hbar G}{c^3}} \right) \right]^{-1} \; \; \; (r > r_p) \; \; \; r \neq r_p[/itex]
The TOV equation solution for a Planck singularity:
[itex]\frac{dP}{dr} = - \left[ \frac{c^7}{4 \pi \hbar G^2} + \frac{3c^7}{4 \pi \hbar G^2} \right] \left( \frac{c^3 r^3}{\hbar G} + \frac{1}{2} \sqrt{\frac{\hbar G}{c^3}} \right) \left[ r \left( r - \sqrt{\frac{\hbar G}{c^3}} \right) \right]^{-1} \; \; \; (r > r_p) \; \; \; r \neq r_p[/itex]
[itex]\boxed{\frac{dP}{dr} = - \frac{c^7}{\pi \hbar G^2} \left( \frac{c^3 r^3}{\hbar G} + \frac{1}{2} \sqrt{\frac{\hbar G}{c^3}} \right) \left[ r \left( r - \sqrt{\frac{\hbar G}{c^3}} \right) \right]^{-1}} \; \; \; (r > r_p) \; \; \; r \neq r_p[/itex]
These equations predict 2 explosion types:
When a Neutron Star collapses into a Black Hole.
When a Black Hole collapses into a Planck singularity.
[/Color]
In post #18 eq. 2, the limiting values should be: (30 min. PF edit limit)
[itex]r > r_s \; \; \; r \neq r_s[/itex]
[/Color]
Reference:
http://en.wikipedia.org/wiki/Planck_pressure"
http://en.wikipedia.org/wiki/Planck_density"
According to Wikipedia (ref. 1, para. 2 listed below),
Wikipedia said:
the pressure exerted by degenerate matter depends only weakly on its temperature. In particular, the pressure remains nonzero even at absolute zero temperature.
Adiabatic indexes:
Low pressure fully degenerate Fermi gas:
[tex]\gamma = \frac{5}{3}[/tex]
High density quantum state relativistic degenerate Fermi gas:
[tex]\gamma = \frac{4}{3}[/tex]
Polytropic degenerate Fermi gas pressure equation:
[tex]P(r) = K \rho(r)^{\gamma}[/tex]
[tex]K[/tex] - particle gas properties constant
[tex]K = \frac{P(r)}{\rho(r)^{\gamma}} = \left( \frac{dF}{dL^2} \right) \cdot \left( \frac{dL^3}{dm} \right) = \frac{dF \cdot dL}{dm}[/tex]
[tex]\boxed{K = \frac{dF \cdot dL}{dm}}[/tex]
[tex]\boxed{\frac{dP}{dr} = -(P(r) + \rho(r) c^2) \left( \frac{4 \pi G r^3 P(r)}{c^4} + \frac{G m(r)}{c^2} \right) \left[ r \left( r - \frac{2G m(r)}{c^2} \right) \right]^{-1}}[/tex]
[tex]\frac{dP}{dr} = -(K \rho(r)^{\gamma} + \rho(r) c^2) \left( \frac{4 \pi G r^3 (K \rho(r)^{\gamma})}{c^4} + \frac{G m(r)}{c^2} \right) \left[ r \left( r - \frac{2G m(r)}{c^2} \right) \right]^{-1}}[/tex]
Polytropic degenerate Fermi gas pressure TOV equation:
[tex]\boxed{\frac{dP}{dr} = -(K \rho(r)^{\gamma} + \rho(r) c^2) \left( \frac{4 \pi G K r^3 \rho(r)^{\gamma}}{c^4} + \frac{G m(r)}{c^2} \right) \left[ r \left( r - \frac{2G m(r)}{c^2} \right) \right]^{-1}}}[/tex]
[/Color]
The Adiabatic indexes for a degenerate Fermi gas are listed in Wikipedia (ref. 1), however not yet listed on Wikipedia (ref. 2 ) below.
[/Color]
Reference:
http://en.wikipedia.org/wiki/Degenerate_matter"
http://en.wikipedia.org/wiki/Heat_capacity_ratio"
According to PHYS 390 Lecture 19, the degenerate Fermi gas pressure of spin 1/2 particles is:
[tex]P(r) = \frac{\pi^3 \hbar^2}{15 m_n} \left( \frac{3N(r)}{\pi V(r)} \right)^{\frac{5}{3}}[/tex]
Number density:
[tex]n(r) = \frac{N(r)}{V(r)} = \frac{\rho(r)}{m_n}[/tex]
[tex]m_n[/tex] - neutron mass
[tex]P(r) = \frac{\pi^3 \hbar^2}{15 m_n} \left[ \frac{3}{\pi} \left( \frac{\rho(r)}{m_n} \right)\right]^{\gamma} = \frac{\pi^3 \hbar^2}{15 m_n} \left( \frac{3}{\pi m_n} \right)^{\gamma} \rho(r)^{\gamma} = K \rho(r)^{\gamma}[/tex]
[tex]\boxed{P(r) = \frac{\pi^3 \hbar^2}{15 m_n} \left( \frac{3}{\pi m_n} \right)^{\gamma} \rho(r)^{\gamma}}[/tex]
[tex]\boxed{K = \frac{\pi^3 \hbar^2}{15 m_n} \left( \frac{3}{\pi m_n} \right)^{\gamma}}[/tex]
However, I failed to resolve the SI derivation for the pressure equation:
[tex]\frac{dF}{dL^2} = \left( \frac{dE^2 dt^2}{dm} \right) \left( \frac{1}{dm} \right) \left( \frac{dm}{dL^3} \right) = \left( \frac{dE^2 dt^2}{dm \cdot dL^3} \right)[/tex]
[/Color]
Reference:
http://www.sfu.ca/~boal/385lecs/385lec19.pdf"
SI derivation for the PHYS 390 Lecture 19 pressure equation:
[tex]\frac{dF}{dL^2} = \left( \frac{dE^2 dt^2}{dm \cdot dL^5} \right) = \left( \frac{dF^2 dL^2 dt^2}{dm \cdot dL^5} \right)[/tex]
[tex]\frac{dF}{dL^2} = \frac{dF^2 dt^2}{dm \cdot dL^3}[/tex]
Newton's second law:
[tex]\boxed{dF = \frac{dm \cdot dL}{dt^2}}[/tex]
According to this solution, the PHYS 390 Lecture 19 pressure equation is correct:
[tex]P(r) = \frac{\pi^3 \hbar^2}{15 m_n} \left( \frac{3N(r)}{\pi V(r)} \right)^{\frac{5}{3}} \; \; \; \gamma = \frac{5}{3}[/tex]
[/Color]
Reference:
http://en.wikipedia.org/wiki/Force"
http://www.sfu.ca/~boal/385lecs/385lec18.pdf"
According to my SI derivations, the PHYS 390 Lecture 19 pressure equation is only valid for an Adiabatic index of [tex]\gamma = \frac{5}{3}[/tex]
[tex]\frac{dF}{dL^2} \neq \left( \frac{dE^2 dt^2}{dm} \right) \left( \frac{1}{dm} \right) \left( \frac{dm}{dL^3} \right) = \left( \frac{dE^2 dt^2}{dm \cdot dL^3} \right) \; \; \; \gamma = 1[/tex]
[tex]\frac{dF}{dL^2} = \left( \frac{dE^2 dt^2}{dm \cdot dL^{3 \gamma}} \right) = \left( \frac{dF^2 dL^2 dt^2}{dm \cdot dL^5} \right)\; \; \; \gamma = \frac{5}{3}[/tex]
[tex]\frac{dF}{dL^2} \neq \left( \frac{dE^2 dt^2}{dm \cdot dL^{3 \gamma}} \right) = \left( \frac{dF^2 dL^2 dt^2}{dm \cdot dL^4} \right)\; \; \; \gamma = \frac{4}{3}[/tex]
[/Color]
According to Wikipedia ref. 1 listed below, the equation for Fermi energy is:
Fermi energy equation:
[tex]E_f = \frac{\hbar^2}{2m_n} \left( \frac{3 \pi^2 N}{V} \right)^{2/3}[/tex]
Fermi pressure:
[tex]P_f = - \frac{dE_f}{dV_f}[/tex]
[tex]P_f = - \frac{\hbar^2}{2m_n} \left( \frac{3 \pi^2 N_f}{V_f} \right)^{2/3} \frac{1}{V_f} = - \frac{\hbar^2}{2m_n} \left( 3 \pi^2 N \right)^{2/3} \frac{1}{V_f^{\frac{5}{3}}} = K \rho_f^{\frac{2}{3}}[/tex]
[tex]\boxed{P_f = - \frac{\hbar^2}{2m_n} \left( 3 \pi^2 N_f \right)^{2/3} \frac{1}{V_f^{\frac{5}{3}}}}[/tex]
[/Color]
Reference:
http://en.wikipedia.org/wiki/Fermi_energy"
In the polytropic equation of state. the constant K is called " the entropy constant " in some literature. You have called it " the particle gas properties constant".
According to Wikipedia ref. 1, para. 3 listed below:
Wikipedia said:
...where K depends on the properties of the particles making up the gas.
Wikipedia said:
where K' again depends on the properties of the particles making up the gas.
Greetings, Helios
Thanks for your important collaboration and correction.
That constant was copied from the Wikipedia ref.1, para. 3 paragraph which does not implicitly declare a key definition which states the SI name for that constant, however it does describe it twice in the same paragraph!
The Wikipedia ref. 1, still requires a lot of work with better, more implicitly written definition keys and definitional equations with more extensive referencing.
According to Wikipedia ref. 2, section 'Entropy in Astrophysics':
Wikipedia said:
In astrophysics, what is referred to as "entropy" is actually the adiabatic constant derived as follows.
[tex]PV^{\gamma} = \text{constant} = K[/tex]
Wikipedia said:
This equation is known as an expression for the adiabatic constant, K, also called the adiabat.
[tex]K[/tex] - adiabatic constant, K, also called the adiabat.
[tex]P = \frac{\rho k_{B}T}{\mu m_{H}}[/tex]
[tex]\boxed{K = \frac{k_{B}T}{\mu m_{H} \rho^{2/3}}}[/tex]
Is the adiabatic constant also called the 'entropy constant' in other literature?
Wikipedia said:
Substituting this into the above equation along with V = [grams] / ρ and γ = 5 / 3 for an ideal monoatomic gas
[tex]PV^{\gamma} = K[/tex]
[tex]\gamma = \frac{5}{3}[/tex] - ideal monoatomic gas
[tex]V = \frac{dm}{\rho}[/tex]
[tex]K = \left( \frac{\rho k_{B}T}{\mu m_{H}} \right) \left( \frac{dm}{\rho} \right)^{\gamma} = \left( \frac{k_{B} dm^{\gamma}}{\mu m_{H}} \right) T \rho^{1 - \gamma}[/tex]
[tex]dm = m_H[/tex]
Identities:
[tex]\frac{\rho}{\rho^{\gamma}} = \rho^{1 - \gamma}[/tex]
[tex]\frac{m_H^{\gamma}}{m_H} = m_H^{\gamma - 1}[/tex]
The adiabatic constant:
[tex]\boxed{K = \left( \frac{k_{B} dm_H^{\gamma - 1} }{\mu} \right) T \rho^{1 - \gamma}}[/tex]
[/Color]
Reference:
http://en.wikipedia.org/wiki/Entropy"
Standard SI derivation:
[tex]K = \frac{dE \cdot dm^{\gamma - 1}}{dT} \cdot \frac{amn}{amu} \cdot dT \left( \frac{dm}{dL^3} \right)^{1 - \gamma} = \frac{dE}{dL^{3(1 - \gamma)}} \cdot \frac{amn}{amu}[/tex]
[tex]\boxed{K = \frac{dE}{dL^{3(1 - \gamma)}} \cdot \frac{amn}{amu}}[/tex]
[/Color]
Yes, an adiabat is a curve of constant entropy on the P-V diagram. The adiabats are isentropic and the " entropy constant " is the value for one adiabat.
Fermi pressure:
Integration by differentiation substitution:
[tex]P_f = - \frac{\hbar^2}{2m_n} \left( 3 \pi^2 N_f \right)^{2/3} \left( \frac{V^{- \frac{2}{3}}}{dV} \right)[/tex]
Differentiation identity:
[tex]\frac{V^{-n}}{dV} = -n V^{-n - 1} = \left(-\frac{2}{3} \right) V^{-\frac{2}{3} - \frac{3}{3}} = \left(- \frac{2}{3} \right) V^{-\frac{5}{3}}[/tex]
[tex]P_f = - \left(- \frac{2}{3} \right) \frac{\hbar^2}{2m_n} \left( 3 \pi^2 N \right)^{2/3} \frac{1}{V_f^{\frac{5}{3}}} = \frac{2 \hbar^2}{6 m_n} \left( 3 \pi^2 N \right)^{2/3} \frac{1}{V_f^{\frac{5}{3}}}[/tex]
[tex]\boxed{P_f = \frac{\hbar^2}{3 m_n} \left( 3 \pi^2 N \right)^{2/3} \frac{1}{V_f^{\frac{5}{3}}}}[/tex]
[/Color]
Post #25 requires integration by differentiation substitution.
[/Color]
Reference:
