Tone Generator Connected To Speaker
  • Thread starter Thread starter SMD1990
    Generator Speaker
The discussion centers on creating a tone-generating circuit using an MPS2222A transistor, capacitors, and inductors. The user initially attempted to connect an LC circuit directly to a speaker but failed to produce sound. After researching Hartley and Colpitts circuits, they sought assistance in building a functional circuit. A suggested circuit utilizes both NPN and PNP transistors, operates at approximately 140 Hz, and can be adjusted by changing the resistor and capacitor values.
  • Understanding of basic electrical engineering concepts
  • Familiarity with transistor types, specifically NPN and PNP
  • Knowledge of LC circuits and their components
  • Experience with circuit assembly and troubleshooting
  • Research Hartley and Colpitts oscillator designs
  • Learn about signal amplification techniques for audio circuits
  • Explore the characteristics and applications of the MPS2222A transistor
  • Investigate the effects of varying resistance and capacitance on oscillation frequency
Electronics enthusiasts, hobbyists in electrical engineering, and individuals interested in building audio circuits will benefit from this discussion.
SMD1990
First, let me just say that I am very new to electrical engineering. It is something that I started teaching myself mere months ago. So, basically, it is probably best that you guys assume I know nothing.
As I have expanded my knowledge, I have built some little things. For instance, an LED light, an electro-static (Van de Graaff) generator, a "brushless" DC motor, et cetera...
Most recently, I have been trying to make a little tone-generating circuit. I originally thought I could just connect an LC circuit to a speaker, and run a current through it. Upon researching why that did not work, I came across Hartley and Colpitts circuits, both of which used a transistor to keep the oscillations going.
So, I got a transistor. Still, no tone. I have tried numerous simple circuits that I have seen online. Any tones should have been within the audible range. Yet, I have heard none.
Thinking I might need to amplify the signal, I have tried connecting some of my circuits to the Line In on my computer, rather than directly to a speaker. Typically when connecting to Line In, I would get my power directly from one of my computer's 5V connectors. Such seemed easier than using a battery.
Basically, I was wondering if you guys could show me a circuit that should work. Maybe then I can figure out what I am doing wrong...
I currently have two capacitors of 10 µF each and one that is 470 µF. My three inductors are each 100 µH. I also have an MPS2222A transistor and a plethora of 1/4 W resistors.
I appreciate any help you guys can give me! Thanks!
I have a small circuit which makes a surprising level of noise in a speaker.
It needs an NPN and a PNP transistor and this means you have to be careful about which leads go where.
[PLAIN]http://dl.dropbox.com/u/4222062/NPN%20PNP%20OSC.PNG
This has the waveform shown, so it sounds a bit rough, but it will certainly make some noise. It runs off a 1.5 volt battery and is OK for such things as a door buzzer.
The speaker is shown as an 8 ohm resistor in the circuit.
As it stands, it would oscillate at about 140 Hz, but this could be changed by varying the 100 K and the 0.1 uF capacitor.
It is possible that your oscillator was not oscillating. An LC oscillator has to have components whose reactances were carefully selected.
Most likely this can only be answered by an "old timer". I am making measurements on an uA709 op amp (metal can). I would like to calculate the frequency rolloff curves (I can measure them). I assume the compensation is via the miller effect. To do the calculations I would need to know the gain of the transistors and the effective resistance seen at the compensation terminals, not including the values I put there. Anyone know those values?
  • · Replies 19 ·
12K
