rashidahwazia
- 9
Hi all,
My team is developing a Ticket vending machine. in this machine the tickets are rolled on rollers and are made from paper(not regular paper but thicker ones). This ticket goes into the ticket printer and at the first stage it is cut into the required size with use of a cutter in the printer and then the information is written on it and then it is dropped out of the printer.
The case is every morning there will be some tickets which are cut short and are stuck inside the printer or are not completely dropped out and are stuck at the final gripper of the printer.
since here is SOOO humid, so we believe that this problem is mostly because of humidity since it mostly happens in early mornings or rainy days.
Please give me your feedback on what you think the reason of this problem is.
Also if you also think that this is because of the humidity please inform me what solutions you suggest,
actually I have used a type of humidity absorber in the machine but after a day it was full of water and it is impossible for us to change it every day and I don't think it had any effects cause the problem happened again.
Thank you in advance for your help
