Torque Calculation - Not a basic application
  • Context: High School
  • Thread starter Thread starter TeeBeeCee
37 replies · 4K views
TeeBeeCee
TL;DR
How to calculate torque on a rotating gear driven by a hydraulic ram.
Please disregard this post if this forum is only academia related. This is a real word physics question.
I work in a hydraulic cylinder repair shop. I have a hydraulic machine that can tighten and loosen bolts and nuts with a lot of torque. When tightening, it is important to know how many foot/pounds of torque was used.
Here is how the machine works. A hydraulic ram pushes on the circumference of a cog that has a socket in the center. The hydraulic ram has a 4” diameter piston. So the surface area of the piston is about 13 square inches.
Assuming the ram is pushed with 100 PSI of force, what is the torque delivered to the socket? Does the cog provide additional torque, similar to a lever? Does the angle of the ram engaging with the cog affect the torque? What additional information do you need to provide an accurate answer?
Here is a crude diagram pieced together from clip art. Hopefully it helps to illustrate the problem.
Welcome, TBC!
Do you have a way to use a torque instrument?
Assuming the pressure will not be good, you will need to measure it.
The torque on the nut or bolt will be greater as the distance between the shaft and the center line of the cylinder increases.
Please, see:
https://www.grc.nasa.gov/www/k-12/airplane/torque.html
Building on variables needed to calculate a precise answer, the ram has a maximum stroke length, and as it extends to push the gear, the angle will change as the end of the gears travels in an arc per X degrees of gear rotation. What about the other components of the question? What other information is needed? I was hoping for a formula.
The problem you have is that the required torque is reached at whatever angle the specific bolt or nut assembly reaches maximum clamping force.
As the torque induced by your ram is dependent on that angle (nut and gear), which is different for each case, you will have different values of maximum torque for each case.
If it happens that the center line of the ram is perpendicular to the line joining center of gear and the point at which gear and ram connect, when tightening, you will know how that the maximum foot/pounds of torque (for that pressure) was used.
If not, you will need to know the last angle that the gear reached for each case in order to precisely do the calculation.
Lnewqban said:
Welcome, TBC!
Please, see:
:cool:
No instrument to measure the torque. Isn’t pressure just one of the variables needed? In the example, 100 PSI of hydraulic pressure is applied to a piston area of 13 square inches, which will develop 1,300 ft pounds of force. In the formula T = F x r x sin(theta), it looks like to me like r will change and definitely theta. I ‘m getting hung up on push/pull versus rotational force. We also have the question about the metal cog that is part of the system. Does it have an impact?
I understand.
Please, study concepts shown in link of post 3 above, and come back with more questions.
The triangle I have drawn in here is going to a piece of the puzzle. Can you relate all the variables using trigonometry "Law of Cosines"?
After you get the relationship, there are a few trig identities to apply to find the torque as a function of ##x##. I'll explain the relevant stuff with forces/torques you need to understand along the way.
Keep in mind...I don't know what level of math you are comfortable with... but a "precise" mathematical model requires some knowledge. If you are looking for conceptual, we can help with that too.
If you show honest engagement but can't do the math, I'll give you a formula in the end to play around with.
Why does the machine have a gear if it is not meshing to another one?
Could you take one or two pictures of the machine for us to see?
How much is the stroke of the ram and the center to pivot radius?
##1300 ~\text{lbf}## ( pound force ) not "ft-pounds" (that's torque).
##r## will not change, ##F## would be a constant in magnitude (for the static, non-accelerating, non moving, rod), ##L## shouldn't change. The angle ##\beta## changes as you suspect, and the total length of the cylinder ##x## changes.
The hydraulic ram pushes the gear to generate the rotational force. I will post pictures and measure the stroke tomorrow. For the center to pivot radius, do you mean from the center of the gear to where the end of the ram meets the gear (Post #8 figure, variable r)?
Yes, it was clear in your first posted diagram.
Nevertheless, I would like to know the reason for the teeth (what the gear is meshing with, if anything).
Please, see if you can picture the mechanism at both extreme positions of the stroke.
That is important to properly help you.
Yes, exactly.
Yes, exactly.
Here are the pictures and some additional information. The cylinder stroke is 6 inches. It takes 12 strokes to turn the drum 360 degrees, which is 30 degrees per stroke. At the beginning of the stroke the angle of the cog to the gears on the drum is about 6 degrees. At the end of the stroke it is 4 degrees. My goal is to be able to tighten bolts and nuts to a specific torque specification by applying the appropriate PSI of hydraulic pressure. Hopefully this helps.
*NOTE* Images were too big. Working on that.
Reply
It’s been a while since I’ve done any trigonometry. In looking at your annotation, I understand what the variables are. X will change by 6”, the length of the stroke. The angle will also change. When the rod is fully retracted at the beginning of the stroke, the angle is 6 degrees. At the end of the stroke it is 4 degrees, and of course the angle changes slightly during the stroke.
The rod doesn't engage the pawls until its extended about an inch from what I can tell in the picture-5 inch stroke? If you have drawings of the machine that would be better, its going to be challenging to get accurate measurements of the components assembled as far as I can see. We might be able to infer ##L## and ##r## if your angular measurements of 6 and 4 degrees, and stroke are accurate.
I was thinking the same thing about getting measurements. I don’t have any drawings. I will reach out to the vendor to see if they will send any. In the meantime, I will try to get the best measurements I can. To get the angle of the ram, I used a digital inclination meter.
Reply
From the diagram with the triangle, where is the torque variable? What is the formula to determine the torque given the variables listed?
You have to find the cosine of the angle ##\beta## as a function of ##x##, then the torque ends up being ##\tau = rF\sin\beta##
Is that chain linked to the hydraulic motor?
If so, what those two do?
Reply
My guess is that it is a chuck for the nut.
Yes, once the ram breaks the nut or bolt loose, the hydraulic motor can remove a lot faster (decent rpm). It sacrifices power for speed. It does not play a part in the question.
Reply
It would be very helpful if you provide an example. I really don’t understand the formula you provided.
Let’s say r=16”, beta=6 degrees, I’m lost after that. Sorry, as you can see math is not my strong suit.
##\beta## isn't 6 degrees, it's going to be more in the vicinity of 90 degrees. ##\beta## is the angle between the force and the radial line from the point of contact to the axis of rotation. It quite literally needs to be the angle in the drawing for the formula to work, not just any of them. The force of the cylinder is ##F## and it's directed along the rod.
But I believe you, so I'm not going to bore you with the details of eliminating it mathematically:
$$ \tau = r F \sqrt{ 1- \frac{(L^2-(r^2+x^2))^2}{4r^2x^2} } $$
having the correct ##r## and ##L## are critical to this, and they will be difficult to measure directly on the assembled machine.
I can do some more algebra, and tell you what they could be ( given some reasonable measurement errors ) if you share what angle measures relative to what are 6 and 4 degrees - relative to what exactly.
This is the torque that is being applied to the nut ( from this mechanism - ideally) when this system is in static equilibrium. Meaning, before the nut breaks loose.
If you are really after the tightening spec, I think it would also be the torque a "torque wrench" should measure if everything was moving very slowly, without jerking and the force was constant from the hydraulic cylinder (measure pressure accurately).
If the torque is critical, what current method are you trying to modify by knowing the torque at the machine?
Currently, I use a table of pressure (measured in BAR, not PSI) provided by the vendor of the hydraulic tear down bench. Some torque specs are lower than listed, or are between the values. I need to be able to calculate the amount of hydraulic pressure needed to be able to tighten to any given torque requirement. I have no idea if the information they provided is correct, so I wanted to verify. I’ve included the table below. They use the metric system. Have no idea why the last pressure entry only increased by 15 when all the others were 25.
Table
Pressure (BAR) Torque (NM)
25 4210.87
50 8421.74
75 12632.60
100 16843.47
125 21054.34
150 25265.21
175 29476.07
200 33686.94
225 37897.81
250 42108.68
275 46319.54
300 59530.41
315 53056.93
Table
25 4210.87
50 8421.74
75 12632.60
100 16843.47
125 21054.34
150 25265.21
175 29476.07
200 33686.94
225 37897.81
250 42108.68
275 46319.54
300 59530.41
315 53056.93
Well, if they are giving you table of values they probably tested it. I would stick to the table.
Here is a graph:
The wobbly bit at the end is a bit funny, and likely won't be explained by the equation I gave. Thats experimental. Also, excel is "filling in the blanks" with high order polynomials, so you would need some more data out there to be sure about that. The good news is most of the graph seems linear.
Reply
Steve4Physics said:
Surely the manufacturer must provide a table of pressure vs. torque, so that the operator can look-up the pressure which needs to be set to achieve a particular torque. Or am I missing something?
Yeah, they just posted that.
I know - just missed it. I deleted my post before I saw that you had replied to it!
Reply
Here is a graph:
Was this chart generated from the data table I provided? If so, the point I made was that I have no idea if the data is correct and wanted to verify.
Yeah, it was. I was trying to help you by giving you a formula for the data so you wouldn't have trouble in between values. Is the value at 300 correct, or a typo?
This equation is good for data up to 275 Bar. I just excluded the points at the end. The point at 315 looks like it would fall in line, which is why I asked if the data at 300 was a typo.
Reply
