Torque in Wind Turbines: Calculating Power Output
This discussion focuses on calculating torque and power output in Horizontal Axis Wind Turbines (HAWT) using a Rope Brake Dynamometer setup. The user conducted experiments at a wind speed of 5 m/s, applying incremental loads up to 200 grams, resulting in a maximum RPM of 310. The calculations revealed a torque of 0.00088 Nm and a power output of 0.0304 watts, significantly lower than the available wind power of 9.6125 watts. The low power output indicates inefficiencies in the turbine's design or setup.
  • Understanding of torque calculations in mechanical systems
  • Familiarity with wind turbine mechanics and aerodynamics
  • Knowledge of using a Rope Brake Dynamometer
  • Basic proficiency in using spreadsheets for data analysis
  • Investigate the efficiency of wind turbines and factors affecting it
  • Learn about the principles of torque and power in rotating systems
  • Explore advanced wind turbine design concepts for improved performance
  • Utilize spreadsheet software to analyze and visualize turbine performance data
Engineers, wind turbine designers, and researchers interested in optimizing wind turbine performance and understanding the mechanics of torque and power generation in HAWTs.
sundaravadivel
【 mod note: moved to H/W forum so homework template is absent 】
Dear all
i am trying to calculate torque in HAWT from the measurements using Rope brake dynamometer set up with a blower. i had wound a string over the turbine shaft. The string is connected to a spring balance on its one end and the other end have provisions to add weights.
firstly i'd calculated the turbine free wheeling characteristics ie.. i allowed the turbine rotor to rotate due to blower wind (5m/s) and i applied load in steps of 10 gm and correspondingly I've noted the RPM (310 RPM). When a particular load is reached (200 grams) , the turbine shaft, does not able to overcome the load and stop its rotation. The blade length is 20 cm (0.2 m).
The swept area = pi*r (squared) = 3.14*0.2*0.2 = 0.1256 m squared.
Power available in wind is = 1/2 rho A V cubed= 0.5*1.225*5*5*5 = 9.6125 watts
from the measurements i got
torque = (load - spring bal. reading)*9.81*(radius of shaft +radius of rope)
torque (Nm) = (0.01-0.001)*9.81*0.011 = 0.00088Nm
power produced = torque *angular velocity=0.00088*31.34= 0.0304 watts
The power produced is very much lower than power available (Cp is very low). where i am going wrong,,any one please help...
Your equation seems OK but...
Have a think about the expected efficiency of a turbine that has no load (or a very small load).
Work the numbers for the other data points and see what you get. I'd use a spreadsheet so you can plot some graphs later.
46K
  • · Replies 72 ·
11K
