Torque Rquired for stages of motion
  • Thread starter Thread starter Bikerz
    Motion Torque
The discussion focuses on calculating the torque required for a swing bridge's three stages of motion, including acceleration, constant velocity, and deceleration. The motor must swing the bridge through 90 degrees in 120 seconds, with the bridge accelerating uniformly for 40 seconds, moving at constant velocity, and then decelerating in the final 20 seconds. Participants discuss using equations related to angular acceleration and velocity, while addressing the moment of inertia and a resisting torque value. Clarifications were made regarding the correct interpretation of the resisting torque, which was confirmed to be 3 kNm instead of 3 kN. The conversation concludes with the original poster resolving their confusion after consulting with their lecturer.
Bikerz
The fuel storage yard is separated from the main plate by a swingbridge (swinging in a horizontal plane). The motor driving the briudge has to swing through an angle of 90degrees in 120seconds. The bridge accelerates uniformly for 40s then moves at a constant velocity, decelerating uniformly to rest in the final 20 s. The rotaing components of the bride have an equivalent moment of inertia of 400kgm² and feels a constand resisting torque of 3kN,. Find Torque of 3 stages of montion?
How do I go about this?
Which equations should I be using?
Torque = Inertia x Angular acceleration
Angular Velocity = Angle/dt (Time I presume)
I have done
sa=((V+0)/2)40=20V
sb=((V+V)/2)60=60V
sc=((0+V)/2)20=10V
I could then do
W=dØ/dt
Then times by Inertia (400)
I get
a-200N
b-400N
c=200N
This seems too easy and whast the resisting torque value for? Do I just add this to part a, ignor for part b and take off for part c?
Tho I'd get a negitive vale for c then?
Cheers
Sheldon
You can use the fundamental kinematics equations to develop an expression for the total rotation angle of the swing bridge, then solve for alpha1, the angular acceleration during stage 1. Once you obtain alpha1 and alpha3, you can compute the applied torque of the three stages. Are you sure your mass moment of inertia and resisting torque given above are correct? After all, 3 kN is not a torque, so what you typed doesn't make sense yet. Try it again. Post a valid attempt to get help.
3kNm. Sorry.
Sent what I did to my lecture and he said it was right and he oppoligsed for teh strange number sin teh question that made me have answers that I thourght must be wrong.
All sorted
Cheers
Thread 'Have I solved this structural engineering equation correctly?'
Hi all, I have a structural engineering book from 1979. I am trying to follow it as best as I can. I have come to a formula that calculates the rotations in radians at the rigid joint that requires an iterative procedure. This equation comes in the form of: $$ x_i = \frac {Q_ih_i + Q_{i+1}h_{i+1}}{4K} + \frac {C}{K}x_{i-1} + \frac {C}{K}x_{i+1} $$ Where: ## Q ## is the horizontal storey shear ## h ## is the storey height ## K = (6G_i + C_i + C_{i+1}) ## ## G = \frac {I_g}{h} ## ## C...
