Torque: Understanding Gear Ratios & Cruise Control
  • Thread starter Thread starter Peetch
    Torque
The discussion focuses on the relationship between torque, gear ratios, and vehicle speed in a simulation context. Higher gear ratios, although smaller, allow for increased speed due to the balance of torque and RPM, which is influenced by throttle position. The power output of an engine varies with throttle position, meaning that torque at the wheels can remain significant even at higher RPMs if the throttle is fully open. Additionally, cruise control maintains speed by adjusting power output based on the required torque, preventing continuous acceleration even at a constant RPM. Understanding these dynamics is crucial for accurate vehicle simulation modeling.
Peetch
I am working on a vehicle simulation and I have calculated the torque to the wheel using engine RPM and the corresponding amount of HP. Then I multiplied that torque by the gear ratios but I do not understand how at a higher gear the ratio is smaller but it is suppose to go faster than the torque provided at a lower gear. I think it has something to do with MOI and the AA but I do not get it please help. Also how does cruse control work if you set your engine to 3000 RPM's and the same amount of torque is being applied to the wheel wouldn't you continue to accelerate?
The power in the drive train at any given moment is the same. The power leaving the engine and going into the gearbox will be the same power that leaves the gearbox (ignore losses in the gearbox), and goes into the drive shaft, but because the speed is changed the torque must change,(power is proportional to torque times speed) same thing happens through the diff.
I think that you are slightly confused about power speed curves for a engine the power quoted at a certain speed is the maximum power, you can run at that speed at a lower power without any problem.
You've made one error and applied it twice. The power output of an engine is not always the same at a given RPM. It varies with throttle position. So applying that back into your first question, torque at the wheel need not be lower at higher rpm. It is if your foot is on the floor and the throttle wide-open, though. So what does that tell you? It tells you your acceleration is better at low speed partly because you are in a lower gear.
Ok so i can be at 3000 RPM's with the throttle fully opened and the engine's power would be ~100 HP but if I am at 3000 RPM's and the throttle only halfway open then the engine's power would be ~50 HP?
I'm sure the relationship between throttle position and power isn't that linear, but yes, you can be at 3000 rpm and practically anywhere between 0-100 hp.
Power (watts) = torque (Newton-meters) x 2π RPM/60
HP = power (watts)/746
An engine could generate 100 HP at 3,000 RPM, but to drive at say 35 MPH (15 meters per second), usually less than 10 HP (7,500 watts) is required.
Bob S
Hello everyone, Consider the problem in which a car is told to travel at 30 km/h for L kilometers and then at 60 km/h for another L kilometers. Next, you are asked to determine the average speed. My question is: although we know that the average speed in this case is the harmonic mean of the two speeds, is it also possible to state that the average speed over this 2L-kilometer stretch can be obtained as a weighted average of the two speeds? Best regards, DaTario
The rope is tied into the person (the load of 200 pounds) and the rope goes up from the person to a fixed pulley and back down to his hands. He hauls the rope to suspend himself in the air. What is the mechanical advantage of the system? The person will indeed only have to lift half of his body weight (roughly 100 pounds) because he now lessened the load by that same amount. This APPEARS to be a 2:1 because he can hold himself with half the force, but my question is: is that mechanical...
Thread 'Beam on an inclined plane'
Hello! I have a question regarding a beam on an inclined plane. I was considering a beam resting on two supports attached to an inclined plane. I was almost sure that the lower support must be more loaded. My imagination about this problem is shown in the picture below. Here is how I wrote the condition of equilibrium forces: $$ \begin{cases} F_{g\parallel}=F_{t1}+F_{t2}, \\ F_{g\perp}=F_{r1}+F_{r2} \end{cases}. $$ On the other hand...
