Total electric field within an inductor
This discussion centers on the application of Kirchhoff's second law in circuits containing inductors and the implications of non-conservative electric fields. The participants explore the relationship between the conservative electric field (\vec{E_{c}}) and the non-conservative electric field (\vec{E_{n}}) within inductors, concluding that the total electric field must be zero despite the presence of charge accumulations. The confusion arises when attempting to apply similar reasoning to a circular loop of wire in a changing magnetic field, where the absence of terminals complicates the understanding of charge accumulation and induced electric fields.
  • Understanding of Kirchhoff's loop rule
  • Familiarity with Faraday's law of electromagnetic induction
  • Knowledge of electric fields and their conservative and non-conservative properties
  • Basic concepts of inductors and their behavior in circuits
  • Study the implications of Faraday's law on induced emf in various circuit configurations
  • Investigate the behavior of electric fields in non-conservative systems
  • Explore the concept of back emf in inductors and its effects on circuit performance
  • Examine case studies involving circular loops of wire in changing magnetic fields
Students and professionals in electrical engineering, physics educators, and anyone interested in deepening their understanding of inductors, electromagnetic induction, and circuit analysis.
epsilonjon
Hi.
I have just started learning about inductors, and this is the method my book uses to show that Kirchhoff's second law is still valid even with inductors in a circuit, and to calculate the voltage drop across an inductor:
"According to Kirchhoff's loop rule, the algebraic sum of the potential differences around any closed circuit must be zero because the electric field produced by charges distributed around the circuit is conservative. We denote this such a conservative field as \vec{E_{c}}.
When an inductor is included in the circuit, the situation changes. The magnetically induced electric field within the coils of the inductor is not conservative. We denote this field as \vec{E_{n}}. We need to think very carefully about the roles of the various fields. Let's assume we are dealing with an inductor whose coils have negligible resistance. Then a hegligibly small electric field is requiresd to make charge move through the coils, so the total electric field \vec{E_{c}} + \vec{E_{n}} within the coils must be zero, even though neither field is individually zero. Because \vec{E_{c}} is nonzero, we know there have to be accumulations of charge on the terminals of the inductor and the surfaces of its conductors, to produce this field."
The author then goes on to use this, together with Faraday's law and the self-induced emf of the inductor, to work out the voltage drop across it. He concludes that we are fine in using Kirchhoff's second law, so long as we are defining the voltages in terms of the conservative part of the field.
I am trying to satisfy myself that this is true, but I have a problem: what if I apply the same thinking (regarding the total electric field being zero) to just a circular loop of wire in a changing magnetic field?
I know that an electric field will be induced which is non-conservative. And, as before, the wire has negligible resistance so the total electric field in the loop must be zero. But since \vec{E}=\vec{E_{c}}+\vec{E_{n}} , \vec{E_{c}} must be nonzero, and there must be an accumulation of charge on the terminals... oh wait, there are no terminals like before? So how is there an accumulation of charge, and where does the non-conservative electric field come from?! Now I'm confused!
Please can someone help me? :frown:
Cheers, Jon.
I don't understand what the article is about. Yes, the induced electric field is not conservative, but the loop is not closed, and electromotive force is fixed. What's the problem?
He argues that, because the inductor coils have negligible resistance, this means that a negligibly small electric field is required to make charge move through the coils, and hence the electric field within the coil must be zero. This seems reasonable to me.
My question is: what if i apply this same reasoning to a circular loop of conducting wire with a changing magnetic flux through it?
That is what I don't understand.
Thanks, Jon.
This might have something related to the long running MIT professor's thread!:smile:
I am questioning how electrodynamics threat induced emf, back emf and so far nobody reply yet!
Okay, thanks, I'll watch the video and see if I can make any more sense of it myself.
In the mean time, is anyone else able to explain please? :frown:
  • · Replies 51 ·
9K
  • · Replies 21 ·
  • · Replies 42 ·
