Total energy in a system of capacitors
The total energy stored in a system of capacitors is equal to the sum of the energies in individual capacitors, specifically for series capacitors. The energy for each capacitor is calculated using the formula U = 1/2 (Q^2 / C). For two series capacitors, the equivalent capacitance is given by Ceq = (C1 * C2) / (C1 + C2), and the total energy stored can be shown to equal the sum of the energies of the individual capacitors. This principle does not apply to resistors, as they do not store energy but consume power, which is calculated differently.
  • Understanding of capacitor energy storage and formulas
  • Familiarity with series and parallel capacitor configurations
  • Knowledge of electrical charge (Q) and capacitance (C)
  • Basic principles of electrical power in resistive circuits
  • Study the derivation of energy stored in capacitors using U = 1/2 (Q^2 / C)
  • Learn about the differences in energy calculations for series vs. parallel capacitors
  • Explore the concept of equivalent capacitance in complex circuits
  • Investigate power consumption in resistors and how it relates to total circuit power
Electrical engineers, physics students, and anyone interested in understanding energy storage in capacitors and power consumption in resistive circuits.
davidbenari
Can someone provide for me a proof that the total energy of my equivalent capacitor is equal to the sum of the energy in all capacitors? Or, if this is untrue, tell me why?
Is this applicable to current and resistors too?
Thanks a lot.
How do you define energy in a capacitance? Can you do the math yourself to compare total energy on a simple set of series parallel capacitors and then do the same for the equivalent capacitance?
Since resistors don't store energy, I don't know what you might have in mind for "Is this applicable to current and resistors too?"
My problem was proving it for series capacitors. Parallel capacitors seem more straightforward, for two reasons, one is that they add $Ceq=C_1+C_2...+C_n$ the other is that they all have the same $V$.
Series capacitors don't always have the same $V$ and they add differently. So I can't do it at the moment. :(
What i meant with resistors was the power they consume. Is the power an equivalent resistor consumes equal to the sum of all the powers on all resistors?
So I ask for that as well, can you figure the power consumed in a resistive circuit and then do the same for the equivalent resistance?
What is it that prevents you from doing it for series capacitors?
If both series capacitors start out uncharged, they will always have the same charge, because the current through them is always the same.
In this case their energy is:
\frac {1}{2} \frac {Q^2} {C_1} + \frac {1}{2} \frac {Q^2} {C_2}
The equivalent capacitance is
\frac {C_1 C_2} {C_1+C_2}
and the energy of the equivalent capacitance is
\frac {1}{2}\frac {Q^2} {C_{eq}} = \frac {1}{2} \frac {Q^2 (C_1 + C_2) } {C_1 C_2} = which is equal to the sum of the stored energy of C1 and C2 calculated above.
I would have appreciated it if you would have waited for him to answer my question before you spoon fed him the answer. My goal was to help him figure it out on his own.
  • · Replies 32 ·
