Transfer Function of System H(jw): 0.318
  • Thread starter Thread starter kenok1216
The discussion revolves around the transfer function of a system, specifically H(jw), and the discrepancy between two proposed forms: 1/[1+(jw/612)] and 0.318/[1+(jw/612)]. Participants explore the implications of inserting w=0 into these functions and the significance of the value 0.318 in relation to frequency response and DC gain.
  • Some participants question why the transfer function is expressed as 0.318/[1+(jw/612)] instead of 1/[1+(jw/612)].
  • There are repeated inquiries about the implications of setting w=0 in the equations and what values can be derived from this.
  • One participant suggests that the value 0.318 is related to the DC gain and is derived from a magnitude plot showing -10dB.
  • Another participant mentions that the transfer function has both a constant part and a frequency-dependent part, indicating that the constant term affects the overall gain.
  • Some participants express confusion about how to reconcile the two transfer functions with the graphical representation provided.
  • There are discussions about the educational aspects of understanding transfer functions and the challenges faced by beginners in grasping these concepts.
Participants do not reach a consensus on the correct form of the transfer function or the significance of the value 0.318. Multiple competing views remain regarding the interpretation of the transfer functions and their relationship to the magnitude plot.
There are references to specific values and functions that may depend on definitions or assumptions not fully articulated in the discussion. The relationship between the transfer functions and their graphical representations remains unresolved.
kenok1216
Determine the transfer function of the system H(jw)
why the answer is not 1/[1+(jw/612)] but equal to 0.318/[1+(jw/612)]?
What happens if you insert w=0 into the equation? Can you determine the remaining value?
to which equation?Vi=Va sin(wt+θ)?
i find that 0.318 is 1/π where the π come from?
You have asked for the transfer function - thus, I mean H(jw), of course.
but the equation of H(jw)=1/[1+jwRC] (from my lecture notes) 1/Rc=w0 (for w<0.1w0), hence i did not where 0.318 come from
The magnitude plot shows for small w values (down to w=0) a level of -10dB. Can you calculate the corresponding absolute value?
Then, you must compare this result with both transfer function for the case w=0. Which one is valid?
20log(Vout/Vin)=-10
丨Vout/Vin丨=10^(-0.5)=0.316? then what is the meaning of this number
for the equation of 1/[1+jw/612] 丨Vout/Vin丨=0.999998 they are not the same,then how can i solve this problem?
Don`t you see it in one of your transfer functions?
NO,they are not the same ,for the equation of 1/[1+jw/612] 丨Vout/Vin丨=0.999998, but how can i make it become 0.316?
I repeat: Don`t you see it in one of your transfer functions?
sorry,still don't understand:frown: can you show me some step ?
At the bottom of your first post I see TWO functions.
Are you able to insert w=0 into BOTH functions - and decide, which one results in 0.318?
from the graph (a) 0 to w0 ≅-10dB
from the graph (b) phase differnet ≅-40 degree so the equation
so Vi(t)=0.316Vi (sinθ-40o)then turn it to the H(jw) form?
Sorry - I resign. Are you kidding me?
Sometimes teachers forget how strange it all seems to beginners.
The mechanics of reading frequency response charts ( we called them Bode plots in my day)
becomes so natural
that your lecturer may have completely forgot to mention it,
or his mention may have been so brief you missed it...
Some of the filter's attenuation is not frequency dependent. Its "Gain", "Attenuation", "Transfer Function" , call it what you like ,
has two parts, a constant part and a frequency dependent part
so
it is of the form K X f(frequency)
and your graph shows you at its left edge that the constant term K is -10db not 0db
and 10-0.5 = .316, not 1
(if it started at zero db then K would be 1)
That's how transfer functions work.
I don't know how he got .318 instead of .316. You should ask him.
as explained above, it's K X f(frequency) ,, 0.316 X 1/[1+(jw/612)]
First find the "DC gain" (for w = 0) for this transfer function 1/[1+(jw/612)]
Next do the same for this one 0.318/[1+(jw/612)], then you need to compare the results. And you will see that only one of the results will fits the "graphical representation".
thank for your,since my lecture notes just have the formula 1/[1+(jw/RC)],so i do not know that it have Dc gain K, but after search at google and read your comment, i got the point now, thank so much.
kenok1216 said:
1/[1+(jw/RC)
I think if you do that division and expand the polynomial you'll find in it terms that are not multiplied by jw
whenever you see that , there's DC gain
as you become accustomed to these exercises you'll come to recognize the "shape" of commonly occurring polynomials and your mind will leap immediately to an equivalent circuit.
That one's a "first order lag"
R2/R1 is the "K" above.
Hi Jim - perhaps you are right in some cases, however, after 25 years experience in teaching electronics, I know about the problems some beginners might have.
But considering that
* both possible transfer functions were given at the bottom of the first post
* and reading again my several answers (in particular my post#6) and the OP`s answer (mentioning the magic value of 0.318)
you certainly will come to the conclusion that I am not "guilty".
In post#12 I have asked him to compare both given functions - he simply has ignored this hint.
I simply have assumed that sombody who presents a magnitude plot together with two possible transfer functions (same denominator, only the constant factor is different) should be able to decide which function belongs to the graph.
Or - do you really think I have overstrained the questioner?
Sorry LVW, my remark was aimed at his lecturer not at your comments.
That he didn't seem to pick up on yours is why i belabored the mechanistic starting point. I well remember being so abjectly confused that i needed a "Reset" button , and that's what i tried to give him.
If it came across as criticism - that was the opposite of my intent,
indeed i noticed your .posts and used them for a springboard
i should have opened (as i often do) with "LVW is on the right track here, " because you were.
I think he came around
Did i go too far in the direction of spoon-feeding ?
Same question re my post #4 here:
https://www.physicsforums.com/threads/opamp-transfer-function-problem.869001/
old jim
Hello Jim, thank you for clarification - and sorry for the misunderstanding I have caused.
It was such a simple problem - and I really could not belief that somebody could have difficulties to decide which of the given functions correspondes to the proper DC gain. Finally, I was not sure if it was a kind of trolling.
LvW
I don't see where you're guilty of that.
Your science is consistently very good
and we all struggle for words to express our thoughts
there's two translations in any communication -
one our mental image to our words
and one from those words to another mental image in mind of the listener...
Then listener tries to communicate his summation back to us ...
remember the early days of language translation by computer ?
They handed the English sentence
"The spirit is strong but the flesh is weak"
to a computer for translation into Russian then back to English
and it came back
"The wine's great but the meat is just awful."
With Highest Regards
old jim
and it came back
Perhaps I should try to repeat this procedure?:oldsmile:
I bet yours would work a lot better...:smile:
34K
  • · Replies 17 ·
11K
