Transformations in curved spacetime?
wpan
I know that the spacetime in special relativity is not curved and that the axis can be transformed via the lorentz transformations.
I was wondering if the curved spacetime in general relativity can be transformed in such a way, and if so, how?
Yes of course. The Lorentz transformations are the set of transformations that preserve the space-time interval $$ ds^2 = dt^2 - dx^2 - dy^2 - dz^2 $$. A similar concept of space-time interval also applies to GR.
Depends on just what you mean, but generally, 'no'.
Wikipedia puts it this way: [Minkowski space is the the flat space-time of SR]
http://en.wikipedia.org/wiki/Lorentz_transformation
In Minkowski space, the Lorentz transformations preserve the spacetime interval between any two events. They describe only the transformations in which the spacetime event at the origin is left fixed, so they can be considered as a hyperbolic rotation of Minkowski space...
In the flat spacetime of SR the space-time separation between two events or two observers is the integral of ds along a straight line from one event to the other. [There is only one such straight line.] The analogous measure in curved spacetime would be the integral of ds along a geodesic [free fall path], generally a curved worldine. But in general in curved spacetime there are multiple geodesics connecting the events so you won't see much talk of “space-time separation” in GR because there are many such paths.
Thread 'Can this experiment break Lorentz symmetry?'
1. The Big Idea: According to Einstein’s relativity, all motion is relative. You can’t tell if you’re moving at a constant velocity without looking outside. But what if there is a universal “rest frame” (like the old idea of the “ether”)? This experiment tries to find out by looking for tiny, directional differences in how objects move inside a sealed box. 2. How It Works: The Two-Stage Process Imagine a perfectly isolated spacecraft (our lab) moving through space at some unknown speed V...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. The Relativator was sold by (as printed) Atomic Laboratories, Inc. 3086 Claremont Ave, Berkeley 5, California , which seems to be a division of Cenco Instruments (Central Scientific Company)... Source: https://www.physicsforums.com/insights/relativator-circular-slide-rule-simulated-with-desmos/ by @robphy
Does the speed of light change in a gravitational field depending on whether the direction of travel is parallel to the field, or perpendicular to the field? And is it the same in both directions at each orientation? This question could be answered experimentally to some degree of accuracy. Experiment design: Place two identical clocks A and B on the circumference of a wheel at opposite ends of the diameter of length L. The wheel is positioned upright, i.e., perpendicular to the ground...
