Transformer core considered as a waveguide
The discussion centers on the concept of using a transformer core as a waveguide or transmission line, drawing comparisons to the Goubau line. Participants highlight that while both systems involve electromagnetic (E-M) fields, the mechanisms of energy transfer differ significantly. The transformer core primarily exhibits near-field effects with longitudinally polarized magnetic fields, contrasting with the Goubau line's surface wave propagation facilitated by a dielectric coating. Ultimately, the consensus is that the mathematical models of waveguide propagation do not apply to transformer cores due to their differing operational principles.
  • Understanding of electromagnetic field theory
  • Familiarity with transformer operation and magnetic coupling
  • Knowledge of waveguide theory and modes of propagation
  • Basic principles of transmission line theory
  • Research the differences between near-field and far-field electromagnetic effects
  • Explore the principles of Goubau line transmission and its applications
  • Study the mathematical models of waveguide propagation and their limitations
  • Investigate the impact of core materials on transformer efficiency and performance
Electrical engineers, physicists, and students studying electromagnetic theory, particularly those interested in transformer design and wave propagation mechanisms.
tech99
Has anyone considered the iron core of a transformer to act as a transmission line or waveguide, where it conveys energy from primary to secondary? The core seems to resemble a "magnetic version" of the single wire Goubau line.
Skimming the Goubau line article I note that there is a dielectric coating and the UHF signal is transmitting via surface waves. This does not fit analogously with the transformer core which is being longitudinally polarized. Also you are not getting the propagation down the length of the iron core. Keep in mind that E-M waves propagate transverse to their E and M fields. While the various modes of a wave guide will correspond to different E vs B field directions (as in radial vs circumfrerential or x vs y ) they still invariably align perpendicular to the propagating waves. With the iron core the B field is along the length so one is rather getting "near field effects" with respect to the transmission of power along the core length.
Thank you for your comments. I had forgotten that the Goubau line was first described with a dielectric coating. For propagation by waveguide modes, I think we can see a longitudinal field component, so B or E may not be perpendicular to the direction of propagation.
For the Goubau line, the magnetic field seems to surround the wire, whilst with the iron core the electric field surrounds the core circumferentially. For Goubau, the electric field is longitudinal and for the iron core the magnetic field is longitudinal. So the fields seem to have the same form but reversed. And when a pulse is applied to the primary, I feel that a wave must propagate along the core to the secondary - it cannot be instantaneous.
Those are my reasons for making the suggestion, and I wondered if a transmission line view (e.g. the effect of mismatching) would be compatible with the basic operation observed with a transformer.
?? what if primary and secondary are a bifilar arrangement instead of two coils separated as on a bobbin wound ?
Then it'd work without an iron core.http://amasci.com/tesla/tmistk.html
It seems that in the case of two coils spaced by air, we are linking the two transducers together via "free space", so we do not have waveguide propagation. The iron core enables the coils to exchange energy when spaced apart, by acting as a waveguide.
It does not act like a waveguide in that the mathematical representations of waveguide propagation do not apply. It is a completely different mechanism (magnetic coupling) as opposed to wave propagation (and the associated Modes).
Just because there is energy across a distance in the two cases does not mean they are in any way analogous. Like comparing a wire to a laser.
A Goubau line is a traveling wave structure. Launching it involves a conical matching section at each end and it operates over many wavelengths. That's very different from the operation of a transformer which is short compared with the wavelength involved. There are parallels between the two, of course, because they both work with EM but I have to ask Why would one want to treat them the same? Would you consider analysing a Goubau line as a kind of Transformer? I can only see a lot of grief in that direction.
I certainly may be way off with respect to the issue of longitudinal modes but I would agree with sophiecentaur, that wavelength considerations invalidate the treatment of the core as a waveguide. That is what I was thinking with my "near field" comment.
  • · Replies 56 ·
  • · Replies 47 ·
