Transforming a matlab code
The discussion revolves around modifying a MATLAB code that simulates the magnetic field of two concentric solenoids to instead simulate the magnetic fields of high voltage transmission lines, specifically for configurations with two and four lines. The focus is on code transformation and adaptation for a different application in electromagnetic field simulation.
  • One participant requests assistance in adapting the existing MATLAB code for solenoids to simulate the magnetic fields of high voltage transmission lines.
  • The original code is described as functioning well for its intended purpose, but the participant seeks guidance on how to modify it for the new application.
  • There is an implication that the mathematical principles governing the magnetic fields may differ between solenoids and transmission lines, which could affect the code structure.
  • Some participants may suggest specific changes to parameters or equations, but no concrete modifications have been proposed yet.
The discussion remains unresolved, as participants have not yet reached a consensus on how to effectively transform the code for the new application. There are indications of differing views on the necessary modifications.
Participants have not yet addressed potential limitations of the original code when applied to transmission lines, such as differences in geometry or field behavior. The discussion may benefit from clarifying these aspects.
Radinax
Hi fellows!
I need a bit of help with transforming a MATLAB code that simulate magnetic field of two concentric solenoid TO a plot that simulate the magnetic fields of high voltage transmission lines (specificly two and four lines), how can it be modified? here is the code:
% GKLmagnet2.m: magnetic profile for TWO ring magnets.
% This code simulates the magnetic field on the z-axis of
% two concentric solenoidal superconducting magnets of specified
% size for use in the 140GHz Gyroklystron (GKL) experiment, MIT.
% With two coils, it's possible to have one large region that
% meets the tolerance spec, otherwise two fields are created which
% may not meet spec. If the field is not continuous (one field)
% to within spec, the varialbe 'flag' is set to unity (otherwise 0),
% and a warning is displayed.
% run GKLmagnet2
% Last edit by Colin Joye, 7/10/03
clear all;
opengl autoselect;
% -------------- USER INPUT -------------------------
Bmax = 5.12; %[Telsa] maximum magnetic field in uniform region
Tol = 0.3; %[%] percent homogeneity of uniform region
% Magnet size. The magnet is a finite-length finite-thickness hollow cylinder
% modeled as a single turn rectangular cross-section current density.
% The magnet is centered at z=0, extending 'Length'/2 above and below z=0.
RadIn = 15; %[cm] inner radius of coil
RadOut = 18; %[cm] outer radius of coil
Length = 6; %[cm] coil length
Separ = 18.0; %[cm] center separation distance > Length
zaxis = 30; %[cm] length above z=0 to view the field profile
% -------------- End USER INPUT ---------------------
% extra user constants:
transparency = 0.25; % controls transparency of slices & patches. '= 1.0' is opaque.
cyl_frac = 0.74; % azimuthal fraction of cylinder to plot. '= 1.0' for full cyl.
% check if length is larger than separation.
if(Separ<Length),
disp(['Error, Separation must be greater than Length']);
break;
end
flag = 0;
% Define z-axis vector for field profile.
z = zaxis*[-1:1/2e4:1];
%z = [0 1 2 5 10 15 20 25 30 31]; %Kreischer's Table II.
% Draw cylinders
sep = Separ/2;
L = Length;
[Xi,Yi,Zi] = cylinder(RadIn,100);
[Xo,Yo,Zo] = cylinder(RadOut,100);
s = floor( cyl_frac*size(Xi,2) )+1;
cylXi = (Zi(:,1:s)-0.5)*L;
cylYi = -Xi(:,1:s);
cylZi = -Yi(:,1:s);
cylXo = (Zo(:,1:s)-0.5)*L;
cylYo = -Xo(:,1:s);
cylZo = -Yo(:,1:s);
% Applying Biot-Savart law to a finite-length finite-thickness cylinder
% with a rectangular cross-section of uniform current density, we get,
% using an analytic (exact) result from Maple v8.0:
r1 = RadIn;
r2 = RadOut;
Bz = zeros(1,length(z));
for M=1:2, % loop calculates for both magnets.
r1p = r1 + sqrt(r1^2 + (L/2 + (z + sep)).^2);
r1n = r1 + sqrt(r1^2 + (L/2 - (z + sep)).^2);
r2p = r2 + sqrt(r2^2 + (L/2 + (z + sep)).^2);
r2n = r2 + sqrt(r2^2 + (L/2 - (z + sep)).^2);
C0 = (z + sep) .* log( r1n./r1p .* r2p./r2n );
C1 = L/2 * log( r2n .* r2p ./ r1n ./ r1p );
A0 = 1 / (r2 - r1) / L; % multiplicative value
Hz = A0 * (C0 + C1);
Bz = Bz + Hz * Bmax / max(Hz); % normalizing for desired value of Bmax.
sep = -sep; % reverse sign for other magnet, reverse again on exit.
end
% Renormalize again, since addition of field messes up first normalization.
Bz = Bz*Bmax/max(Bz);
% Find uniformity zones.
zmid = find(z==0);
u = find( abs(Bz(zmid:end) - Bmax)/Bmax <= (Tol/100) );
UniformLength = 2*(z(u(end)+zmid)-z(u(1)+zmid));
if(u(1)~=1), %check if the field is still continuous.
disp(['Warning, field is broken into two regions']);
flag = 1;
end
% ---------------- Figures -------------------
figure(1)
clf(1)
hold on;
surf(cylXi-sep,cylYi,cylZi); % inner cylinder
surf(cylXo-sep,cylYo,cylZo); % outer cylinder
surf(cylXi+sep,cylYi,cylZi); % inner cylinder
surf(cylXo+sep,cylYo,cylZo); % outer cylinder
colormap autumn;
shading flat;
% Plot dressups
a = 1.2*RadOut;
b = 1.1*zaxis;
axis equal;
axis([-b b -a a -a a]);
view([-15 15]);
% define scaling variable for making field plot look better.
scale = floor(a/max(Bz)); % scale line and grid to view field better
if(scale<=1) % make sure you don't have scale = 0, 3, 6, 7, 9, etc.
scale=1;
elseif(mod(scale,2)~=0 & mod(scale,5)~=0)
scale=scale-1;
end
% Add transparent slices. Transparency controlled by "alpha"
% Horizontal plane slice
h = patch([-b -b b b],[-a a a -a],[0 0 0 0],[0.2 1 0.5]);
alpha(h,transparency);
set(h,'EdgeAlpha',0);
% Vertical plane slice
h = patch([-b -b b b],[0 0 0 0],[-a a a -a],[0.2 1 0.5]);
% Z=0 plane slice
%h=patch([0 0 0 0],[-a -a a a],[-a a a -a],[0.7 1 0]);
%alpha(h,.3);
%set(h,'EdgeAlpha',0);
% solidify cylinders
map = colormap;
px = cylXi(:,end)'*[1 0 0 1;0 1 1 0];
py = [cylYi(:,end)' cylYo(:,end)'];
pz = [cylZi(:,end)' cylZo(:,end)'];
h = patch(px-sep, py, pz,[0.7 0.8 0.9]);
set(h,'EdgeAlpha',transparency);
h = patch(px+sep, py, pz,[0.7 0.8 0.9]);
px = cylXi(:,1)'*[1 0 0 1;0 1 1 0];
py = [cylYi(:,1)' cylYo(:,1)'];
pz = [cylZi(:,1)' cylZo(:,1)'];
% Put grid on field line patch
ytick = get(gca,'Ztick');
ytick = (ytick + max(ytick))/2; % remove negative ticks and interpolate.
ztick = get(gca,'Xtick');
Ly = length(ytick);
Lz = length(ztick);
y0 = zeros(1,Ly);
y1 = b*ones(1,Ly);
z0 = zeros(1,Lz);
z1 = a*ones(1,Lz);
line([1;1]*ztick,[z0;z0],[z0;z1],'Color',0.4*[1 1 1],'LineStyle',:); %vert lines
line([-y1;y1],[y0;y0],[1;1]*ytick,'Color',0.4*[1 1 1],'LineStyle',:);%horiz lines
% Add axis line and numbers on new grid.
% Vertical:
line(-[b b],[0 0],[0 a],'Color',[0 0.3 1]); % vert axis line for numbers
line(-[1;1.03]*y1,[y0;y0],[1;1]*ytick,'Color',[0 0.3 1]); % draw tick lines.
h = text(-1.03*y1',y0',ytick',num2str(ytick'/scale),'HorizontalAlignment','right');
set(h,'Color',[0 0.3 1]);
pz = length(get(h,'String'))-3;
h = text(-1.1*b-pz,0,mean(ytick),'Field [T] (blue)','HorizontalAlignment','center');
set(h,'Color',[0 0.3 1],'Rotation',90);
% Horizontal:
line(-[b zaxis],[0 0],[0 0],'Color',[0 0.3 1]); % horiz axis line for numbers
line( [zaxis b],[0 0],[0 0],'Color',[0 0.3 1]); % horiz axis line for numbers
line([1;1]*ztick,[z0;z0],-[0;0.03]*z1,'Color',[0 0.3 1]); % draw tick lines.
h = text(ztick',z0',-0.055*z1',num2str(ztick'),'HorizontalAlignment','center');
h = line([-zaxis zaxis],[0,0],[0,0]); % z-axis line.
set(h,'Color','red','LineWidth',2.5);
% Add plot of field line
h = plot3(z,zeros(1,length(Bz)),scale*Bz,'b');
set(h,'Color','blue','Linewidth',2);
h = text(0,0,0.1*Bmax,'Uniform Region');
set(h,'Rotation',90,'Color',[0 0.4 0.4])
% Add patch showing uniform region within 'Tol' percent.
uz0 = u(1)+zmid;
uz1 = u(end)+zmid;
px = [z(uz0) z(uz1) z(uz1) z(uz0)];
py = [0 0 0 0];
pz = scale*[0 0 Bz(u(1)+zmid) Bz(u(end)+zmid)];
h = patch(px, py, pz,[1 0.2 0.5]);
alpha(h,1.5*transparency);
px = -[z(uz0) z(uz1) z(uz1) z(uz0)];
%h = plot3(z(u),zeros(1,length(u)),max(Bz)*ones(1,length(u)),'m');
%set(h,'LineWidth',2');
set(h,'Rotation',90,'Color',[0 0.4 0.3])
% Title and Labels
title(['Magnet strucure w/ Field: ' num2str(Bmax) ' T max; R1 = ' num2str(r1) ...
' cm; R2 = ' num2str(r2) ' cm; L = ' num2str(L) ' cm; S = ' num2str(Separ) ...
' cm; ' num2str(Tol) '% Uniform length: ' num2str(UniformLength) ' cm']);
xlabel('Z-axis [cm]');
ylabel('X-axis [cm]');
zlabel('Y-axis [cm]');
hold off;
% ------------- END GKLmagnet2.m ---------------------------
PS: It dooes what i need but i need the magnetic fields of those high voltage transsmision lines, and i don't know to much of programing, sooo i will apreciate a loooot if you can help me out =)
I could use some help you know...
Ok then. Hang around the Computer Lab while other students from your class are working on this project. After they leave, look though all the waste paper bins in the hope they've disgarded some hard copies of partially debugged code. Then you'll have some code that's a little bit closer to what you're trying to achieve to try and hack.
Now for a serious reply.
You haven't got any help because you've posted a silly question. No one here is likely to be writting code by "transforming" code from a completely different problem, it's just not how it's done.
You should be starting here with the relevant equations for the actual problem at hand. If you don't know what these are then that's what your first question should be in relation to.
