Transistor Base to Emitter Voltage
The discussion centers around the differences between Base-Emitter Saturation Voltage (VBE(sat)) and Base-Emitter On Voltage (VBE(on)) in bipolar junction transistors (BJTs). Participants explore the definitions, conditions under which these voltages apply, and their implications in various operational states of the transistor, including active and saturation regions.
  • Some participants question the values of VBE(sat) and VBE(on), suggesting that the saturation voltage should be higher than the on voltage.
  • One participant provides specific values for an NPN transistor and seeks clarification on the differences between VBE(sat) and VBE(on).
  • Another participant explains that VBE(on) is specified at a certain collector current and temperature, and that VBE(sat) occurs when the transistor is driven into saturation with a higher base current.
  • There is a discussion about the implications of VBE being lower or higher than VBE(on) and VBE(sat), with various scenarios proposed regarding transistor operation.
  • One participant warns that driving the base-emitter diode above VBE(on) may lead to avalanche breakdown, indicating the need for careful consideration of the transistor's physical models.
  • Another participant notes that there is no VBE(sat) for first-order circuit analysis, emphasizing the importance of VCE(sat) instead.
Participants express differing views on the definitions and implications of VBE(sat) and VBE(on), with no consensus reached on the interpretations or the specific values discussed. Multiple competing perspectives remain regarding the operational characteristics of BJTs.
Limitations in the discussion include assumptions about the operating conditions of the transistor, the dependence on specific models, and the lack of resolution on the implications of varying VBE values.
Readers interested in transistor operation, circuit design, and semiconductor physics may find this discussion relevant.
alexhong81
just wondering, what is the difference between Base-Emitter Saturation Voltage and Base-Emitter on Voltage ?
VBE (sat) = 0.5V
VBE (on) = 0.7V
The sat value should be higher than the on value. The first value of 0.5V sounds more like "Vcesat" instead of "Vbesat". Can you double check.?
Anyway, when a bjt is driven fully into saturation, Vce drops to a low value, 0.1 to maybe 0.5V, or even higher/lower in some cases. The on voltage for moderate current values at room temp are around 0.65V. If driven harder, the bjt saturates, & Vbe increases a little.
Claude
I am sorry, you are right, I got the wrong value here.
I am looking at this NPN transistor ZXTD6717E6, Diodes Inc.
VCE(sat) = 0.245V max (havent seen such low VCEsat before)
VBE(sat) = 0.93V typical
VBE(on) = 0.865V typical
If i am not wrong, When VCE > 0.245V and VBE > 0.93V the transistor will "on" and current ID will flow.
Then what is VBE(on) 0.865V? What is the difference between VBE(sat) and VBE(on)?
Thanks~~
Vbeon must be specified at some value of colector current & some temp, usually 25C. If the bjt is in its active region, i.e. Vce>0.7V or so, then Vbeon is the nominal forward voltage drop across the b-e junction.
To saturate the device, a base current greater than Ic/hFE is needed. Most general purpose bjt devices spec saturation at Ic/Ib equal to 10. In this case, the base is overdriven so that Vce drops to a low value, known as Vcesat. This is a condition where the device acts like a closed switch.
Because the base current is higher than its value when the device is in the active region, Vbe is higher as well, & this is Vbesat. Since Vbesat occurs when base current is increased, then Vbesat>Vbeon. But the voltage across a forward biased p-n junction increases only as the logarithm of the current, a large increase in Ib results in a relatively small increase in Vbe. Hence Vbesat is larger than Vbeon by a small margin.
Did this help?
Claude
Thanks Claude.
See whether my interpretation of your explanation is correct:
BJT in active region, VCE>VCE(sat): VBE(on) = nominal base emitter voltage.
BJT in saturation region, VCE<VCE(sat), Ib>Ic/HFE
BJT in active region, Ib higher, VBE(sat) higher.
1. What happens when VBE is lower than VBE(on)?
2. What happens when VBE is higher than VBE(on)?
3. What happens when VBE is lower than VBE(sat)?
4. What happens when VBE is higher than VBE(sat)?
Thanks again Claude
alexhong81: BJT in active region, VCE>VCE(sat)
BJT is in active region when: Nearly VCE > VBEon
All Transistor currents are nearly zero: IB=IC=IE=0
For simple Bias circuits VBE can not be higher than VBEon. Driving BE diode above VBEon may lead to Avalanche break down. But transistor CAN work with over voltages, its work is highly dependent to the type of transistor and the circuit and we will have to consider the precise transistor physical models like Ebers-Moll or Gummon-Poll models.
There is no VBEsat for first order circuit analysis of transistor bias circuits. We have VCEsat!
The question is wrong!
Microelectronic circuit design by Richard Jaeger is highly recommended.
Thanks...guess i will have to do some reading up first...
  • · Replies 23 ·
11K
  • · Replies 19 ·
