Transistor cant understand even a bit
21 replies · 5K views
sudar_dhoni
i can't understand the transistor completely
i can understand how it works but this stupid conventional current is confusing me completely
please can anyone give a lengthy explanation on working of transistor
CE CB CC types. i don't understand all these types of transistor i.e how current flows in all these
also this transistor characteristics is making me mad
but i am very anxious and curious to learn about it
can any 1 help me
The NPN transistor bears a vague similarity to the triode vacuum tube.
Electrons are emitted from the emitter (filament)
The flow is controlled by the base (grid)
The electrons reach the collector (plate).
In vacuum tubes, the grid potential is several volts below the filament, while in the NPN transistor, the base is ~0.6 volts above the emitter. The grid controls space charge around the filament to limit plate current. Thermionic emission controls the electron charge density near the filament.
Emitter follower (common collector) is similar to cathode follower. Common emitter is similar to common cathode, and grounded grid is similar to grounded (or common) base.
Bob S
Bob S
Bob S
in vacuum tubes electrons flow from the battery
but in transistors current flow from the transistor
also i can't understand the function of rheostat in the figure posted by me
in fact i can't understand the whole of this circuit diagram
what is the meaning of voltage between emitter and base , collector and base
do they have potential differece
In your transistor, current flows into the collector, and out the emitter. The base potential controls the amount of collector current. A higher base voltage increases the collector current. R1 controls the collector voltage, and R2 the base voltage.
Bob S
Bob S
BOB S thanks a lot for comparing with the triode
i understood triode
please say whether i am right or right
the voltage between emitter and base is Vbe i.e supply voltage which is used to destroy depletion region
the voltmeter measures the potential diff between emitter and base which is same as the supply voltage Vbe am i right
i understood everything except for1 thing
i can't understand y a rheostat is used
my sir told me that it is used to vary the voltage
i can't understand this because the supply voltage just establishes a driving force or electric field in the transistor and no current flows from supply to transistor then what is the purpose of rheostat there as no current flows from supply to transistor
this 1 thing is confusing me? please help me GENIUS BOBS
Since you seem to be more interested in the circuitry around the transistor then the transistor itself I am moving this to the EE forum.
sudar_dhoni said:
BOB S thanks a lot for comparing with the triode.
The voltmeter measures the potential diff between emitter and base which is same as the supply voltage Vbe am i right
There is a current flowing from the base to the emitter, called Ibe. There is another current flowing from the collector to emitter, called Ice. The ratio Ice/Ibe is called hfe, or gain. So the rheostat provides the Ibe current to turn the transistor on. See
http://www.rason.org/Projects/bipolamp/bipolamp.htm
Look up 2N3904 specs, incl hfe at
http://www.datasheetarchive.com/pdf-datasheets/Datasheets-24/DSA-467653.pdf
Bob S
Conventional current vs electron current has nothing to do with how a transistor operates.
Power still comes from the battery and any current that leaves the battery has to return to it.
In this diagram, the current splits into base current and collector current. R just limits the base current.
At the emitter, the currents combine again and return to the battery.
The base current controls the collector current. I have drawn these currents on the same scale to show that the collector current is a LOT bigger than the base current.
If you search my posting history, I've contributed to threads where the transistor, bjt & FET, is thoroughly dissected. I'd recommend reading these threads, and if you have a specific question, it can then be addressed.
Transistor operation is not rocket science, but far from trivial. At 1st, one must simply trust the semiconductor OEMs because they make the devices, and know more than anyone. After much time and study, it will make sense to you. But trust Fairchild, On Semi, Texas Instruments, Natl Semi, etc. more than non-peer-reviewed web sites. The web is filled with people who think they know more than the OEMs. I am a practicing EE in my 32nd year, with a year left to go on a doctorate and I still have much to learn. Trust me, there are only a small number of people who have a great understanding of the innards of a transistor. Use them as a reference. They are the ones who MAKE the transistor. Disregard contrarians who insist they know more than OEMs.
Claude
Claude
i want to know only one thing that why that rheostat is used
if u say to vary the supply voltage
how can it vary the supply voltage
what i know is that the supply voltage is mainly used to provide the electric field to destroy the depletion region in the EB junction forward biased due to which electrons in emiiter move to base.Only minute of them are attraced towards the positive terminal of Vbe while the rest flows to the Collector and so on
what i want to know is that to vary the supply voltage why rheostat is used
how does it vary the voltage
i thought that the current from the battery mainly flows through the volmeter which measures the voltage of the source and that for the transistor it justs provides electric field to destroy the depletion region
since transistor is connected parallel to voltmeter and supply the voltage measured by voltmeter is the same applied for the transistor as it is connected parallel
please tell me why that rheostat
The voltmeter draws very little current compared to the current drawn by the transistor. Ideally it should draw none, but all voltmeters draw some current.
A rheostat used as in this diagram is called a potentiometer. (A rheostat only uses two connections but a potentiometer uses both ends of the device and the sliding contact.)
It is a long piece of resistance wire wrapped on an insulating cylinder and a connection is made to each end and to a sliding contact which is available to tap onto the wire at regular intervals (ususally every turn) along its length.
If a potential is placed across this potentiometer, it divides evenly along the length of the wire and you can use the sliding contact to vary the voltage out. This is just like a variable voltage supply.
Some current is taken from the potentiometer and flows through the transistor. A lot more current flows in the potentiometer and returns to the battery. Note that this is only for testing the transistor and would not be used for normal operation of a transistor.
but in transistor the current (non conventional current) flows from negative terminal to the emitter of the transistor. in its path there is no rheostat.
Moreover initially current does not flow through the transistor but only establishes electric field. then y do u need a rheostat or potentiometer there?
OK.
It looks like you have a problem with electrical circuits, not just transistors. This can be fixed.
In the above diagram can you see that if you move the slider on the potentiometer from the bottom to the top, the voltage between the slider and the bottom connection will increase?
Forget the transistor for a moment, but I have redrawn the currents as electron flow.
vk6kro said:
OK.
i already know how potentiometer works
i know that it can vary the voltage drops and all
but i can't understand y is it used in the transistor characteristics
because here the supply voltage just simply establishes electric field within the transistor
and that no current is drawn from the battery
in that case what is the use of this potentiometer which is primarily used to vary the voltage drops
thats y in most of this circuit diagram they have marked only conventional current
what i know is that the supply voltage is mainly used to provide the electric field to destroy the depletion region in the EB junction forward biased due to which electrons in emitter move to base.Only minute of them are attraced towards the positive terminal of Vbe while the rest flows to the Collector and from collector they flow to the positive terminal of Vcb
and from -terminal of Vcb flows to the +terminal of Vbe and from - terminal of Vbe flow back to emitter to maintain the concentration of electrons in emitter.thus all the concentrations have been balanced and the result is that current has flown in the circuit
i want u explain in terms of the current that i have mentioned.
i can understand only if u mention the actual electron movement
not conventional as it does not exist in reality
As you increase the voltage across the transistor from zero, initially the transistor does not conduct at all. You could use a variable power supply for this or you could use a potentiometer, it doesn't matter. What matters is the voltage across the transistor C- E pins.
When you reach about 1 volt, it will start to conduct if there is base current flowing.
As you increase the collector to emitter voltage, (assuming constant base current) the current reaches a maximum at about 1.5 volts on the collector and stays like that as you increase the voltage from 1.5 volts to say 12 volts. This current is set by the base current times the gain of the transistor.
You do not have to worry about conventional current vs electron current as the magnitudes of these are the same.
thats what i want to know that how potentiometer can be used as a variable power supply
since for transistor only the battery's electric field is action .
If u use potentiometer u can vary the voltage drops.This is valid only if u draw current from the battery
but for transistor only the battery's electric field is used there
i can't understand how a potentiometer can vary the electric field of the battery acting on the transistor.
but i know how potentiometer works i learned from this site
http://www.allaboutcircuits.com/vol_1/chpt_6/1.html
i just can't digest how it is used in this transistor characteristics and what is its role and how can it vary the electric field of the battery acting the Emitter BAse
You understand how a potentiometer works but you don't understand how it produces a variable voltage?
Its only function is to produce a variable voltage, so you do not understand how it works.
That website explains it very well.
As you increase the voltage across the base emitter junction of a transistor (or any other diode) in the forward direction, the current through the diode starts off at zero and stays there at zero until the diode starts to conduct at about 0.6 volts for a silicon diode and at different voltages for other types of diodes. Above 0.6 volts, the diode current will increase rapidly and be limited only by the available current.
You need a variable voltage to test the transistor and a potentiometer gives you a variable voltage. So, why is that a problem?
u didnt understand my question
i never told i didnt understand how potentiometer works
see what i have asked
"i can't understand how a potentiometer can vary the electric field of the battery acting on the transistor.
i just can't digest how it is used in this transistor characteristics and what is its role and how can it vary the electric field of the battery acting the Emitter BAse"
potentiometer is just an instrument used to vary the voltage drops
if u send 10V by adjusting the slider u can drop 4V and send only 6V to the appliance
this is possible if current flows through it
in the case of transistor battery only establishes electric field within the transistor
how can potentiometer vary the electric field which is acting on the transistor?
There is a current flowing in the potentiometer, so the voltage that comes out of the slider is just as real as the voltage that comes out of the battery.
In the above circuit, the voltmeter doesn't draw any current. What does it read when the slider is in the centre position on the potentiometer?
If you put a transistor across the voltmeter, why would it not get the same voltage on it as the voltmeter?
the voltmeter will draw little current and measure 6V as the remaining 6 would have already dropped.What u r saying is applicable only if we draw current from the battery.
But in transistor the battery is just applying electric field and not drawing current.
How can the electric field be varied but using potentiometer
Mr vk6kro please bear with me.If u feel that i am pestering u please mention it
here after i won't trouble u
You can put a voltage across anything. Of course. Why couldn't you? If it is already variable it will still be variable.
It will draw current if it is a conductor or it will not draw current if it is an insulator.
Why do you keep insisting that a transistor will not draw current?
It will draw a current as soon as the minimum voltage is reached for the base emitter junction to start conducting. This is only a very small voltage. For higher voltages, it will draw a current.
What country are you in?
i am from INDIA
could u please tell me then what is the function of battery in npn transistor
i thought that transistor will draw current from the battery only after the electrons in the n type have gone to the base to maintain the concentration of electrons in the n type
i.e the electrons from -terminal will flow to emitter
in that way transistor draws current
but this happens only after the electrons in the n type have gone to base due the influence of the ELECTRIC FIELD SET UP BY THE BATTERY WHICH HOW CAN U VARY ?
I WILL EXPLAIN MY QUESTION IN DETAIL
DO U HAVE YAHOO ID WE'LL CHAT THERE
IF SO PLZ GIVE UR ID I'LL SEND FRIEND REQUEST
