Transistor Question: Can a Transistor Amplify Current?
  • Thread starter Thread starter jearls74
    Transistor
A transistor cannot amplify current beyond its specifications; it cannot increase 1 amp of current at the collector to 15 amps at the emitter. The collector current is determined by the base current multiplied by the transistor's gain. Emitter current is the sum of collector and base currents. Understanding these principles is crucial for effective transistor applications. Transistors function as current-controlled variable resistors, not as current amplifiers.
jearls74
ive been reading about transistors and i have a question i can't find answer to, maybe someone here knows the answer. how much current can a transistor amplify or create? for example, can you push 1 amp of current through the collector of a 15 amp 12 volt NPN transistor and would it boost the current to 15 amps coming out of the emitter?
No.
A transistor can be thought of as a current controlled variable resistor.
Collector current is determined by base current times the transistor gain.
Emitter current will be collector current + base current.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
