Transistors, i can't understand how to solve this problem
  • Thread starter Thread starter kliker
    Transistors
The discussion revolves around understanding the behavior of a PNP transistor in a specific circuit configuration. The original poster expresses confusion regarding the current flow direction and the implications of a high βdc value, while also seeking clarity on how to determine the output voltage (Vo) given the resistances involved.
  • Participants explore the implications of the transistor's orientation and the meaning of βdc being large. Questions arise regarding the current flow in a PNP configuration and the conditions under which the transistor operates in cutoff. Some participants suggest that if β is large, the base current (Ib) can be neglected, while others question how to calculate the transistor current without knowing Ib.
The discussion is ongoing, with participants providing insights and clarifications about the behavior of the transistor in the given circuit. There is recognition of the complexity of the situation, and some participants are attempting to reconcile their understanding of cutoff conditions with the implications of a large βdc.
Participants note the lack of specific values for Vcc and the focus on determining Vo based on the given resistances. There is also mention of the potential confusion stemming from the transistor's orientation and the definitions of current flow in PNP versus NPN configurations.
kliker
[PLAIN]http://img685.imageshack.us/img685/2164/transistor.jpg
having this transistor how can I find Vo? We know that βdc is too large
and also R1 = 10KΩ and R2 = 30KΩ
i just can't understand what to do, I mean it's pnp, so why does the current goe from top to bottom?
shouldnt it go from bottom to top? since it's pnp and not npn?
also, we have no resistors through the way where the symbol of pnp is, so wouldn't the whole current just go from there? so there would be no current through the resistors, or not?
i please ask someone to explain this in detail, i ve been searching for a month, and found nothing that would help me understand this problem
thanks in advance
I think that I found out the solution
while I was taking a bath 5 minutes ago I thought that maybe the sign next to Vcc shows the current of electrons, which is correct in pnp transistor
we know that b is too large but also we know that b = Ic/Ib
so if b too large then Ib -> 0
hence we are in cut off region where Vce = Vcc
also in cut off region we can assume that the transistor is open hence the whole current will go from the two resistors
that means that
V0 = Vcc - I(R1+R2)
am I correct?
No, the arrow in a current source points in the direction of positive current, not in the direction of electron flow.
So I agree that the transistor looks like it is drawn upside-down. If it really is like that, then you would need to use the reverse Beta number for the transistor in your calculation.
Hi thanks for the answer
but how can positive current go like this in pnp? Shouldnt it work like this in npn transistor?
Also, I'm not sure what is reverse beta number, can you please explain it more? thanks a lot :)
As I said, the transistor is drawn upside-down from its usual orientation.
Remember that there is also a PN junction between the collector and the base, and if you draw it, the PN junction points into the base, just like the emitter-base junction. So in a sense, the transistor is symmetrical. However, real BJTs are generally built asymmetrically, with different sizes and doping profiles for the EB and CB junctions. This is done to optimize the forward Beta.
But you can run a BJT backwards (upside-down), you just get a lot less beta (and some breakdown voltages change, I believe). I don't think most BJT datasheets even list a reverse Beta (reverse hfe) number, though...
http://www.fairchildsemi.com/ds/MM%2FMMBT3906.pdf
thanks a lot i think I understand now
so we have something like this
[PLAIN]http://img716.imageshack.us/img716/6910/pnp.jpg
in our book they use the symbol in a different way but now i can understand that it is the same thing
hence
again the logic is the same I guess
since we have b too large, then Ib -> 0, we are in cut off region
that means all current will go from the two resistors
and V0 = Vcc - I(R1+R2)
since we know that VBE = 0.7
but where is actually BE? If it is upside down, then Vbe will be in the loop that contains R1
but I think I am wrong here, or not?
You're on the right track. You will get about 0.7V drop from C-B, and current flowing out of the base into the junction between the two base resistors. There will be current flowing through the resistors (with Ib extra flowing down through R2), and some current flowing from top to bottom (C-E) through the transistor. Equilibrium will be established with some value of the base voltage. I guess you could assume some low value of Beta for this reverse configuration... something like 10-20?
but since it says that beta is too large, can't we assume that it is in cut off region? hence the current will be going only through the two resistors?
I don't know what it means to say "βdc is too large". Especially when the transistor is being used in reverse-Beta mode.
But whatever. If Beta is large, all that means is that you can neglect the Ib compared to all the other currents. So yes, the same current flows in R2 as R1. But when you neglect the base current, I'm not sure how you calculate the transistor current? You need Ib and Beta for that, no? Are you given a value for the current source?
in my book it says that when we are in cut off region, there won't be any current going through the transistor, because we can assume that it's open, like in an open circuit
so the current will go from the two resistors only
but I am not sure if i understood this 100%
While it's true that there is no collector current in cutoff, that does not equate to saying that a BJT with high Beta is always in cutoff.
In the circuit you posted, I believe that the circuit will settle with some transistor current and some current through the two resistors. Do they give you a value for the current source?
Note -- it only takes a fraction of a mV to make 0.7V across the 10k Ohm R1. The rest of the current from the current source must be flowing through the transistor. If Ib were not negligible, that would change things only slightly.
no they give no value for Vcc
only for R1 and R2
in the circuit it wants actually only V0
if we assume that there is no current going through the transistor
will V0 be just I(R1+R2)?
i think I am wrong again
the circuit is very confusing for me :(
only for R1 and R2
First, don't assume that there is no current going through the transistor. First, it is wrong, and second, it would keep you from being able to solve the problem.
So to solve this problem, just picture the transistor flipped so that it looks more normal. As I said, the only difference is a much lower Beta, which apparently you can just ignore in this problem.
Next, you know the voltage across R1, right? That gives you the current through R1. Does that tell you something about the current through R2 (again assuming Ib = 0)? And then what does Vo have to be?
BTW, this type of circuit (usually with the BJT in the correct orientation for the best Beta) is called a "Vbe multiplier". Quiz Question -- why is it called that?
Vbe multiplier? Hm, I don't know, actually we ve never done something like that before
I can't understand how it is possible to have current through transistor
since Ib = 0
we know that Ic = beta*Ib
so if Ib is 0 Ic should be 0 too, or no?
let's just assume that there is no current going through the transistor
we have a voltage devider
so V0 will be Vcc - I(R1+R2)? from the picture I can't understand if it will be like this or V0 = I(R1+R2)?
since Ib = 0
No, Ib and Ic are not zero. When the problem says that the Beta is very high, it just means that the Ib is negligible to support the Ic.
Google Vbe multiplier. Wikipedia covers it.
