Translations math problem (gr 12 level)
  • Thread starter Thread starter Senjai
The discussion centers on a Grade 12 math problem involving transformations of the function y=f(x). The transformation is given as -2y-2=f(0.5x-3), with the point (-3, -2) on f(x). Participants attempt to find the corresponding point on the transformed function but struggle with the calculations and transformations. One key insight is that substituting x=0 into the transformation leads to the point (0, 0) being on the new function. Overall, the conversation highlights confusion around applying transformations correctly and understanding the relationship between the original and transformed functions.
Senjai
If the function y=f(x) is transformed to -2y-2=f(0.5x-3), and the point (-3, -2) is on f(x), which of the following will be on the new function -2y-2=f(0.5x-3)?
y = {af}\left[b(x-h)\right] + k
When i attempted this question, i got (-9, -1) which is wrong, i don't know the answer still. I am still unsure really how to show my work so i pretty much did the horizontal translations and scale factors to x, and vertical translations and scale factors to y.
after rewriting the function, i have y = -\frac{1}{2}(0.5x-3) + 2
in an attempt to show work i showed the transformations.
x \rightarrow 0.5x
x \rightarrow x - 3
y \rightarrow 2y
y \rightarrow -y{}\textit{(reflection on x axis)}
y \rightarrow y - 2
I then simply tried to run those transformations on the x and y values seperatly.
(-3, -2)
x = -3(2) -3 = -9
y = -((-1/2)(-2)) + 2 = 1?? I am lost,
i don't really know how to show my owkrk for this question, nor how to do it properly.
any help would be appreciated.
This was also a multiple choice question. Possible answers were
(-9, -1)
(1, 0)
(0, 0)
(-12, 2)
Saying that "(-3, -2) is on f(x)" means that f(-3)= -2. In order that we be able to use that, without any other knowledge of f, we need to be able to apply f to -3 so would have to have 0.5x- 3= -3 so 0.5x= 0 or x= 0. In that case, we have -2y- 2= f(-3)= -2 so -2y= 0 and y= 0. The point is (0, 0).
wow, i feel really really dumb, makes sense putting it that way.. looked at it on a graph, was able to do it that way, algebraically i wasn't able to see it like that.. so its easy, transformation applied to x = previous x value? i don't understand why you can't sub -3 in for x and use that to transform it though, sorry for being all dumb about it...
~Senjai
Senjai said:
(snip)
That's not right. What happened to the f? If the function y = f(x) is transformed to {-}2y{-}2 = f(0.5x{-}3), then
y = {-}\frac{1}{2}[f(0.5x{-}3)] {-} 1.
But you don't need to do this at all; HallsofIvy's solution is the way to go.
01
I picked up this problem from the Schaum's series book titled "College Mathematics" by Ayres/Schmidt. It is a solved problem in the book. But what surprised me was that the solution to this problem was given in one line without any explanation. I could, therefore, not understand how the given one-line solution was reached. The one-line solution in the book says: The equation is ##x \cos{\omega} +y \sin{\omega} - 5 = 0##, ##\omega## being the parameter. From my side, the only thing I could...
Essentially I just have this problem that I'm stuck on, on a sheet about complex numbers: Show that, for ##|r|<1,## $$1+r\cos(x)+r^2\cos(2x)+r^3\cos(3x)...=\frac{1-r\cos(x)}{1-2r\cos(x)+r^2}$$ My first thought was to express it as a geometric series, where the real part of the sum of the series would be the series you see above: $$1+re^{ix}+r^2e^{2ix}+r^3e^{3ix}...$$ The sum of this series is just: $$\frac{(re^{ix})^n-1}{re^{ix} - 1}$$ I'm having some trouble trying to figure out what to...
