Transmitting Information faster than light?
The discussion revolves around the concept of transmitting information faster than light using a hypothetical 300,000 km long rod made of an infinitely stiff material. Participants explore the implications of pushing one end of the rod while simultaneously activating a laser at the other end, questioning whether this could result in instantaneous signal transmission.
  • Some participants propose that if the rod were infinitely stiff, the button at the other end could be pushed instantly upon pushing the rod.
  • Others argue that no material can be infinitely stiff, and that signals would propagate through the rod at the speed of sound, which is significantly slower than the speed of light.
  • A participant notes that electromagnetic forces hold atoms together, implying that even the most rigid materials cannot transmit signals faster than light.
  • One participant introduces a hypothesis suggesting that the molecules in the rod might behave like marbles, creating a domino effect that does not allow for faster-than-light transmission.
  • Another participant acknowledges the commonality of the question and refers to existing resources that address the topic.
  • Some participants express gratitude for the insights shared, indicating a learning process regarding the limitations of material properties in relation to signal transmission.
Participants generally agree that the concept of an infinitely stiff rod is not physically realizable, and that signals cannot be transmitted faster than light. However, there are competing views regarding the nature of signal propagation and the behavior of materials under stress.
Limitations include assumptions about material properties, the definition of stiffness, and the nature of signal propagation in different materials. The discussion does not resolve the complexities surrounding these concepts.
This discussion may be of interest to those exploring concepts in physics related to material properties, signal transmission, and the fundamental limits imposed by the speed of light.
butifarra
Hi everybody. I have always wondered something and have not been able to get an answer.
Let us suppose we have a 300.000 km long straight rod. It is of graphene, or any very tough material, of absoulte stiffness, without any displacement or absorption between its molecules.
Parallel to the rod I have a laser light. The laser is in the A end of the rod. In the B end of the rod there is a button, the rod is touching the button but not pushing it.
Aside the button, there is a optical sensor that can detect the laser light.
If I push the A end of the rod and simultaneously turn the laser on, the sensor will receive the siganl one second later, and the button in the B end of the rod... wil be pushed instantly?
Science news on Phys.org
The button will be pushed by the rod a MUCH longer time since the "push" will traverse the rod at the speed of sound in graphene, whatever that is.
Trouble is, there are no infinitely stiff materials. Signal will propagate through the rod at the speed of sound for such a rod. Which can be as high as few kilometers per second, but that's still about 5 orders of magnitude slower than light.
As an absolute limit on material stiffness, keep in mind that atoms within the material are still held together by electromagnetic forces. So even if we push the envelope of physically possible and look at an absolute upper limit, it's still the speed of light.There are ways to beat speed of light limit. They all have to do with the fact that it's a local limit, not a global one.
Also a 300k Km long infinitely stiff rod will have mass that will require a set amount of energy to push it. Any mass that "can" be pushed at the speed of light will invariably compress the rear of the mass into a state of fusion as the front will remain static and will in all probability result in a fusion explosion. IMHO anyway!
Please take a look at our FAQ entry on this topic: Can I send a signal faster than light by pushing a rigid rod?
Ok, K2's reply is the best, I believe. I had taken into account the sound speed of the material, but not the fact that, ultimately, the electromagentic forces keep the molecules united. I didn´t know, either, it was a common question, as the link to the already explained subject shows.
Thank you all very much.
You had assumed infinite stiffness, and therefore infinite sound speed of the material. But even graphene doesn't have infinite sound speed. (I'm not trying to sound condescending, just this is how I would explain what happens).
Yes Bruce, you are right. Thanks to all for your time.
I have wondered this myself. I have hypothesized that perhaps the molecules that make up the rod behave more like marbles than expected. Instead of them being fixed to each other, perhaps they push each other, and creates a domino effect, that does not transmit the information faster than light.
That's just my hypothesis.
That's pretty much correct; the effect is more obvious in softer materials or liquids.
  • · Replies 20 ·
  • · Replies 17 ·
  • · Replies 30 ·
  • · Replies 24 ·
