Trig identities, what does this mean?
7 replies · 12K views
supernova1203
Tan theta=sin theta/cos theta
What does that identity mean? What does it say about the triangle?
And what on Earth is an identity?
I understand everything taught in the course so far, trig ratios, reciprocal trig ratios, special angles etc etc...but i have no idea what identities mean, some of them i recognize because they are reciprocal trig functions like
sin theta=1/cosecant theta -->which means that sin theta the angle is reciprocal to its cosecant... but Tan theta=Sin theta/cos theta... what does that even mean?or what about cotangent theta = cos theta/sin theta
Im lost mostly in trig identities @_@
and please no dictionary definitions, pretend your trying to explain these concepts to your 80 year old grandma @_@
from what i can gather an identity is basically left side equals right side?
for some reason reciprocal trig identities are easier for me to comprehend...because i know what a reciprocal is
omg i just read a page where it shows the sides as being sin theta and cos theta...i thought theta was for angles then why did they mark the sides of the triangle like this?
for tan theta if you break up sin and cos into their parts, that is op/hy and adj/hp and divide you will get the definition of tan which is op/adj. cot is when you divide cos/sin again the hyp will cancel out.
Identities are like masks to an actor: the same actor can wear many masks. There synonyms telling you the same thing. so yes one side does equal another.
hope this helps a bit
I would recommend going to
http://www.khanacademy.org/video/trigonometric-identities?playlist=Trigonometry
And watching this video, along with the following four. He does a good job on breaking it down in simpler terms.
your right, i just checked it out, makes a whole lot more sense than how the teachers explain it...
Sin(θ) is not an angle, or a side. Sine, Cosine, and Tangent are all functions of angles. In right triangle, these give the ratios of sides.
θ is an angle, however.
Are sine, cosine, and tan defined for anything other than a right triangle? and if not why not?
Yes; sine, cosine, and tangent are defined for all triangles. They can also be defined without reference to triangles. When working with triangles, oblique triangles are thought of as being two right triangles.
They also apply to oblique triangles, although you have to use the law of sines and cosines.
