MHB Is 1/(1+sinx) + 1/(1-sinx) Equal to 2sec2x?
  • Thread starter Thread starter chlobuggy
    Identity Trig
The discussion revolves around verifying the trigonometric identity 1/(1+sinx) + 1/(1-sinx) = 2sec^2x. Participants explain that by manipulating the identity using the Pythagorean theorem, specifically 1 - sin^2(x) = cos^2(x), the equation can be simplified. The result shows that the left side equals 2/cos^2(x), which confirms the identity as 2sec^2(x). The conversation also emphasizes the importance of understanding the underlying concepts rather than just seeking quick answers. Overall, the thread provides a clear explanation of the trigonometric identity verification process.
chlobuggy
1 + 1 = 2 sec2x
______ ________
1+sinx 1-sinx
PLEASE SOMEONE HELP!
UGH! In case you can't tell what that says, it's 1/1+sinx + 1/1-sinx = 2sec2x
Mathematics news on Phys.org
Re: Verfication
chlobuggy said:
1 + 1 = 2 sec2x
______ ________
1+sinx 1-sinx
We want to show that:
\[\frac{1}{1+\sin(x)}+\frac{1}{1-\sin(x)}=2 \sec^2(x)\]
Well:
\[\frac{1}{1+\sin(x)}+\frac{1}{1-\sin(x)}=\frac{(1-\sin(x))+(1-\sin(x))}{(1+\sin(x))(1-\sin(x))}=\frac{2}{1-\sin^2(x)}=\frac{2}{\cos^2(x)}\]
etc...
CB
Re: Verfication
chlobuggy said:
1 + 1 = 2 sec2x
______ ________
1+sinx 1-sinx
(With apologies to Captain Black: sorry, I didn't realize that you had undertaken to help this newcomer till I had laboriously put up my post, after which I felt disinclined to waste the whole thing by pulling it down: i certainly DID NOT want to seem like I was jumping in, and would not have done so, had I realized that you had already answered)
Hellow ChloBuggy and welcome to the site
First, you need to learn to use the resources of the site. Have a look around and learn how to write equations so that others will be able to better assist you.
Second, why the urgency?
In the meantime, what you have here is a simple trigonometric identity, based on the core identity of Pythagoras, which is:
$$cos^2(x)+sin^2(x)=1$$
It is the manipulation of this identity which will allow you to solve your equation, which I think must be as follows:
$$\frac{1}{1+sin(x)}+\frac{1}{1-sin(x)}=\frac{2}{1-sin^2(x)}$$
$1-sin^2(x)=cos^2(x)$ (Refer to the initial Pythagorean identity)
This gives you: $$\frac{2}{cos^2(x)}=sec^2(x)$$
Divide both sides by 2 and you are left with your identity:
$$sec^2(x)=sec^2(x)$$
However, unless you know why you are doing this, I am afraid what I have written will not help much.
But I offer it nonetheless in case it spurs you on to learn some more about the site and to get some more help from those better equipped to do so than I, who am a beginner at this.
Best regs,
DeusAbscondus
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
