Trig substitution integral(need a check on the solution)
4 replies · 11K views · last reply
vande060
this is the first problem like this I've ever tried so take it easy!:redface:
evaluate the integral
I = ∫ x^3/√(16-x^2) dx from 0 to 2√3
- π/2 < ϑ < π/2
x = 4sinϑ , dx = 4cosϑdϑ
*x = 2√3, x/4 = sinϑ , sinϑ = √3/2 , ϑ = π/3
x = 0 sinϑ = 0 , ϑ = 0
4cosϑ = √(16-x^2)
I = ∫ (4sinϑ)^3 * 4cosϑdϑ /4cosϑ
I = ∫ (4sinϑ)^3 dϑ
I = 64 ∫ sin^3ϑ dϑ
I = 64 ∫ (1-cos^2ϑ)*sinϑ dϑ
u = cosϑ
du = -sinϑ
I = -64 ∫ (1-u^2)du
I = -64( cosϑ - cos^3ϑ/3) + C
converting back to x
sinϑ = x/4
cosϑ = √(x^2 -16)/4
I = -64{[ √(x^2 -16)/4] - [√(x^2 -16)/4]^3/3]} from 0 to π/3
i think i made a mistake because i get imaginary numbers here
maybe i wasnt supposed to convert back to x, but change the solve in an integral set to theta bounds and expressed in theta like below
I = -64( cosϑ - cos^3ϑ/3) + C from 0 to pi/3
-64[( 1/2 - 1/24) - (1 - 1/3)] = 40/3
i) You actually don't need to use a trig substitution here. u=16-x^2 will actually do the job. ii) If you do, then if sin(x)=x/4 then cos(x)=sqrt(16-x^2)/4. Not the x^2-16 thing. That's where your imaginaries are coming from. And iii) If you've changed the variable back to x then the limits are 0 to 2*sqrt(3), not the theta limit of pi/3. Actually a lot of the rest of it is correct, which is good. But I didn't check every line.
i actually just realized that before i read your post, so is that last line (40/3) right
If your final answer is 40/3, yes, I think that's right. I didn't actually check your details to the end.
thanks a lot everything is clearer now
