Trig substitution integral (I hope)
7 replies · 2K views
ArcanaNoir
I got to a place in a problem where I need to do a sticky integral, and I'm hoping I can use a trig substitution. If not, I will need to solve the main problem another way :(
[tex]\int_0^\infty \sqrt{1+(e^{-\theta })^2} \; \mathrm{d} \theta[/tex]
[tex]1+\tan ^2 \theta =\sec ^2 \theta[/tex]
Can I let [itex]e^{- \theta } = \tan \phi[/itex] ?
if so, does [itex]\mathrm{d} \theta = \sec ^2 \phi \; \mathrm{d} \phi[/itex] ?
And then, do I have
[tex]\int \sec ^3 \phi \; \mathrm{d} \phi[/tex] ?
Aside from the fact you can tell the integral is divergent just by looking at it, d(exp(-t))=(-exp(-t)*dt).
Any particular reason you want to do a trig substitution?
Myself, I'm not a fan of trig substitutions.
Usually my first step is take a part of the expression and call it "u".
Do a substitution and see what you are left with.
I see a trig substitution more as a last resort.
Maybe I should start at the beginning.
I need to find the total length of the spiral [itex]r(\theta )=e^{-\theta }[/itex] for [itex]\theta \in [0,\infty )[/itex]
There is a formula for arc length, but I don't necessarily have to use it if there is another way:
[tex]L=\int \sqrt{1+(r')^2} \; \mathrm{d} \theta[/tex]
I'm concerned right away about the infinity.
Hmm, that is not the right formula for the length of your curve.
I suspect you are mixing up the formula with a cartesian version.
Alas. So, how about [tex]L=\int_0^\infty \sqrt{r^2+(\frac{dr}{d\theta} )^2} \; \mathrm{d} \theta[/tex]
in which case I will be computing
[tex]\int_0^\infty \sqrt{ e^{-2 \theta } + (-e^{-\theta } )^2 } \; \mathrm{d} \theta[/tex] ?
