Trig substitution into integrals
The discussion centers on the use of trigonometric substitution for evaluating the convergence of the series ∑1/(n^2 - 1) from n=3 to infinity. The original poster questions the validity of substituting n with 2sin(u) when the upper bound approaches infinity, leading to concerns about the sine function's range. It is clarified that the substitution can still be made by evaluating the integral from 3 to a finite limit b and then taking the limit as b approaches infinity. However, participants suggest that using partial fractions is a more straightforward and effective method for this integral. The consensus is that while trigonometric substitution is possible, partial fractions are preferred for this specific case.
tadf2
I was testing for convergence of a series:
∑\frac{1}{n^2 -1} from n=3 to infinity
I used the integral test, substituting n as 2sin(u)
so here's the question:
when using the trig substitution, I realized the upperbound, infinity, would fit inside the sine.
Is it still possible to make the substitution? Or is there a restriction when this happens?
Mathematics news on Phys.org
What does "fit inside the sine" mean?
Sure, you can make the substitution. The integral will be from 3 to, say b, and you take the limit as b → ∞.
Not that you asked, but it's probably simpler and quicker to break up 1/(n2 - 1) using partial fractions.
Inside the sine meaning, the argument of the 'arcsine' would only range from -1 to 1.
So I'm guessing you can't make the substitution because arcsin(infinity) = error?
If you're looking for an appropriate trig substitution for the definite integral (and not just one that gets you a correct antidierivative), then ##\sec u## is the way to go. But like Mark44 said, partial fractions is really the "right" technique of integration for this particular integral.
Here is a little puzzle from the book 100 Geometric Games by Pierre Berloquin. The side of a small square is one meter long and the side of a larger square one and a half meters long. One vertex of the large square is at the center of the small square. The side of the large square cuts two sides of the small square into one- third parts and two-thirds parts. What is the area where the squares overlap?
