MHB Solve Trigonometry Challenge: $\cos^k x-\sin^k x=1$
The equation $\cos^k x - \sin^k x = 1$ is analyzed for positive integer values of $k$. For $k=1$, the solutions are $x=0$ and $x=\frac{3\pi}{2}$. For $k \geq 2$, the function $f_k(x)$ is shown to have a maximum value of 1, occurring at specific points, leading to solutions at $x=0$, $x=\pi$ (if $k$ is even), and $x=\frac{3\pi}{2}$ (if $k$ is odd). The analysis utilizes calculus and the method of Lagrange multipliers to determine the extreme values of the function. Overall, the solutions are confirmed to be exhaustive for the given conditions.
anemone
MHB
POTW Director
Solve the equation $\cos^k x-\sin^k x=1$, where $k$ is a given positive integer.
Mathematics news on Phys.org
partial solution easy part(there is a difficult part also)
for k even.
only solution
$\cos^k x=1$
$\sin^k x=0$
so
$\sin\, x=0$ and $\cos\, x=\pm 1$ hence $x = n\pi$
k is odd
there are 3 cases
case 1)
$\cos\ x=1$
$\sin\ x=0$
this case is a subset of above case $x = 2n\pi$
case 2)
$\cos\ x=0$
$\sin\ x=-1$
giving $x = (2n-\dfrac{1}{2})\pi$
case 3)
$\cos\ x$, $\sin\ x$ are non integers
This is the difficult part(remaining )
[sp]
Let $f_k(x) = \cos^k x-\sin^k x$. This is periodic, with period $2\pi$, so it will be sufficient to find solutions of $f_k(x) = 1$ in the interval $x\in [0,2\pi).$
If $k=1$ then $f_1(x) = \cos x - \sin x = \sqrt2\cos\bigl(x + \frac\pi4\bigr)$. That takes the value $1$ when $\cos\bigl(x + \frac\pi4\bigr) = \frac1{\sqrt2}$, in other words $x + \frac\pi4 = \frac\pi4 \text{ or }\frac{7\pi}4.$ Thus the solutions to $f_1(x) = 1$ are $x=0,\frac{3\pi}2.$
The case $k=1$ is anomalous, because that is the only value of $k$ for which $|\,f_k(x)|$ can ever be greater than $1$. One way to see this is by calculus, using the method of Lagrange multipliers. Suppose that $k\geqslant2$. If we let $u = \cos x$ and $v = \sin x$, then we want to find the extreme values of $u^k - v^k$ subject to the constraint $u^2+v^2 = 1$. The Lagrange method gives the equations $$ku^{k-1} - 2\lambda u = 0, \qquad -kv^{k-1} - 2\lambda v = 0.$$ Therefore either $u=0$ or $u^{k-2} = \frac{2\lambda}k$, and similarly either $v=0$ or $v^{k-2} = -\frac{2\lambda}k$. Combining those values with the fact that $u^2+v^2=1$, it follows that if $u=0$ then $v = \pm1$, and if $v=0$ then $u = \pm1$. If both $u$ and $v$ are nonzero then $u^{k-2} = -v^{k-2}$. In the case when $k$ is odd, the $(k-2)$-th roots are unique and it follows that $u=-v$, so that $(u,v) = \pm\bigl(\frac1{\sqrt2},-\frac1{\sqrt2}\bigr)$. But when $k$ is even there are two (real) $(k-2)$-th roots, so there is the additional possibility that $u=v=\pm\frac1{\sqrt2}$.
This shows that the only possible extreme values of $(u,v)$ are $(\pm1,0)$, $(0,\pm1)$ and $\bigl(\pm\frac1{\sqrt2}, \pm\frac1{\sqrt2}\bigr)$. In terms of $x$, with $(u,v) = (\cos x,\sin x)$, this means that the only extreme values of $f_k(x)$ must occur when $x$ is a multiple of $\frac\pi4$. It is easy to check that $|\,f_k(x)| \leqslant1$ at all those points (and hence everywhere), and that the only points in $[0,2\pi)$ where $f_k(x) =1$ are $x=0$, together with $x=\pi$ (if $k$ is even) and $x = \frac{3\pi}2$ (if $k$ is odd). So the solutions found by kaliprasad are the only ones.
[/sp]
Thank you Kali (for your partial solution) and Opalg for your solution that complements Kali's!
I can't wait any longer to share the other solution that I found somewhere online and I certainly hope you like the method used to solve it as much as I do:
For $k\ge 2$, we have
$1=\cos^k x-\sin^k x \le |cos^k x-\sin^k x|\le |\cos^k x|+|\sin^k x| \le \cos ^2 x+\sin^2 x=1$
Hence, $\sin^2 x=|\sin^k x|$ and $\cos^2 x=|\cos^k x|$, from which it follows that $\sin x,\,\cos x\in\{1,\,0,\,-1\}\implies x\in\dfrac{\pi Z}{2}$. By inspection one obtains the set of solutions
$\{n\pi,\, n\in Z\}$ for even $k$ and $\{2n\pi,\,2n\pi-\dfrac{\pi}{2},\,n\in Z\}$ for odd $k$.
For $k=1$, we have $1=\cos x-\sin x=-\sqrt{2}\sin\left(x-\dfrac{\pi}{4}\right)$ which yields the set of solutions $\{2n\pi,\,2n\pi-\dfrac{\pi}{2},\,n\in Z\}$.
Therefore, the solutions to the given equation is $\{n\pi,\,2n\pi-\dfrac{\pi}{2},\,n\in Z\}$.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
