Trigonometry reflection problem
  • Context: Undergrad
  • Thread starter Thread starter Lindsayyyy
    Reflection Trigonometry
5 replies · 3K views
Lindsayyyy
Hi,
I was about solving a refrection problem and I'm just one step away from the solution. I stuck at some simple problem I guess.
I have:
[tex]\alpha=60°+\frac1 3 arcsin(\frac1 {1,33} sin(\alpha))[/tex]
and I want to find the alpha but I have troubles to solve this.
I guess it's not that hard, but I'm failing right now :blushing:
Thanks for your help in advance
Mathematics news on Phys.org
Hi Lindsayyyy! :smile:
The problem you have here has afaik no algebraic solution.
If that is what you're looking for, you won't find it.
What you can do, of course, is make an approximation.
That's easy with for instance http://wolframalpha.com.
Cheers! :smile:
Hhhmm...I gave it a try, and I solved by hand pretty easily.
This was my approach:
Multiply both side of the equation by 3, to eliminate the 3 in the denominator.
Move the 180 from the righ to the left
take the sine of both sides of the equation
you should have
sin(3a - 180) = sin( arcsin( (1/1.33) sin(a) ) )
but the sin(p-180) = -sin(p)
-sin(3a) = sin( arcsin( (1/1.33) sin(a) ) )
and the sin ( arcsin(x) ) = x
-sin(3a) = (1/1.33) sin(a)
and sin(3a) = 3sin(a) - 4(sin(a))^3
-3sin(a) + 4(sin(a))^3 = (1/1.33)sin(a)
put everything on one side of the equation and you have a cubic equation without a quadratic or constant term:
4(sin(a))^3 - (3 + 1/1.33)sin(a) = 0
Now, we simply say
X = sin(a)
A = 4
C = -(3 + 1/1.33)
and we have
AX^3 + CX = 0
or, if we factor one X out:
X ( AX^2 + C ) = 0
So, one solution is X1 = zero, due to the single X...now, we need to solve the roots of the quadratic equation with no B term:
X2 = +sqrt ( -C/A ) = 0.9685
X3 = -sqrt ( -C/A ) = -0.9685
So, from X = sin(a)
a = arcsin(X)
a1 = arcsin(0) = 0 degrees
a2 = arcsin(0.9685) = 75.578 degrees
a3 = arcsin(-0.9685) = -75.578 degrees
and that's it.
You still need to check if the solutions work.
You created an extra solution when you replaced
3a - 180 = arcsin( (1/1.33) sin(a) ) with
sin(3a - 180) = sin(arcsin( (1/1.33) sin(a) ))
Awww! You're right.
I made a mistake in my calculation and came out with sine's with different arguments that could not be made equal.
Good catch! :smile:
willem2 said:
You created an extra solution when you replaced ...
Yes. That is right too...
There is an extra condition that -90 < 3a - 180 ≤ 90.
That is, 30 < a ≤ 90.Cheers! :smile:
Thank you very much for help. Nice approach @ gsal, this helped me a lot.:approve:
