Trip to Space -- Can ship with 1g acceleration escape Earth?
- Level: Undergrad
- Thread starter ckirmser
- Start date
50 replies · 8K views
Thomas Wown
- 3
- 0
Earths gravity is around 9 and most planes that take off Horizontally accelerate and 3-4 gz (Boeing). So yes it's possible. Common sense wins!
Staff Emeritus
Education Advisor
Dearly Missed
- 35,014
- 21,725
Dale said:Just dig a tunnel straight down through the earth
Or use a big spring.
ckirmser
- 105
- 3
Well, it appears that, no matter how loud my gut screams at me, it's just flat wrong.
But, is it only because we're dealing with a sphere and the starting position of the ship is separated from the point source of gravity, the center of the Earth?
I mean, theoretically, if we deal with point sources of gravity and acceleration, then the "ship" has no track to ride and is forced, no matter what direction it points, to give its 1G acceleration directly against the 1G of gravity. The one cancels out the other and the ship goes nowhere.
I figure it must be because, as I said in an earlier post, the track is providing a virtual force opposite that of gravity, allowing the ship to get sort of a false acceleration upwards, even though all of its own acceleration is being used to push it along the track.
Still doesn't seem right...
- 4,348
What do you mean by that?ckirmser said:...if we deal with point sources of gravity...
If you start at the point mass, then you have infinite Newtonian gravity, not 1g.
If you start at distance r from the point mass where gravity is 1g, then it's even simpler to escape with 1g proper acceleration, because the planet is not in the way.
Mentor
- 15,584
- 10,900
Point sources of gravity are tricky because Newton's law of gravity applies in all the space around the point but not at the point itself. One way to see this is that at ##r=0## Newton's law of gravity gives you an infinite force pointing in no direction; the nonsensical result is the math's way of telling you that it doesn't work under those conditions. This is not a problem because such ideal point masses do not exist and it should be no surprise that the math does not describe the behavior of something that cannot exist. However, it does mean that if you try to analyze the behavior of the spaceship at ##r=0## you are committing a logical error similar to the one you are committing if you start a mathematical proof with something like "Let ##n>1## be a common factor of two different prime numbers ##P## and ##Q##..."; the initial premise is bogus so can lead to bogus results.ckirmser said:I mean, theoretically, if we deal with point sources of gravity and acceleration...
There is nothing virtual about that force. When the ship is resting on the track a spring scale between the ship and the track will clearly show that the track is pushing on the ship with some force; we infer that the force of gravity on the ship is equal to and opposite to the force of the track on the ship because the ship is not accelerating so the net force on the ship is zero. If the track were not exerting this upwards force on the ship it would fall towards the center of the earth. Nor is there any "false acceleration" involved; the ##F## in ##F=ma## is always the total force from all sources acting on the object that is accelerating with acceleration ##a##. It pretty much has to be that way because the object in question only has one acceleration vector at any moment, no matter how many different forces are acting on it at that moment.the track is providing a virtual force opposite that of gravity, allowing the ship to get sort of a false acceleration upwards,
- 2,002
Let's assume the mass of the Earth is concentrated to a point, but your ship still starts 1 Earth radius away where gravity is 1g. There is no track, but your ship is pointed in such a way that it is laying on its side. Without firing his engines, he would fall straight in towards the center. If he fires his engines at all, even briefly, he will put him self in an elliptical orbit around the central mass with the mass at one focus. The longer he fires his engine, the further his closest approach will be from the central mass.ckirmser said:Well, it appears that, no matter how loud my gut screams at me, it's just flat wrong.
Now even if he no longer fires his engines, he will pick up speed as he moves in closer to the center.
I mention this so we can consider the following scenario:
He fires his engines once briefly to put himself in that elliptical orbit. Once his reaches his closest approach he will picked up a great deal of speed. He will in fact be moving much faster than circular orbital speed for that same distance. Escape velocity is ~1.414 times the circular orbital velocity for the distance from the center we are considering. This means, that at this moment, our ship is closer to escape velocity than something in a circular orbit at that distance would be.
Now we make sure our ship is pointed in the same direction as our orbital motion, and fire our engines briefly again, increasing our speed even more. This changes the orbit, raising the other end of the orbit.
So let's say that this still left you short of escape velocity. Just wait until you've completed one whole orbit, and then do another brief thrust. This increases your velocity even more, pushing the high end even higher. Just keep repeating this until your last thrust puts you over escape velocity. This process works without your even having to provide thrust the entire time, and no matter how weak your thrust is. (This method is actually more efficient than continuous thrust.)
Orbital mechanics is one of those disciplines where intuitive "gut feeling" can often lead you badly astray.
Homework Helper
- 30,596
- 7,548
But the cannon ball does not travel on a track and has to be traveling at the appropriate speed as soon as it is launched. It is a very different thing from a vehicle on a rail that could accelerate at any rate at all until the track ends, in principle. If you exchange the track for the lift from a wing, a similar argument applies and the vehicle can be accelerating continually whilst it has atmosphere to travel through. Drag is a factor of course but efficiency of a rocket system is the reason why they're operated with high acceleration.Janus said:Look up Newton's cannon.
- 3,777
- 2,002
sophiecentaur said:But the cannon ball does not travel on a track and has to be traveling at the appropriate speed as soon as it is launched. It is a very different thing from a vehicle on a rail that could accelerate at any rate at all until the track ends, in principle. If you exchange the track for the lift from a wing, a similar argument applies and the vehicle can be accelerating continually whilst it has atmosphere to travel through. Drag is a factor of course but efficiency of a rocket system is the reason why they're operated with high acceleration.
The barrel of the cannon acts like the track from the time the powder is ignited until it leaves the muzzle and while the projectile accelerates. The track just serves the same purpose for a lower acceleration and longer run. The point is that it doesn't matter how the projectile achieves orbital/escape velocity relative to the surface, just that it eventually does.
Homework Helper
- 30,596
- 7,548
Precisely. The OP asks about low values of acceleration. The cannon provides very high acceleration to get the same result.Janus said:The track just serves the same purpose for a lower acceleration and longer run.
What really counts is the Kinetic Energy that the Ship can be given and that can (at least in principle) be dished out in as long a time as you may choose.
Photonboy
- 1
- 0
*The main CONFUSION is the air resistance.
If we assume NO air at all, and assume that the ship can apply 1G maximum thrust then it can either accelerate directly UPWARDS just enough to cancel out out gravity (thus weighing NOTHING relative to a normal scale, but also not going anywhere). The ship can move sideways relative to the surface as well, but without any air it would just slide around on the surface.
Now, once we have AIR resistance this all changes. As long as the aerodynamics are sound, then we can fly like normal and eventually spiral off. It's actually impossible to have indefinite thrust as you lose mass but assuming that you'll eventually escape. You lose speed due to air resistance, but the air resistance also thins as you get higher so (in theory) you can escape. The thrust required isn't slightly more than 1G as it would be in a vacuum, plus since we are no longer at the 1G equalized point (if we assumed surface was where the vectors cancel to zero), we are higher.
As said elsewhere you need to be VERY SPECIFIC with the wording because having air, or wings etc changes the question.
ckirmser
- 105
- 3
A.T. said:What do you mean by that?
Well, typically, one doesn't do all the Calculus necessary to figure the gravity affecting a body on the surface of a planet by figuring out what it is from all the mass below the surface in all directions. Instead, one just assumes the gravity of the body is focused at the center of mass.
Not a point mass in fact, but only for the purpose of making the discussion and the math easier.
Actually, using the Earth as an example, it's only 1g at the surface. At the center, it is 0g. So, all ships leaving Earth will start at r, which is, what, around 4,000 miles? At that distance, the effect of gravity is 1g.
John Park
- 193
- 30
But even on an airless world as long as the ship can accelerate horizontally it will eventually reach escape speed.
John Park
- 193
- 30
That's more or less how I'd look at it.
Note that when space vehicles take off, they start out vertically until they're out of the atmosphere; then they shift to a roughly horizontal trajectory, which is apparently a more efficient way to build up speed.
ckirmser
- 105
- 3
Nugatory said:Point sources of gravity are tricky because Newton's law of gravity applies in all the space around the point but not at the point itself. One way to see this is that at ##r=0## Newton's law of gravity gives you an infinite force pointing in no direction; the nonsensical result is the math's way of telling you that it doesn't work under those conditions. This is not a problem because such ideal point masses do not exist and it should be no surprise that the math does not describe the behavior of something that cannot exist. However, it does mean that if you try to analyze the behavior of the spaceship at ##r=0## you are committing a logical error similar to the one you are committing if you start a mathematical proof with something like "Let ##n>1## be a common factor of two different prime numbers ##P## and ##Q##..."; the initial premise is bogus so can lead to bogus results.
Well, OK, true. I'm simplifying - perhaps over-simplifying - because this has only to do with a game. My reference is an old GDW game called Triplanetary.
In the game, 1 hex is equal to the distance traveled at 1g acceleration in the course of a turn. Final movement is determined by adding together the vectors of hexes entered and the acceleration of the ship for that turn. Planets are represented by a dot and each adjacent hex has a gravity arrow pointing towards the planet, like so;
A ship with 1g acceleration, trying to leave the planet, would go to an adjacent hex, add it's acceleration vector to the gravity vector of the planet, giving it a net movement of 0;
This is what I refer to as a "point source."
I may have been a bit sloppy in my terms. By virtual, I meant that it is not a force of gravity or acceleration.
So, the ship can never leave the planet. But, it appears this is wrong by the use of a track around the planet - well, a theoretical track. Probably, in reality, there'd be no such track allowing the ship to get the speed up while being held down and having part of the gravity mitigated thereby.
ckirmser
- 105
- 3
Janus said:Orbital mechanics is one of those disciplines where intuitive "gut feeling" can often lead you badly astray.
Kinda like vertigo.
"I know the bubbles are going that way, but they are WRONG! UP is over the other way!"
Homework Helper
- 13,438
- 8,110
These forums are about real world physics, not counter-factual game physics. In real life, 1 g is an acceleration, not a velocity.ckirmser said:In the game, 1 hex is equal to the distance traveled at 1g acceleration in the course of a turn.
ckirmser
- 105
- 3
Photonboy said:As said elsewhere you need to be VERY SPECIFIC with the wording because having air, or wings etc changes the question.
I haven't been including air, just a track. Atmospherics adds more trouble to the main question.
However, my second image in post #19 is composed just from the vectors given by gravity and acceleration, and the supportive force of the track. No air at all.
ckirmser
- 105
- 3
jbriggs444 said:These forums are about real world physics, not counter-factual game physics. In real life, 1 g is an acceleration, not a velocity.
The game example was just to illustrate how I was coming at this. It is still vector math, be it real life or game theory. And, in the game, the vector is an acceleration, not a velocity.
When extrapolated to a sphere, and the same vector math applied, I was able to visualize far better why the ship could leave when running on a track.
Homework Helper
- 30,596
- 7,548
Efficiency is what it's all about. The OP is about 'Acceleration' and I'm afraid that a discussion which doesn't include the Energy requirements is really hardly worth having when space launches are concerned.John Park said:That's more or less how I'd look at it.
Mentor
- 15,584
- 10,900
That makes no sense, unless the one turn of the game is supposed to represent a different amount of time for different players and different stages of the game, and I doubt you intended that. The problem is that the distance traveled depends on the initial velocity as well as the acceleration, so the same 1g acceleration will mean different distances traveled and "the distance traveled at 1g acceleration" is ill-defined. The original 1973-vintage Triplanetary game doesn't make this mistake (and it may be that you just meant to say something different here than what you actually said). The original game also does allow the ship to escape earth, because of the rule that vectors that originate in a gravity hex are not affected by the hex.ckirmser said:In the game, 1 hex is equal to the distance traveled at 1g acceleration in the course of a turn.
However... Although that early version of the game did make a creditable effort (given the limitations of the grease-pen mechanics - these days we could play it on a whiteboard with a hex grid projected on it) to model the effects of gravity and acceleration, it really has very little to do with any real physics. We help you with understanding what physics really says, but that's no longer what this discusion is about, so it is closed.
- ckirmser
- · Replies 31 ·
- Mechanics
- Replies
- 31
- bob012345
- · Replies 21 ·
- Special and General Relativity
- Replies
- 21
Writing: Input Wanted
Flight duration to L4 point and 90-degree Earth orbit with constant 1g acceleration
- Fred Bobo
- · Replies 6 ·
- Sci-Fi Writing and World Building
- Replies
- 6
- somethingswrong
- · Replies 7 ·
- Replies
- 7
- Chinspinner
- · Replies 10 ·
- Replies
- 10
- servo75
- · Replies 9 ·
- Replies
- 9
- zeroxg
- · Replies 1 ·
- Replies
- 1
- Zigzagcom
- · Replies 12 ·
- Optics
- Replies
- 12
- ledopmi
- · Replies 12 ·
- Replies
- 12
- merovingian
- · Replies 12 ·
- Introductory Physics Homework Help
- Replies
- 12
