Triple integral in spherical coordinates
6 replies · 7K views · last reply
musicmar
use spherical coordinates to calculate the triple integral of f(x,y,z) over the given region.
f(x,y,z)= sqrt(x^2+y^2+z^2); x^2+y^2+z^2<=2z
Once I find the bounds, I can do the integral. But I'm having trouble with the bounds of rho.
This region is a sphere of radius 1 centered at (0,0,1). If this is true, then theta and phi both range from 0 to 2pi.
Does rho range from 0 to 2, or do I need to use the function of the region in there somewhere?
Thank you.
You can change variables in f so that you move the center of the sphere to the origin. Equivalently, you can use spherical coordinates centered at (0,0,1). The definition of x and y are the same, but
[tex]z = 1 + \rho \cos\theta.[/tex]
The ranges of [tex](\rho,\theta,\phi)[/tex] don't change, but [tex]\rho^2 = x^2 + y^2 + (z-1)^2[/tex]
Where did the (z-1)^2 come from? And having rho^2 in terms of x,y, and z doesn't really help me. x=rho sin(theta)cos(phi), y=rho sin(theta)sin(phi), and z=rho cos(phi).
I don't really understand your response. Sorry. Could you clarify?
Thank you.
Thank you.
In your coordinates, [tex]\rho = 0[/tex] is the point (0,0,0) in Cartesian space. If you use a spherical coordinate system where we shift
[tex]z= 1 + \rho \cos(\phi),[/tex]
then [tex]\rho = 0[/tex] is the point (0,0,1), which is the center of your sphere. This is convenient because we don't have weird ranges for our integral, but the expression of f(x,y,x) is a bit more complicated.
If you didn't shift it, how would you find the bounds of rho?
In the regular coordinates where you have
[tex]\rho = \sqrt{x^2+y^2+z^2} ,[/tex]
you see that, because [tex]-\infty<x,y,x<\infty[/tex], we have [tex]0<\rho < \infty.[/tex] In the shifted coordinates, we find the same range of values for [tex]\rho[/tex].
[itex]\rho[/itex] is the distance from the origin to points on that sphere. Since the sphere has center at (0, 0, 1), it contains both (0, 0, 0) (at distance 1 directly below (0, 0, 1) on the z-axis) and (0, 0, 2) (at distance 1 directly above (0, 0, 1). The first point has distance 0 from (0, 0, 0) and is the smallest value of [itex]\rho[/itex] while the second has distance 2 from (0, 0, 0) and is the largest value of [itex]\rho[/itex].
