Triumph Herald steering tie rod problem
5 replies · 2K views · last reply
Kajan thana
TL;DR
Hi guys, this might be a silly question. I have attached a picture to this thread. Am I right to refer to the component ( shown with the red dash line ) as the steering tie rod? If not, what is the name for that rod?
Thank you
Left: photo of a car's front wheel and suspension in grass, with a red arrow pointing to a line drawing on the right of a steering knuckle with a label reading Section of Failure at the lower end of the shaft.
No I would call that the "stub axle" or perhaps the wheel spindle. The tie rod is the thing that supplies the turning torque from the steering box.
  • Love
Thank you so much
The horizontal part with wheel bearings is the stub axle.
The near vertical part with steering bearings is the kingpin.
Since it is all one casting on a tractor it is called a “kingpin / stub axle”, or some similar combination.
I believe the piece doing the job of a kingpin can also be called the Vertical Link (Triumph Herald suspension parts list).
But Stub axle describes perfectly the broken part. A wheel fits on an axle and the axle, in that case is just a 'stub' (short). You could have some fun, separating the two parts of that component in the photo. Heat, cold and steady force but no bashing if you can help it
The tie rod is the thinner, horizontal rod at top left of the photo.
sophiecentaur said:
Triumph Herald
my wife's first car was a Herald. An oddity in the US.
