Trouble understanding coordinates for the Lagrangian
4 replies · 2K views · last reply
p1ndol
Hello, I'm having some trouble understanding this solution provided in Landau's book on mechanics. I'd like to understand how they arrived at the infinitesimal displacement for the particles m1. I appreciate any kind of help regarding this problem, thank you!
  • Diagram of a rhombus-shaped linkage hanging from a point A on a vertical axis, with two masses m1 at the side corners and a mass m2 sliding on the lower part of the axis; segments a are labelled and angle theta is marked at A.
It's nothing more than Pythagoras applied to orthogonal infinitesimal displacements ##ad\theta## and ##a\sin{\theta} d\phi##, however if you want a (very slightly) more formal approach in terms of the holonomic basis...
if ##\phi## is held constant then ##\mathbf{E}_{\theta} = \dfrac{\partial \mathbf{r}}{\partial \theta} = a \hat{\boldsymbol{e}}_{\theta}## whilst if ##\theta## is held constant then ##\mathbf{E}_{\phi} = \dfrac{\partial \mathbf{r}}{\partial \phi} = a\sin{\theta} \hat{\boldsymbol{e}}_{\phi}##. Since ##\mathbf{E}_{\theta}## and ##\mathbf{E}_{\phi}## are orthogonal you have $$dl^2 = \displaystyle{\sum_i \sum_j }dx^i \mathbf{E}_i \cdot dx^j \mathbf{E}_j= {E_{\theta}}^2 d\theta^2 + {E_{\phi}}^2 d\phi^2 = a^2 d\theta^2 + a^2 \sin^2{\theta} d\phi^2$$
I think he did it in spherical coordinates. The infinitesimal motion of m1 can be disassembled into two parts; this disassembly is correct since the displacements in the two directions are small (meaning they are kinda linear) and orthogonal:
Displacement^2 caused by horizontal rotation ##\Omega##:
$$dl^2_{horizontal}=R^2(\Omega\mathrm{dt})^2=a^2\sin^2 \theta(\Omega\mathrm{dt})^2$$
Displacement^2 caused by the rotation of m1 about A in the plane of book:
$$v=r\omega\implies dl^2_{vertical}=(a\mathrm d{\theta})^2$$
Hope this helps.
