Why is my LM-2940 CT12 regulator IC experiencing erratic function?
  • Thread starter Thread starter Ravaner
The LM-2940CT12 regulator IC is experiencing erratic voltage regulation, dropping from a normal 13.9V to 10.5V under load, despite following datasheet guidelines and using appropriate capacitors. Potential causes include oscillation due to inadequate output capacitor ESR, which could be mitigated by adding a ceramic capacitor in parallel. Circuit layout issues, such as the distance of the filter capacitor from the IC and grounding robustness, may also contribute to the problem. The IC's package size could impact heat dissipation, leading to overheating and failure. The user plans to implement a ceramic capacitor to address the ESR issue, which may stabilize the output voltage.
Ravaner
Hello. I use for several months an LM-2940CT12 to supply 3 PCB's. All datasheet rules were respected.Max current is less than 200 mA. A few weeks ago voltage falls down to 8 V ant head voltage which is normally 13.9 V falls to 10.5 V and so regulation was out of order. I replace the component, and after few days, pb appears one more time. I precise that nothing has been changed on PCB's, and sometimes power works and head and then out voltages returns to correct values. How can we explain that erratic function of reguator IC ?
It could be oscillating. Is it properly bypassed? Does it get hot during normal operation? Did it get hot when the condition occurred? If you powered it down and up again did the condition persist? If you put your finger on the output did it change the voltage?
If it is oscillating it is probably because you used a cheap electrolytic on the output. You could parallel it with a 0.1 ceramic. There is a section in the data sheet regarding ESR of the output capacitor. (it wouldn't paste well)
Also, circuit layout can cause oscillation. the filter cap needs to be close to the part and grounds need to be robust.
What drives the "head" voltage. By head I assume you mean the raw supply is 13.9 DC.
What package are you using? Is it too small to dissipate the 1/2 watt and the part eventually fries? The SOT-223 is 175C/Watt so it would get pretty warm.
Thanks for reply. input cap (filtering) is 4700 µF, output cap 470 µF, distances to IC < 1". IC mounted on heatsink (not really usefull). Absolutely never any oscillation. For the time being it works perfectly ! Anyway I'll place a ceramic cap on output, may be effectively an ESR problem.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
